  4. rhoCentralFoam求解器的问题
10 帖子 8 发布者 18.6k 浏览
  • V 离线
    V 离线
    vivian
    写于 最后由 CFD中文网 编辑
    最近在看rhoCentralFoam求解器,有一些问题,请教各位:
    在使用openfoam中rhoCentralFoam求解器时,我参照其中的例子结合自身算例,给定了边界条件及初始值,在计算4000步后,出现如下错误:
    --> FOAM FATAL ERROR:
    Maximum number of iterations exceeded
        From function Foam::scalar Foam::species::thermo<Thermo, Type>::T(Foam::scalar, Foam::scalar, Foam::scalar, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar, Foam::scalar) const, Foam::scalar (Foam::species::thermo<Thermo, Type>::*)(Foam::scalar) const) const [with Thermo = Foam::hConstThermo<Foam::perfectGas<Foam::specie> >; Type = Foam::sensibleInternalEnergy; Foam::scalar = double; Foam::species::thermo<Thermo, Type> = Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>]
        in file /home/liyue/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H at line 66.
    FOAM aborting
    #0  Foam::error::printStack(Foam::Ostream&) at ~/OpenFOAM/OpenFOAM-3.0.1/src/OSspecific/POSIX/printStack.C:218
    #1  Foam::error::abort() at ~/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/error.C:249
    #2  Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/OpenFOAM/OpenFOAM-3.0.1/src/OpenFOAM/lnInclude/errorManip.H:85 (discriminator 4)
    #3  Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::T(double, double, double, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::*)(double, double) const, double (Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::*)(double) const) const at ~/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H:66
    #4  Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::TEs(double, double, double) const at ~/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H:425
    #5  Foam::sensibleInternalEnergy<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> >::THE(Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> const&, double, double, double) const at ~/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/sensibleInternalEnergy.H:126
    #6  Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy>::THE(double, double, double) const at ~/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/specie/lnInclude/thermoI.H:365
    #7  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::calculate() at ~/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/basic/psiThermo/hePsiThermo.C:46 (discriminator 2)
    #8  Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::constTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleInternalEnergy> > > >::correct() at ~/OpenFOAM/OpenFOAM-3.0.1/src/thermophysicalModels/basic/psiThermo/hePsiThermo.C:143
    #9  ? at ~/OpenFOAM/OpenFOAM-3.0.1/applications/solvers/compressible/rhoCentralFoam/rhoCentralFoam.C:232
    #10  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #11  ? at ??:?
    Aborted (core dumped)
    结合前面求解e方程残差无变化,我分析,这是由于e的求解修正出现了错误,为查找错误来源,我想在rhoCentralFoam的求解器中加断点,看求解过程中的数值传递与变化。
    于是,我采用了debug模式在rhoCentralFoam.C的215行加入断点,想输出e,结果屏幕输出了大量信息,我应该如何输出才能得到想要的场信息呢?
    1. 如果我想梳理出程序运行的主线,搞清楚从场的离散点到通过离散方法,获得最终求解的代数方程矩阵,我认为最好的办法是从建立场开始,关注场中存储的离散点的信息变化。那么请问如何输出存储点压力,面通量信息的矩阵呢?
