  3. 求助贴:湍流计算遇到一个小问题,求指教
求助贴:湍流计算遇到一个小问题,求指教
3 帖子 2 发布者 2.9k 浏览
    wh3296
    网格划分好了之后,计算报错。貌似是wall边界条件的问题?还是湍流模型的问题呢?
    哪位大佬可以点拨一下,不胜感激!
    Reading transportProperties
    [8]
    [8]
    [8] --> FOAM FATAL IO ERROR:
    [8] Entry 'method' not found in dictionary "IOstream.wallDist"
    [8]
    [8]
    [8] file: IOstream.wallDist
    [8]
    [8]     From function bool Foam::dictionary::readEntry(const Foam::word&, T&, Foam::keyType::option, bool) const [with T = Foam::word]
    [8]     in file /home/b408/OpenFOAM/OpenFOAM-v1912/src/OpenFOAM/lnInclude/dictionaryTemplates.C at line 334.
    [8]
    FOAM parallel run exiting
    fvScheme里面加上
    wallDist
        method meshWave;
    wh3296
    @李东岳 解决了,谢谢!
