  3. 请问有并行debug的工具吗?
请问有并行debug的工具吗?
4 帖子 2 发布者 3.2k 浏览
    CFDngu
    写于 最后由 CFDngu 编辑
    一直用gdb调试程序,但却不会并行调试。最近写的代码单核运行没问题了,但并行运行有问题,应该是不同processor交界面处出现问题。之前对并行这方面涉及不多,对并行编程思想认识不直观,故想尝试并行调试。
    我在openWiki上看到一个mpirunDebug文件(文件如下),但是不会用。求大佬指点一二,或者有什么好用的并行debug工具推荐一下?:xiexie:
    #!/bin/sh
    # Driver script to run mpi jobs with the processes in separate
    # windows or to separate log files.
    # Requires bash on all processors.
    PROGNAME=`basename $0`
    PROGDIR=`dirname $0`
    if [ `uname -s` = 'Linux' ]; then
       ECHO='echo -e'
    else
       ECHO='echo'
    fi
    printUsage() {
      echo ""
      echo "Usage: $PROGNAME -np <dd> <executable> <args>"
      echo ""
      echo "This will run like mpirun but with each process in an xterm"
    nProcs=''
    exec=''
    args=''
    while [ "$1" != "" ]; do
        echo "$1"
        case $1 in
          -np)
            nProcs=$2;shift
            if [ ! "$exec" ]; then
                exec=$1
            elif [ ! "$args" ]; then
                args="\"$1\""
            else
                args="$args \"$1\""
            fi
        esac
        shift
    done
    echo "nProcs=$nProcs"
    echo "exec=$exec"
    echo "args=$args"
    if [ ! "$nProcs" ]; then
        printUsage
        exit 1
    fi
        printUsage
        exit 1
    fi
        printUsage
        exit 1
    fi
    exec=`which $exec`
    if [ ! -x "$exec" ]; then
        echo "Cannot find executable $exec or is not executable"
        printUsage
        exit 1
    fi
    echo "run $args" > $HOME/gdbCommands
    echo "where" >> $HOME/gdbCommands
    echo "Constructed gdb initialization file $HOME/gdbCommands"
    $ECHO "Choose running method: 1)gdb+xterm  2)gdb  3)log  4)xterm+valgrind 5)nemiver: \c"
    read method
    if [ "$method" -ne 1 -a "$method" -ne 2 -a "$method" -ne 3 -a "$method" -ne 4 -a "$method" -ne 5 ]; then
        printUsage
        exit 1
    fi
    $ECHO "Run all processes local or distributed? 1)local  2)remote: \c"
    read spawn
    if [ "$spawn" -ne 1 -a "$spawn" -ne 2 ]; then
        printUsage
        exit 1
    fi
    # check ~/.$WM_PROJECT/$WM_PROJECT_VERSION/
    # check <installedProject>/etc/
    if [ "$WM_PROJECT" ]; then
       for i in \
          $HOME/.WM_PROJECT/$WM_PROJECT_VERSION \
          $HOME/.WM_PROJECT \
          $WM_PROJECT_DIR/etc \
       do
          if [ -f "$i/bashrc" ]; then
             sourceFoam="$i/bashrc"
             break
          fi
       done
    fi
    # Construct test string for remote execution.
    # Source OpenFOAM settings if OpenFOAM environment not set.
    # attempt to preserve the installation directory 'FOAM_INST_DIR'
    if [ "$FOAM_INST_DIR" ]; then
       sourceFoam='[ "$WM_PROJECT" ] || '"FOAM_INST_DIR=$FOAM_INST_DIR . $sourceFoam"
    else
       sourceFoam='[ "$WM_PROJECT" ] || '". $sourceFoam"
    fi
    echo "**sourceFoam:$sourceFoam"
    rm -f $HOME/mpirun.schema
    touch $HOME/mpirun.schema
    proc=0
    xpos=0
    ypos=0
    for ((proc=0; proc<$nProcs; proc++))
    do
        procCmdFile="$HOME/processor${proc}.sh"
        procLog="processor${proc}.log"
        geom="-geometry 120x20+$xpos+$ypos"
        node=""
        if [ .$WM_MPLIB = .OPENMPI ]; then
            node="-np 1 "
        elif [ .$WM_MPLIB = .LAM ]; then
            if [ "$spawn" -eq 2 ]; then
                node="c${proc} "
            fi
        fi
        echo "#!/bin/sh" > $procCmdFile
        if [ "$method" -eq 1 ]; then
            echo "$sourceFoam; cd $PWD; gdb -command $HOME/gdbCommands $exec 2>&1 | tee $procLog; read dummy" >> $procCmdFile
            #echo "$sourceFoam; cd $PWD; $exec $args; read dummy" >> $procCmdFile
            echo "${node}xterm -font fixed -title 'processor'$proc $geom -e $procCmdFile" >> $HOME/mpirun.schema
        elif [ "$method" -eq 2 ]; then
            echo "$sourceFoam; cd $PWD; gdb -command $HOME/gdbCommands >& $procLog" >> $procCmdFile
            echo "${node}$procCmdFile" >> $HOME/mpirun.schema
        elif [ "$method" -eq 3 ]; then
            echo "$sourceFoam; cd $PWD; $exec $args >& $procLog" >> $procCmdFile
        elif [ "$method" -eq 4 ]; then
            echo "$sourceFoam; cd $PWD; valgrind $exec $args; read dummy" >> $procCmdFile
        elif [ "$method" -eq 5 ]; then
        ## maybe could use nemiver sessions for reloading breakpoints --session=<N> or --last
    #         echo "$sourceFoam; cd $PWD; nemiver --last $exec $args; read dummy" >> $procCmdFile
            echo "$sourceFoam; cd $PWD; nemiver $exec $args; read dummy" >> $procCmdFile
    #         echo "$sourceFoam; cd $PWD; ddd --args $exec $args; read dummy" >> $procCmdFile
            echo "${node} $procCmdFile" >> $HOME/mpirun.schema
        fi
        chmod +x $procCmdFile
        let column=proc%6
        if [ $proc -ne 0 -a $column -eq 0 ]; then
            ((xpos+=600))
            ((ypos=0))
        else
            ((ypos+=200))
        fi
    done
    do
        echo "    tail -f $procLog"
    done
    $ECHO "Constructed $HOME/mpirun.schema file. Press return to execute.\c"
    read dummy
        mpirun -app $HOME/mpirun.schema </dev/null
        mpirun $HOME/mpirun.schema </dev/null
    fi
  • Cp_ZhaoC 离线
    Cp_ZhaoC 离线
    Cp_Zhao
    ArmDDT软件,现在好像叫armforge
    blog :
    <https://chengpengzhao.com>
    CFDngu
    在 中回复了 Cp_Zhao 最后由 编辑
    @cp_zhao 这个我记得收费吧?不过也谢谢了~
    Cp_ZhaoC 1 条回复 最后回复
  • Cp_ZhaoC 离线
    Cp_ZhaoC 离线
    Cp_Zhao
    在 中回复了 CFDngu 最后由 编辑
    @cfdngu 收费也没办法,我之前找了一圈也没有找到比这个好用的
    blog :
