  4. decomposePar运行时出现问题
decomposePar运行时出现问题
8 帖子 6 发布者 11.7k 浏览
    Aeronastro
    不知道有没有哪位遇到过这样的情况,我在decomposePar的时候,出现这样的错误提示:
    Processor 0: field transfer
    terminate called after throwing an instance of 'std::logic_error'
    _what(): basic_string::_S_consturct null not valid
    入口边界条件是我自己定义的,功能是读取一个文件数据,进行运算之后赋值给这个边界条件的私有变量。我用的是simple分块,不破坏这个入口。哪里出错了呢可以给点建议吗?
    PS:单核验证可以计算
    Aeronastro
    可能我描述的问题不够准确,下面附上我的部分代码:
    在.H文件中,定义了一些私有变量与私有变量的接口:
    // private perameters
      //- freestream Ma
            scalar Ma_;
            //- freestream T
            scalar Tinf_;
            scalar gamma_;
            scalar Prt_;
            //- munber of modes
            scalar nmodes_;
            //- smallest wavenumber
            scalar dxmin_;
            //- ratio of ke and kmin (in wavenumber)
            scalar wew1fct_;
            scalar amp_;
            //- kinetic viscosity of the smallest eddy
            scalar visc_;
            //- delta Inlet
            scalar deltaInlet_;
            //- freestream Velocity
            scalar Uinf_;
            //- freestream pressure
            scalar pInf_;
            //- read file
            IFstream IF_;
            //- rows of file data
            label ny_;
            //- MeanField
            vectorField Ubar_;
            //- primeField
            vectorField UPrime_;
            //- ReynoldStress tensor
            symmTensorField  ReynoldStress_;
            label curTimeIndex_;
            // member function
            void calculateProfiles(IFstream&, vectorField&, symmTensorField&, scalar&);
    // Access
    	    scalar nmodes() const
    	    	return nmodes_;
    	    scalar deltaInlet() const
    	    	return deltaInlet_;
    	    scalar& deltaInlet()
    	    	return deltaInlet_;
    	    scalar amp() const
    	    	return amp_;
    	    scalar dxmin() const
    	    	return dxmin_;
    	    scalar visc() const
    	    	return visc_;
    	    scalar wew1fct() const
    	    	return wew1fct_;
    	    scalar Ma() const
    	    	return Ma_;
    	    scalar Tinf() const
    	    	return Tinf_;
    	    scalar gamma() const
    	    	return gamma_;
    	    scalar Prt() const
    	    	return Prt_;
    	    scalar Uinf() const
    	    	return Uinf_;
    	    scalar pInf() const
    	    	return pInf_;
    	    IFstream IF() const
    	    	return IF_;
    	    IFstream& IF()
    	    	return IF_;
    	    vectorField& Ubar()
    	    	return Ubar_;
    	    vectorField Ubar() const
    	    	return Ubar_;
    	    symmTensorField& ReynoldStress()
    	    	return ReynoldStress_;
    	    symmTensorField ReynoldStress() const
    	    label ny()
    	    	return ny_;
    然后在.C中,我的构造函数:
    // constrctor
    Foam::syntheticVelocityFixedValueFvPatchField::syntheticVelocityFixedValueFvPatchField
        const fvPatch& p,
        const DimensionedField<vector, volMesh>& iF,
        const dictionary& dict
        fixedValueFvPatchVectorField(p, iF),
        Ma_(readScalar(dict.lookup("Ma"))),
        Tinf_(readScalar(dict.lookup("Tinf"))),
        gamma_(dict.lookupOrDefault("gamma", 1.4)),
        Prt_(dict.lookupOrDefault("Prt", 0.9)),
        nmodes_(readScalar(dict.lookup("nmodes"))),
        dxmin_(readScalar(dict.lookup("dxmin"))),
        wew1fct_(dict.lookupOrDefault("wew1fct", 2.0)),
        amp_(dict.lookupOrDefault("amp", 1.452762113)),
        visc_(dict.lookupOrDefault("visc", 15.2e-6)),
        Uinf_(readScalar(dict.lookup("Uinf"))),
        pInf_(readScalar(dict.lookup("pInf"))),
        IF_(dict.lookup("pathName")),	// stored meanStreamVelocity and ReynoldStress profile data