    在 中回复了 vivian 最后由 编辑
    @vivian
    错误显示迭代步数超出了。
    e是个场,你要输出场的话,就会输出所有的场的值,不清楚你要看什么,也可以单独输出场的最大值最小值看看越界否。如果一定要查看整个场的信息,输出到log再看,这样log文件会变得很大。
    rhoCentralFoam &> log
    从离散的矩阵系数如fvScalarMatrix组建我们常规的稀疏矩阵不是一俩行代码可以搞定(估计不到100行?)因为openfoam里面存储的是稀疏矩阵,并用指针+指针。所以,可能得用点时间。
    更简单的方法,是回到问题本身,很少是因为矩阵系统解不出来的原因,而是设置有问题导致发散。
    CFD中国标准用户测试帐号
    目前由徐笑笑登录
    WayneW 1 条回复 最后回复
  • WayneW 离线
    WayneW 离线
    Wayne
    在 中回复了 CFD中文网 最后由 编辑
    @cfd-china 厉害了我的哥
    主要做AI,懂一点CFD
  • V 离线
    V 离线
    vivian
    写于 最后由 CFD中文网 编辑
    谢谢您的回复!:big_mouth:
    结合tutorial中wedge15的算例,我的模拟模型为马赫数2的压缩拐角流动。入口设置了速度边界,出口为超声速出口。采用k-epsilon湍流模型,所需k,epsilon值根据经验公式给出。
    压力场设定为:
    internalField   uniform 100000;
    boundaryField
        INLET
            type            inletOutlet;
            inletValue      uniform 101325;
            value           uniform 101325;
        OUTLET
            type            waveTransmissive;
            field           p;
            phi             phi;
            rho             rho;
            psi             thermo:psi;
            gamma           1.3;
            fieldInf        100000;
            lInf            1;
            value           uniform 100000;
        BOTTOM
            type            zeroGradient;
        TOP
            type            zeroGradient;
        frontAndBackPlanes
            type            empty;
    速度设定为:
    internalField   uniform (600 0 0);
    boundaryField
        INLET
            type            supersonicFreestream;
            pInf            100000;
            TInf            300;
            UInf            (600 0 0);
            gamma           1.4;
            value           uniform (662 0 0);
        OUTLET
            type            inletOutlet;
            inletValue      uniform (662 0 0);
        BOTTOM
            type            zeroGradient;
        TOP
        frontAndBackPlanes
            type            empty;
    温度场设置为:
    internalField   uniform 300;
    boundaryField
        INLET
            type            inletOutlet;
            inletValue      uniform 300;
            value           uniform 300;
        OUTLET
            type            inletOutlet;
            value           uniform 300;
        BOTTOM
            type            zeroGradient;
        TOP
        frontAndBackPlanes
            type            empty;
    求解器的设置是根据相似算例给出,这个的设置有什么原则吗?我设置的如下,还请多多指点:
    solvers
        "rho.*"
            solver          diagonal;
        "p.*"
            solver          PBiCG;
            preconditioner  DILU;
            tolerance       1e-12;
            relTol          0;
        "(U|e).*"
            $p;
            tolerance       1e-9;
        "(nuTilda).*"
            $p;
            tolerance       1e-10;
    PIMPLE
        nOuterCorrectors 1;
        nCorrectors      2;
        nNonOrthogonalCorrectors 0;
    Q1:不知道我这样设置边界条件是否合理哪?
    Q2:求解器的选择应该如何设置呢,有什么选择原则,请问有什么资料推荐码?
    Q3:在外部参数设置找不出差错,又有发散产生时,请问如何debug呢?
    Z R 2 条回复 最后回复
    liailei0627
    你好,出现了跟你一样的问题,用rhoCentralFoam LES,请问问题解决了吗,可否指教下思路。
    宝 1 条回复 最后回复
    zhangdong
    不知道大家有没有关注过thermophysicalProperties里面的设置。rhoCentralFoam 的wedge15的算例里面的mu设置为零。如果马赫数为2的时候,设置了湍流,那么thermophysicalProperties相关项也要发生变化。mu应该不是零,并且要随温度场发生变化。这种情况下rhoCentralFoam是否还合适不好说。我在sonicFoam里面看到有考虑湍流的,给出的入口速度是600。如果改为sonicFoam求解一下试试呢?
    吴 1 条回复 最后回复
  • 吴 离线
    吴 离线
    吴优
    在 中回复了 zhangdong 最后由 编辑
    @zhangdong 如果mu随温度变化,transport就不选const而是sutherland,然后在transport中规定As,Ts取值
  • 宝 离线
    宝 离线
    宝丁
    在 中回复了 liailei0627 最后由 编辑
    @liailei0627 +1
    zhangdong
    @vivian 您能贴出thermoProperties的设置吗?我用OpenFOAM-6,rhoCentralFoam的tutorial里面wedge15Ma5的算例是马赫数5,该算例通过设置transport中Cp的选项,使得声速是1(https://openfoam.com/documentation/tutorial-guide/tutorialse6.php),所以入口速度设置的是5,不知您是否把thermoProperties更改过来了?
    另外,我用sonicFoam计算圆柱扰流,分别在Ma=1, Ma=3的情况下,进行计算,Re=1.0e+6,采用k-epsilon模型,可以计算。
  • R 离线
    R 离线
    Rachel0096
    @vivian 我也遇到了一样的问题,请问您的问题解决了吗,可以指点一下吗?
