  3. 有算过水锤的吗
有算过水锤的吗
29 帖子 3 发布者 25.5k 浏览
  • 胡 离线
    胡 离线
    胡同小巷
    又来请教问题了。
    我这是水击问题,开始管道速度为0.1209,我不想让出口瞬间变为0,想让出口设置为慢慢的变为0,比如经历2s,以一定的加速度慢慢的变为0。那出口速度这里应该怎么写?
    谢谢老师:xinxin:
    在 中回复了 胡同小巷 最后由 编辑
    #22
    @胡同小巷 用codedFixedValue 参考 https://www.cfd-china.com/topic/3499 里面有模板
    胡 2 条回复 最后回复
  • 胡 离线
    胡 离线
    胡同小巷
    @李东岳 老师codedFixedValue不是设置非均匀边界的吗?我这个问题是均匀边界,但是是随时间变化的。
    codedFixedValue可以吗?
  • 胡 离线
    胡 离线
    胡同小巷
    @李东岳 老师您好,我用rhoPimpleFoam计算水击但是运行不了,不知道什么错误
    p文件
    internalField   uniform 5e+05;
    boundaryField
        fixedWalls
            type            zeroGradient;
        inlet
            type            fixedValue;
            value           uniform 5e+05;
        outlet
            type            zeroGradient;
        frontAndBack
            type            empty;
    U文件
    internalField   uniform (0.12 0 0);
    boundaryField
        fixedWalls
            type            noSlip;
        inlet
            type            zeroGradient;
        outlet
            type            uniformFixedValue;
            uniformValue    scale;
            scale
            type            linearRamp;
            start           0;
            duration        0.4;
            value           2;
        frontAndBack
            type            empty;
    T文件
    internalField   uniform 20;
    boundaryField
        fixedWalls
            type            fixedValue;
        inlet
            type            fixedValue;
        outlet
            type            fixedValue;
        frontAndBack
            type            empty;
    thermophysicalProperties
    thermoType
        type            heRhoThermo;
        mixture         pureMixture;
        transport       const;
        thermo          eConst;
        equationOfState rPolynomial;
        specie          specie;
    mixture
        specie
            molWeight       100;
        equationOfState
            C (0.001278 -2.1055e-06 3.9689e-09 4.3772e-13 -2.0225e-16);
        thermodynamics
            Cv              4185;
            Hf              0;
        transport
            mu              3.967e-05;
            Pr              1;
    controlDict
    application     rhoPimpleFoam;
    startFrom       startTime;
    startTime       0;
    stopAt          endTime;
    endTime         0.4;
    deltaT          0.00001;
    writeControl    timeStep;
    writeInterval   100;
    purgeWrite      0;
    writeFormat     ascii;
    writePrecision  6;
    writeCompression off;
    timeFormat      general;
    timePrecision   6;
    runTimeModifiable true;
    下面是报错:
    Create time
    Create mesh for time = 0
    PIMPLE: No convergence criteria found
    PIMPLE: No corrector convergence criteria found
            Calculations will do 2 corrections
    PIMPLE: Operating solver in transient mode with 2 outer correctors
        type            heRhoThermo;
        transport       const;
        thermo          eConst;
        specie          specie;
    Reading field U
    --> FOAM FATAL IO ERROR:
    Expected a '(' while reading VectorSpace<Form, Cmpt, Ncmpts>, found on line 43 the label 2
    file: /home/huliren/OpenFOAM/huliren-8/run/SHUJI/shuiji/0/U/boundaryField/outlet/value at line 43.
        From function Foam::Istream& Foam::Istream::readBegin(const char*)
        in file db/IOstreams/IOstreams/Istream.C at line 92.
    FOAM exiting
    在 中回复了 胡同小巷 最后由 编辑
    #25
    @胡同小巷 类似这个 https://www.cfd-china.com/topic/5031/用rhopimplefoam计算t型管冷热流混合-计算几步就停掉/1 不涉密的话你清理下算例 发在论坛我给你调一下
    胡 2 条回复 最后回复
  • 胡 离线
    胡 离线
    胡同小巷
    @胡同小巷 老师您好,我把这个文件发到下面了,在您邮箱也发了一份。望老师帮忙调整一下。
  • 胡 离线
    胡 离线
    胡同小巷
    @李东岳 水击,运动粘度0.00003967,进口压力500000,出口速度经历0.4s由0.12降至0,求解0--0.4s内的出口处压力随时间变化曲线
    [链接文本](8076956a-b043-4046-8cf6-9b11d520d44e-shuiji.zip 链接地址)
  • 胡 离线
    胡 离线
    胡同小巷
    @李东岳 老师您好,我这个水击可以计算了,但是感觉结果不对阿,和我用fluent计算的结果差很多的。
    第一个是阀门处的压力随时间变化
    第二个是残差图
    希望老师可以抽点时间帮看一下
    32aa25de-0d6b-48ad-888b-1b9a7b553c7a-图片.png file:///home/huliren/%E5%9B%BE%E7%89%87/2021-08-23%2020-19-33%20%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE.png
    3bbea22f-518a-4e3d-a726-496129e9903a-图片.png file:///home/huliren/%E5%9B%BE%E7%89%87/2021-08-23%2020-19-25%20%E7%9A%84%E5%B1%8F%E5%B9%95%E6%88%AA%E5%9B%BE.png
    在 中回复了 胡同小巷 最后由 编辑
    #29
    @胡同小巷 你那个算例我下载了之后没法运行。好像不是openfoam8的。不过你这个压力的图,看起来比较正常。