        ny_(dict.lookupOrDefault("ny", 535)),
        curTimeIndex_(-1)
        if (dict.found("Ubar") && dict.found("ReynoldStress") && dict.found("deltaInlet"))
        	deltaInlet_= scalar(readScalar(dict.lookup("deltaInlet")));
        	Ubar_ = vectorField("Ubar", dict, p.size());
        	ReynoldStress_ = symmTensorField("ReynoldStress", dict, p.size());
        else
        	calculateProfiles(IF(), Ubar(), ReynoldStress(), deltaInlet());
        if (dict.found("UPrime"))
        	UPrime_ = vectorField("UPrime", dict, p.size());
        else
        	UPrime_ = vectorField(p.size(), vector::zero);
        if (dict.found("value"))
            fvPatchField<vector>::operator=
                vectorField("value", dict, p.size())
        else
            fvPatchField<vector>::operator=(Ubar());
    这里调用的成员函数calculateProperties如下:
    // member function
    void Foam::syntheticVelocityFixedValueFvPatchField::calculateProfiles
        IFstream& IF,
        vectorField& Ubar,
        symmTensorField& ReynoldStress,
        scalar& deltaInlet
        if (!IF)
        	FatalErrorIn("void Foam::syntheticVelocityFixedValueFvPatchField::calculateMeanVelocity")
        	 << "can not find " << IF.name() << exit(FatalError);
        else
        	scalarField UvdPlus(ny()), vPlus(ny()), wPlus(ny()), Ux(ny()), Uy(ny()), Uz(ny());
        	symmTensorField stressPlus(ny(), symmTensor::zero);
        	scalarField yPlus(ny()), y(ny());
        	scalar yInf, ySup;
        	scalar R(287.0), max_UvdPlus(26.457427), As(1.512e-06), Ts(120.0);
        	scalar r=pow(Prt(), 1.0/3.0);
        	//- calculate nuwInlet and Utao
        	scalar Taw = Tinf()*(1.0+(gamma()-1.0)/2.0*r*sqr(Ma()));
        	scalar Tw = (Taw - Tinf())/r + Tinf();
        	scalar rhow = pInf()/(R*Tw);
        	scalar muw = As*sqrt(Tw)/(1.0+Ts/Tw);
        	scalar nuwInlet = muw/rhow;
        	scalar A = sqrt((gamma()-1.0)/2.0*Prt()*sqr(Ma())*Tinf()/Tw);
        	scalar B = (1.0+sqrt(Prt())*(gamma()-1.0)/2.0*sqr(Ma()))*Tinf()/Tw - 1.0;
        	scalar Utao = Uinf()/A*(
        	                           asin((2.0*sqr(A)-B)/sqrt(sqr(B)+4.0*sqr(A)))
        	                         + asin(B/sqrt(sqr(B)+4.0*sqr(A)))
        	                       )/max_UvdPlus;	// max(Uvd+) = 25.6803733;
        	const scalarField T = this->patch().lookupPatchField<volScalarField, scalar>("T");
        	//- flag to decide whether to calculate deltaInlet
        	bool delta=true;
        	forAll(UvdPlus, patchI)
        	    IF >> yPlus[patchI] >> UvdPlus[patchI] >> vPlus[patchI] >> wPlus[patchI]
        	       >> stressPlus[patchI].xx() >> stressPlus[patchI].yy() >> stressPlus[patchI].zz() >> stressPlus[patchI].xy();
        	    // calculate dimensional y
        	    y[patchI] = yPlus[patchI]*nuwInlet/Utao;
        	    // calculate dimensional Ux
        	    scalar tmp = A*(UvdPlus[patchI]*Utao)/Uinf() - asin(B/sqrt(sqr(B)+4.0*sqr(A)));
        	    Ux[patchI] = (sin(tmp)*sqrt(sqr(B)+4.0*sqr(A)) + B)/(2.0*sqr(A))*Uinf();
        	    Uy[patchI] = vPlus[patchI]*Utao;
        	    Uz[patchI] = wPlus[patchI]*Utao;
        	    if (Ux[patchI] > 0.99*Uinf() && delta)
        	    	deltaInlet = y[patchI];
        	    	delta = false;	// deltaInlet calculated only once;
        	vectorField Cf = this->patch().Cf();
        	Ubar = vectorField(Cf.size());
        	symmTensorField Reynold(Cf.size(), symmTensor::zero);
        	ReynoldStress = symmTensorField(Cf.size(), symmTensor::zero);
        	// interpolate at the cell
        	forAll(Cf, faceI)
