  3. 量纲问题:加入的fvm::susp部分总差个密度量纲?求大佬指点,我已黔驴技穷了
7 帖子 3 发布者 4.6k 浏览
    Chen_hao
    错误如下:
    --> FOAM FATAL ERROR:
    incompatible dimensions for operation
        [omega[0 0 -2 0 0 0 0] ] - [omega[1 -3 -2 0 0 0 0] ]
    我定义量部分:
     const volVectorField& B =
        this->mesh_.objectRegistry::template
        lookupObject<volVectorField>("B")
        const volScalarField& sigmaMag =
        lookupObject<volScalarField>("sigmaMag")
        volScalarField Ux = U.component(0);
        volScalarField Uy = U.component(1);
        volScalarField Uz = U.component(2);
        volScalarField Bx = B.component(0);
        volScalarField By = B.component(1);
        volScalarField Bz = B.component(2);
        volScalarField Scmag
           ((sigmaMag/rho)*(2.0*Ux*Uy*Bx*By) + (2.0*Ux*Uz*Bx*Bz) + (2.0*Uy*Uz*Bx*By) - (Uy*Uy + Uz*Uz)*Bx*Bx - (Ux*Ux + Uz*Uz)*By*By - (Uy*Uy + Ux*Ux)*Bz*Bz)
    加入一个fvm::susp部分:
     tmp<fvScalarMatrix> omegaEqn
                fvm::ddt(alpha, rho, omega_)
              + fvm::div(alphaRhoPhi, omega_)
              - fvm::laplacian(alpha*rho*DomegaEff(F1), omega_)
                alpha()*rho()*gamma
               *min
                    GbyNu, //G
                    (c1_/a1_)*betaStar_*omega_()
                   *max(a1_*omega_(), b1_*F23()*sqrt(S2()))
              - fvm::SuSp((2.0/3.0)*alpha()*rho()*gamma*divU, omega_)
               //加入部分如下:
              - fvm::SuSp(0.1*alpha()*rho()*Scmag()/k_(), omega_)
              - fvm::Sp(alpha()*rho()*beta*omega_(), omega_)
              - fvm::SuSp
                    alpha()*rho()*(F1() - scalar(1))*CDkOmega()/omega_(),
                    omega_
              + Qsas(S2(), gamma, beta)
              + omegaSource()
              + fvOptions(alpha, rho, omega_)
    量纲显示差一个密度,可我计算的Scmag量 [0,2,-3,0,0,0,0] 密度没差,:mihu: 莫非是方程默认除了一个rho的单位?
    这两行手算梁刚没问题?
    Chen_hao
    在 中回复了 李东岳 最后由 Chen_hao 编辑
    自己添加这一部分算下来确实如错误所示 [1,-3,-2,0,0,0,0]
    不理解的是这一部分 alpha gamma 无量纲,rho [1,-3,0,0,0,0,0] , divU [0,0,-1,0,0,0,0 ] , omega [0,0,-1,0,0,0,0] ,
    按道理来说应该也是 [1,-3,-2,0,0,0,0],可错误显示其为 [0 0 -2 0 0 0 0],
    然后omegaSource定义的量纲:
    kOmegaSST<TurbulenceModel, BasicTurbulenceModel>::omegaSource() const
        return tmp<fvScalarMatrix>
            new fvScalarMatrix
                omega_,
                dimVolume*this->rho_.dimensions()*omega_.dimensions()/dimTime
    从这看是[ 1,0,-2,0,0,0,0] ???
    Chen_hao
    @chen_hao
    自回复,如果论文中源项公式没错的话,按部就班导入进来就会有量纲问题,
    解决办法:不要纠结,计算好源项量纲直接除一个带量纲的标量1即可。:zoule:
    希望可以给大家节省时间。
        dimensionedScalar I1
        	"I1",
        	dimDensity,
        	1
    在 中回复了 Chen_hao 最后由 编辑
    @chen_hao 信息很多,一直没时间细看,惭愧惭愧... :135: :135:
    Chen_hao
    @李东岳 :xinxin:
    谢谢老师,已经帮我很多了,记录下来,也可以帮助其他人
  • vbcwlV 离线
    vbcwlV 离线
    vbcwl
    openFoam可以无量纲的,应该在etc/controlDict这个文件里里吧dimensionset 1改为0
    LBE
