  4. paraview批量保存descriptiveStatistics的数据
3 帖子 1 发布者 4.6k 浏览
  • 氕 离线
    氕 离线
    氕氘-川
    大家好,我切了很多slice求每个切片上平均值,现在求出来后,因为只需要mean这个值,我怎样可以批量导出这个数值?
    这是我保存的方式:
    Render()
    writer = CreateWriter(str(y)+".csv"descriptiveStatistics1)
    writer.FieldAssociation = "Points"
    writer.UpdatePipeline()
    del writer
    但是这样保存会说writer.FieldAssociation = "Points"里面的points不对,然后我去了之后就会报错。
    氕 2 条回复 最后回复
  • 氕 离线
    氕 离线
    氕氘-川
    在 中回复了 氕氘-川 最后由 编辑
    此回复已被删除!
  • 氕 离线
    氕 离线
    氕氘-川
    在 中回复了 氕氘-川 最后由 编辑
    @氕氘-川 批量保存的脚本老报错: ERROR: In C:\bbd\df0abce0\build\paraview\src\paraview\ParaViewCore\VTKExtensions\Default\vtkCSVWriter.cxx, line 82
    vtkCSVWriter (000001F6DAFC08C0): Unable to open file: /-0.1150.csv
    vtkCSVWriter (000001F6DAFCC8C0): Unable to open file: /-0.0650.csv
    这是我的脚本:
    import numpy as np
    from paraview import numpy_support as ns
    import paraview as pv
    import paraview.simple as ps
    afoam = FindSource('a.foam')
    for y in np.arange(-0.115,0.115,0.05):
    # Make a cut of the wing to have a local 2D profile
    Slice1 = Slice( Input=afoam )
    Slice1.SliceType = "Plane"
    Slice1.Triangulatetheslice = 0
    Slice1.SliceOffsetValues = [0.0]
    Slice1.SliceType.Origin = [0.0, y, 0.0]
    Slice1.SliceType.Normal = [0.0, 1.0, 0.0]
    descriptiveStatistics1 = DescriptiveStatistics(Slice1)
    descriptiveStatistics1.VariablesofInterest = ['T']
    descriptiveStatistics1.AttributeMode = 0
    Render()
    writer = CreateWriter(str(y)+".csv",OutputPort(descriptiveStatistics1, 1))
    writer.FieldAssociation = "Cells"
    del writer
    #SaveData(str(y)+".csv", proxy=OutputPort(descriptiveStatistics1, 1), FieldAssociation='Cells')
    descriptiveStatistics1.UpdatePipeline()