        	    for(label patchI=0; patchI < y.size()-1; patchI++)
        	    	yInf = Cf[faceI][1]-y[patchI];
        	    	ySup = Cf[faceI][1]-y[patchI+1];
        	    	if(yInf*ySup <= 0)
        	    	    Ubar[faceI][0] = yInf/(yInf-ySup)*Ux[patchI+1] - ySup/(yInf-ySup)*Ux[patchI];
        	    	    Ubar[faceI][1] = yInf/(yInf-ySup)*Uy[patchI+1] - ySup/(yInf-ySup)*Uy[patchI];
        	    	    Ubar[faceI][2] = yInf/(yInf-ySup)*Uz[patchI+1] - ySup/(yInf-ySup)*Uz[patchI];
        	    	    Reynold[faceI] = yInf/(yInf-ySup)*stressPlus[patchI+1] - ySup/(yInf-ySup)*stressPlus[patchI];
        	    	    // calculate dimensional Reynold stress
        	    	    scalar ksi = sqrt(Tw/T[faceI]);
        	    	    ReynoldStress[faceI].xx() = sqr(Reynold[faceI].xx()/ksi)*Utao;
        	    	    ReynoldStress[faceI].xy() = -sqr(Reynold[faceI].xy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].yy() = sqr(Reynold[faceI].yy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].zz() = sqr(Reynold[faceI].zz()/ksi)*Utao;
        	    	    break;
        	    	else	// Cf.component(1) is higher than y.last()
        	    	    Ubar[faceI][0] = Ux.last();
        	    	    Ubar[faceI][1] = Uy.last();
        	    	    Ubar[faceI][2] = Uz.last();
        	    	    ReynoldStress[faceI].xx() = sqr(stressPlus.last().xx()/ksi)*Utao;
        	    	    ReynoldStress[faceI].xy() = -sqr(stressPlus.last().xy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].yy() = sqr(stressPlus.last().yy()/ksi)*Utao;
        	    	    ReynoldStress[faceI].zz() = sqr(stressPlus.last().zz()/ksi)*Utao;
        	scalar ymin = min(Cf.component(1));
        	scalar Uxmin = min(Ubar.component(0));
        	scalar dUxdy = Uxmin/ymin;
        	scalar dUdy = sqr(Utao)/nuwInlet;
        	Info << "dUxdy (from case simulation)	=" << dUxdy << nl
        	     << "dUdy (from theory calculation)	=" << dUdy << nl
        	     << "Utao				=" << Utao << nl
        	     << "nuwInlet			=" << nuwInlet << nl
        	     << "deltaInlet			=" << deltaInlet << endl;
    我在单核下测试时时可以计算的,但是想并行计算的时候,decomposePar过不去,终端输出信息如下:
    |  \\    /   O peration     | Version:  2.4.0                                 |
    Build  : 2.4.0-dcea1e13ff76
    Exec   : decomposePar
    Date   : Nov 13 2016
    Time   : 10:59:43
    Host   : "zwk"
    PID    : 12485
    Case   : /home/Ubuntu/WORKPLACE4/SyntheticCase-test
    nProcs : 1
    Create time
    Decomposing mesh region0
    Create mesh
    Calculating distribution of cells
    Selecting decompositionMethod simple
    Finished decomposition in 0.04 s
    Calculating original mesh data
    Distributing cells to processors
    Distributing faces to processors
    Distributing points to processors
    Constructing processor meshes
    Processor 0
        Number of cells = 23686
        Number of faces shared with processor 1 = 1997
        Number of faces shared with processor 1 = 58
        Number of processor patches = 2
        Number of processor faces = 2055
        Number of boundary faces = 4243
    Processor 1
        Number of faces shared with processor 0 = 1997
        Number of faces shared with processor 0 = 58
        Number of faces shared with processor 2 = 1978
        Number of faces shared with processor 2 = 52
        Number of processor patches = 4
        Number of processor faces = 4085
        Number of boundary faces = 2189
    Processor 2
        Number of faces shared with processor 1 = 1978
        Number of faces shared with processor 1 = 52
        Number of faces shared with processor 3 = 1954
        Number of faces shared with processor 3 = 11
