  3. 简单算例超算计算报错
简单算例超算计算报错
3 帖子 2 发布者 2.3k 浏览
  • 微 离线
    微 离线
    微凉风
    各位朋友大家好,最近我在用学校的超算算一个简单的Case,但是提交作业以后总是会报错,而在自己电脑上运行相同的命令则可以正常计算。算例是图片中的效果,然后提交的作业命令在第二张图。运行后会出现这个错误,有朋友可以帮忙看一下是哪里的环境设置出了问题吗?
    [1] --> FOAM FATAL IO ERROR:
    [1] Cannot find patchField entry for procBoundary1to0
    [1]
    [1] file: /lustre/home/acct-mectl/mectl-stu2/thk/test-thk/fluid-openfoam/processor1/0/pointDisplacement.boundaryField from line [4]
    [4]
    [4] --> FOAM FATAL IO ERROR:
    [2] Cannot find patchField entry for procBoundary2to1
    [2]
    [2] file: /lustre/home/acct-mectl/mectl-stu2/thk/test-thk/fluid-openfoam/processor2/0/pointDisplacement.boundaryField from line 17 to line 53.
    [5]
    [5] --> FOAM FATAL IO ERROR:
    [5] Cannot find patchField entry for procBoundary5to2
    [5]
    [5] file: /lustre/home/acct-mectl/mectl-stu2/thk/test-thk/fluid-openfoam/processor5/0/pointDisplacement.boundaryField from line 17 to line 53.
    [5]
    [4] Cannot find patchField entry for procBoundary4to1
    [4]
    [4] file: /lustre/home/acct-mectl/mectl-stu2/thk/test-thk/fluid-openfoam/processor4/0/pointDisplacement.boundaryField from line 17 to line 53.
    [4]
    [4] From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>; PatchField = Foam::pointPatchField; GeoMesh = Foam::pointMesh]
    [4] in file /tmp/rpm/spack-stage-openfoam-org-7-hf7fehnzmia4muicuqvlcaki7y2iqx2x/OpenFOAM-7/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 191.
    [4]
    FOAM parallel run exiting
    MPI_ABORT was invoked on rank 2 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
    with errorcode 1.
    NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
    You may or may not see output from other processes, depending on
    exactly when Open MPI kills them.
    是不是个人计算机上的 OpenFOAM 和超算上的不一样?
    或者MPI库版本不一样?MPI库可以不大,可以在家目录编译一份自用版本的
    微 1 条回复 最后回复
  • 微 离线
    微 离线
    微凉风
    @bestucan 谢谢前辈,版本是一样的,后来和学校超算人员联系发现是少了一个环境配置加载:module load gcc/7.4.4,加上以后就可以了
