  3. 编译体积力时遇到的小报错
编译体积力时遇到的小报错
1 帖子 1 发布者 1.1k 浏览
  • J 离线
    J 离线
    Joann
    在学习用openfoam做自航的时候想尝试用体积力模型替代桨模型产生的推力,这需要引入体积力模型。
    在编译时有遇到一点小问题,关于未定义引用,请问要怎么正确引用,解决这个报错提示使得编译成功?
    首先这是wmake出现的提示:
    /usr/bin/ld.bfd: /home/dyfluid/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/waveProp/waveProp.o: in function `main.cold':
    waveProp.C:(.text.unlikely+0x49d): undefined reference to `Foam::functionObjects::forces::~forces()'
    /usr/bin/ld.bfd: /home/dyfluid/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/applications/solvers/multiphase/waveProp/waveProp.o: in function `main':
    waveProp.C:(.text.startup+0x8bc9): undefined reference to `Foam::functionObjects::forces::forces(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&)'
    /usr/bin/ld.bfd: waveProp.C:(.text.startup+0x8bed): undefined reference to `Foam::functionObjects::forces::calcForcesMoment()'
    /usr/bin/ld.bfd: waveProp.C:(.text.startup+0x8bfc): undefined reference to `Foam::functionObjects::forces::forceEff() const'
    /usr/bin/ld.bfd: waveProp.C:(.text.startup+0xa444): undefined reference to `Foam::functionObjects::forces::~forces()'
    make: *** [/home/dyfluid/OpenFOAM/OpenFOAM-7/wmake/makefiles/general:142: /home/dyfluid/OpenFOAM/OpenFOAM-7/platforms/linux64GccDPInt32Opt/bin/waveProp] Error 1
    对应文件bodyForce.H中定义体积力的部分:
    // Define the (cylindrical) region for the body force from dictionary values
    const scalar yProp (readScalar(bodyForceDict.lookup("yProp")));
    const scalar zProp (readScalar(bodyForceDict.lookup("zProp")));
    const scalar xPropmin (readScalar(bodyForceDict.lookup("xPropmin")));
    const scalar xPropmax (readScalar(bodyForceDict.lookup("xPropmax")));
    const scalar tipRadius (readScalar(bodyForceDict.lookup("tipRadius")));
    const scalar hubRadius (readScalar(bodyForceDict.lookup("hubRadius")));
    Foam::functionObjects::forces F
       "forces",
        mesh,
        dragForceDict
    F.calcForcesMoment();//这里未定义引用,该如何修改?
    vector force =F.forceEff();//这里未定义引用,该如何修改?
    scalar drag = force.x();//这里未定义,该如何修改?
    Info << "Thrust = " << drag << endl;
    scalar thrust = 1.1*drag; //Considering 10% more
    Hello, CFD. Hello, OpenFOAM.
