  3. 求一个win10可用的ANSYS下载地址
21 帖子 7 发布者 29.1k 浏览
  • P 离线
    P 离线
    panchen
    @东岳 按照教程安装ansys 17.2 后,fluent可以正常打开,但是单独打开OCEM时,报如下错误:
    ICEM_ACN is "/opt/ansys_inc/v172/icemcfd/linux64_amd".
    Hallo root.
    ANSYSLIC_DIR is set to /opt/ansys_inc/shared_files/licensing
    LD_LIBRARY_PATH is "/opt/ansys_inc/v172/icemcfd/linux64_amd/lib:/opt/ansys_inc/v172/icemcfd/linux64_amd/bin:/opt/ansys_inc/v172/icemcfd/linux64_amd/dif/iges:/opt/ansys_inc/v172/icemcfd/linux64_amd/../../Framework/bin/Linux64".
    args =
    libGL error: unable to load driver: swrast_dri.so
    libGL error: failed to load driver: swrast
    Window information: depth = 24
                        class = 4
    visual depth = 24 class = 4
    X Error of failed request:  BadValue (integer parameter out of range for operation)
      Major opcode of failed request:  154 (GLX)
      Minor opcode of failed request:  3 (X_GLXCreateContext)
      Value in failed request:  0x0
      Serial number of failed request:  4785
      Current serial number in output stream:  4789
    Exit from ICEM CFD
    我的机子没有独显,用的是集显,会是这个原因吗,还请各位大神帮忙解答一下。
