  3. 气液两相 没有纯气体
气液两相 没有纯气体
1 帖子 1 发布者 1.3k 浏览
    hongjiewang
    上面是加热壁面,下面全都是多孔区域(孔隙率0.73),然后我产生的液相分布是这样的~ 几乎没有纯气体区域~甚至在固液界面处的液相含量反而高~我已经调过不同的毛细力模型,发现不是毛细力的影响~
    现在还可以做的是增大相变系数~但是我相变系数一增大,就会在开始相变的时候发散~
    有没有老师可以分析一下 可能是哪里导致的问题~
    solvers
        "alpha.liquid.*"
            cAlpha          1;
            nAlphaCorr      2;
            nAlphaSubCycles 2;
            MULESCorr       yes;
            nLimiterIter    5;
            solver          smoothSolver;
            tolerance       1e-7;
            relTol          0;
        rho
            solver           diagonal;
            tolerance        1e-7;
            relTol           0.1;
        rhoFinal
            $rho;
            tolerance        1e-7;
            relTol           0;
        mDotSmearFinal
            solver           PCG;
            tolerance        1e-7;
            preconditioner   DIC;
            relTol           0.00;
            smoother         DIC;
        "(U|T)"
            smoother         symGaussSeidel;
            tolerance        1e-7;
            relTol           0.;
            minIter          15;
            maxIter          50;
        "(U|T)Final"
            $U;
            tolerance        1e-7;
            relTol           0;
            maxIter          50;
        p
            tolerance        1e-8;
            solver           PCG;
            preconditioner   DIC;
            relTol           0.001;
            smoother         DIC;
        pFinal
            $p;
            tolerance       1e-07;
            relTol          0;
        "pcorr.*"
            $p_rgh;
            tolerance        1e-9;
            relTol           0;
    PIMPLE
        momentumPredictor   yes;
        nCorrectors         5;
        nNonOrthogonalCorrectors 0;
        pRefCell            0;
        pRefValue           1e5;
    relaxationFactors
        alpha.liquid   0.2;
        U              0.5;
        p              0.5;
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    divSchemes
        div(phi,alpha)  Gauss vanLeer01;
        div(phirb,alpha) Gauss vanLeer01;
        //div(phirb,alpha) Gauss interfaceCompression;
        //div(rhoPhi,U)      Gauss vanLeerV;
        //div(rhoPhi,U)      Gauss limitedLinearV 1;
        div(rhoPhi,U)      Gauss linearUpwind;
        div(rhoPhiByEps,U)  Gauss linearUpwind;
        div((mu*dev2(grad(U).T()))) Gauss linear;
        div(((rho*nu)*dev2(T(grad(U))))) Gauss linear;
        div(rhoCpPhi,T) Gauss vanLeer;
        div((interpolate(cp)*rhoPhi),T) Gauss vanLeer;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
