  3. 管式填充床中两相流的模拟中,循环边界压力梯度、分散相含率运算出错的问题
5 帖子 2 发布者 3.3k 浏览
    Caijinjin
    最近在做管式填充床中两相流动的模拟,采用循环边界cyclicAMI达到缩短管长,减少网格的目的。网格使用snappyHexMesh画完后没有问题,动力源项给的是连续项平均速度Ubar,为0.03m/s,填充床几何为
    运算时出现如下结果:
    主要就是动力源计算的压力梯度一直在正负之间反复跳动,且数值非常大,压力P_rgh的迭代次数会超限。运算一段时间后会直接导致求解的相分数远远超出0-1的范围,如下图所示:
    想请教一下对这种循环边界熟悉的老师同学,能够解答一下我这些问题。
    另外附上我的fvSolution:
    solvers
        "alpha.*"
            nAlphaCorr      1;
            nAlphaSubCycles 3;
            implicitPhasePressure yes;
            solver          smoothSolver;
            tolerance       1e-8;
            relTol          0;
            minIter         1;
        p_rgh
            solver          PCG;
            preconditioner  FDIC;
            tolerance       1e-6;
            relTol          0.01;
        p_rghFinal
            $p_rgh;
            tolerance       1e-6;
            relTol          0;
        "U."
            tolerance       1e-7;
            relTol          0;
            minIter         1;
        "(e|h).*"
            tolerance       1;
            relTol          0;
            minIter         0;
            maxIter         0;
        "(k|epsilon|omega).*"
            tolerance       1e-7;
            relTol          0;
            minIter         1;
    PIMPLE
        nOuterCorrectors    3;
        nCorrectors         2;
        nNonOrthogonalCorrectors 1;
        pRefPoint (0.10399 0 0);
        pRefValue 101325;
    relaxationFactors
        equations
            ".*"            0.7;
    fvSchemes:
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
        limited         cellLimited Gauss linear 1;
    divSchemes
        default                         none;
        "div\(phi,alpha.*\)"            Gauss vanLeer;
        "div\(phir,alpha.*\)"           Gauss vanLeer;
        "div\(alphaRhoPhi.*,U.*\)"      Gauss linearUpwind limited;
        "div\(phi.*,U.*\)"              Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,(h|e).*\)"        Gauss linearUpwind limited;
        "div\(alphaPhi.*,f.*\)"         Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,K.*\)"      Gauss linearUpwind limited;
        "div\(alphaPhi.*,p\)"           Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,\(p\|thermo:rho.*\)\)"     Gauss linearUpwind limited;
        "div\(alphaRhoPhi.*,(k|epsilon|omega).*\)"      Gauss linearUpwind limited;
        "div\(\(\(\(alpha.*\*thermo:rho.*\)\*nuEff.*\)\*dev2\(T\(grad\(U.*\)\)\)\)\)"  Gauss linear;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    fluxRequired
        default         no;
    wallDist
        method          meshWave;
        nRequired       yes;
    你这个看起来不太好收敛。你有没有尝试单向流,压力梯度有震荡么
    Caijinjin
    单相流我还没尝试过,之前用过空的圆管做过一样的案例,问题都解决了。
    现在我这边入口fixedValue,mapped边界条件都能是正常运行,就cyclicAMI出现问题,所以我打算先看看mapped的结果。
    在 中回复了 Caijinjin 最后由 编辑
    meanVelocity这面有个phaseMeanVelocity,可用于多相流,不过不确定是否有用。
    Caijinjin
    @李东岳 好的,李老师,我去调试看看