        Number of processor faces = 3995
        Number of boundary faces = 2329
    Processor 3
        Number of faces shared with processor 2 = 1954
        Number of faces shared with processor 2 = 11
        Number of faces shared with processor 4 = 1992
        Number of faces shared with processor 4 = 57
        Number of processor faces = 4014
        Number of boundary faces = 2276
    Processor 4
        Number of faces shared with processor 3 = 1992
        Number of faces shared with processor 3 = 57
        Number of faces shared with processor 5 = 1964
        Number of faces shared with processor 5 = 43
        Number of processor faces = 4056
        Number of boundary faces = 2208
    Processor 5
        Number of faces shared with processor 4 = 1964
        Number of faces shared with processor 4 = 43
        Number of faces shared with processor 6 = 1984
        Number of faces shared with processor 6 = 41
        Number of processor faces = 4032
        Number of boundary faces = 2330
    Processor 6
        Number of cells = 23685
        Number of faces shared with processor 5 = 1984
        Number of faces shared with processor 5 = 41
        Number of faces shared with processor 7 = 1986
        Number of faces shared with processor 7 = 55
        Number of processor faces = 4066
        Number of boundary faces = 2218
    Processor 7
        Number of faces shared with processor 6 = 1986
        Number of faces shared with processor 6 = 55
        Number of processor faces = 2041
        Number of boundary faces = 4211
    Number of processor faces = 14172
    Max number of cells = 23686 (0.00105549% above average 23685.8)
    Max number of processor patches = 4 (14.2857% above average 3.5)
    Max number of faces between processors = 4085 (15.2978% above average 3543)
    Time = 0
    dUxdy (from case simulation)	=2.46405e+06
    dUdy (from theory calculation)	=2.46471e+06
    Utao				=23.1659
    nuwInlet			=0.000217736
    deltaInlet			=0.0144036
      what():  basic_string::_S_construct null not valid
    还麻烦各位可以给个意见,这个问题就是这个边条造成的,但不知道如何解决,谢谢各位了
    忒复杂了..爱莫能助啊:crying:
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    wwzhao 超神
    在 中回复了 Aeronastro 最后由 编辑
    @Aeronastro 粗略看了一下,感觉问题出在IF_上。你的 dict 能贴上来吗?
    A 1 条回复 最后回复
    Aeronastro
    在 中回复了 wwzhao 最后由 编辑
    @wwzhao 好的,这个是我速度入口的边界条件
    boundaryField
        inlet
            type        syntheticVelocity;
            Ma          2.3;
            Tinf        104;
            Prt         0.9;
            nmodes      200;
            dxmin       0.01e-03;
            Uinf        552;
            pInf        3998.63;
            pathName    "/home/Ubuntu/WORKPLACE4/syntheticCase-test/data";
            value       uniform (552 0 0);
       other boundaries ......
    由于刚开始计算的时候不知道Ubar,ReynoldStress和deltaInlet,在边条构造时需要通过那个calculateProfiles函数计算。
    其中的data文件中的数据是一列一列排布的,
    0_1479171527178_data
    Haining LUO
    这个情况我倒是没有遇到过,不过我编了个synthetic的湍流生成条件,核比较少的时候patch像是一个完整的剖面,而decomposePar之后(没有遇到你这个问题)而且核数特别高(~500)之后,发现patch也被分割了的感觉。。我想说的是核数少的时候(~30)根本没发现patch上面会被不同的processor分割。
    有一个计算圆形(是的,我的BC仅仅适用于圆形)中心的程序,我想不同processor算出来的ctr不同!
        // Get range and orientation
        boundBox bb(patch().patch().localPoints(), true);
        vector ctr = 0.5*(bb.max() + bb.min());
    看来得定义一个常量才稳妥
  • D 离线
    D 离线
    D.Benjamin
    你好,我想请问,你怎么上传这些可以滑动的页面呀?
    OpenFOAM初学者,希望和大家共同交流
    不想patch被分割,可以用这个:?
    preservePatches (xxx xxx)
    @D-Benjamin
    这是代码高亮,大片大片的代码用esc下面那个,前面点击三次,后面点击三次,把代码包围起来,你可以试试下面这个(分为三行)
    ``` 代码```
