  2. CFD彩虹条
  3. [招生贴] Two PhD at UMass Lowell, Fluid Dynamics and Machine Learning
已定时 已固定 已锁定 已移动 CFD彩虹条
2 帖子 2 发布者 1.9k 浏览
    zlwei
    Two new Ph.D. positions (2022-2023) are available for the Department of Biomedical Engineering at the University of Massachusetts Lowell. The stipend is ~$31200, and the tuition is fully covered.
    ML+FD Ph.D. Position:
    The research will involve the applications of fluid dynamics and machine learning.
    Qualifications:
    • a Bachelor's or equivalent degree in engineering (Computer, Mechanical, Biomedical, and Aerospace), applied mathematics, or related fields. Applicants with a master's degree are preferred.
    • Previous research experience is highly desirable but not required. Desirable research skills include
    o computational or experimental modeling technique in fluid dynamics
    o fluid-structure interaction
    o programming (C, C++, or Python).
    • Strong oral and written communication skills.
    Review of applications will begin immediately. Interested students should send a single PDF containing the following items to ZhenglunAlan_Wei@uml.edu with a "Ph.D. Application (ML+FD)" in the subject line.
    • Curriculum Vitae
    • Personal statement (including research interests and availability)
    • Unofficial transcript(s)
    ML+Cardio Ph.D. Position:
    The research will involve machine learning applications in machine learning, medical image processing, and preventative cardiology.
    Qualifications:
    • Previous research experience is highly desirable. Desirable research skills include machine learning and programming (C, C++, or Python).
    Review of applications will begin immediately. Interested students should send a single PDF containing the following items to ZhenglunAlan_Wei@uml.edu with a "Ph.D. Application (ML+Cardio)" in the subject line.
    • Curriculum Vitae
    • Contact information for three references
    any official links?
