  4. 动网格并行计算找不到point文件
动网格并行计算找不到point文件
5 帖子 2 发布者 6.8k 浏览
  • 郑 离线
    郑 离线
    郑学习
    求解器interFoam,涉及旋转动网格
    具体问题是:
    从中间时间步(非0时间文件)开始计算的话,decomposePar生成的processor文件的constan-polyMesh文件中不包含“point”文件,导致后续并行计算报错
        \\  /    A nd           | Version:  10
         \\/     M anipulation  |
    Build  : 10
    Exec   : interFoam -parallel
    Date   : Mar 20 2023
    Time   : 14:31:00
    Host   : "dyfluid-virtual-machine"
    PID    : 5576
    I/O    : uncollated
    Case   : /home/dyfluid/OpenFOAM/dyfluid-10/run/2Dtry
    nProcs : 2
    Slaves : 1("dyfluid-virtual-machine.5577")
    Pstream initialised with:
        floatTransfer      : 0
        nProcsSimpleSum    : 0
        commsType          : nonBlocking
        polling iterations : 0
    Create time
    Create mesh for time = 0.2
    Selecting fvMeshMover motionSolver
    Selecting motion solver: solidBody
    [0]
    [0]
    [0] --> FOAM FATAL ERROR: [1]
    [1]
    [1] --> FOAM FATAL ERROR:
    [1] cannot find file "/home/dyfluid/OpenFOAM/dyfluid-10/run/2Dtry/processor1/constant/polyMesh/points"
    [1]
    [1]     From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    [0] cannot find file "/home/dyfluid/OpenFOAM/dyfluid-10/run/2Dtry/processor0/constant/polyMesh/points"
    [0]
    [0]     From function virtual Foam::autoPtr<Foam::ISstream> Foam::fileOperations::uncollatedFileOperation::readStream(Foam::regIOobject&, const Foam::fileName&, const Foam::word&, bool) const
    [0]     in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539.
    [0]
    FOAM parallel run exiting
    [0]
    [1]     in file global/fileOperations/uncollatedFileOperation/uncollatedFileOperation.C at line 539.
    [1]
    [1]
    MPI_ABORT was invoked on rank 1 in communicator MPI COMMUNICATOR 3 SPLIT FROM 0
    with errorcode 1.
    NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
    You may or may not see output from other processes, depending on
    exactly when Open MPI kills them.
    [dyfluid-virtual-machine:05572] 1 more process has sent help message help-mpi-api.txt / mpi-abort
    [dyfluid-virtual-machine:05572] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    目前尚不清楚该如何解决,求助
    decomposePar的log怎么提示?
    郑 1 条回复 最后回复
  • 郑 离线
    郑 离线
    郑学习
    @李东岳 李老师您好
    这是中间时间文件decomposePar的结果
         \\/     M anipulation  |
    Build  : 10
    Exec   : decomposePar
    Date   : Mar 21 2023
    Time   : 16:04:48
    PID    : 3798
    I/O    : uncollated
    nProcs : 1
    Create time
    Decomposing mesh region0
    Create mesh
    Calculating distribution of cells
    Selecting decomposer scotch
    Finished decomposition in 0.038637 s
    Calculating original mesh data
    Distributing cells to processors
    Distributing faces to processors
    Distributing points to processors
    Constructing processor meshes
    Processor 0
        Number of cells = 42000
        Number of faces shared with processor 1 = 80
        Number of processor patches = 1
        Number of processor faces = 80
        Number of boundary faces = 85660
    Processor 1
        Number of faces shared with processor 0 = 80
        Number of boundary faces = 85180
    Max number of cells = 42000 (0% above average 42000)
    Max number of processor patches = 1 (0% above average 1)
    Max number of faces between processors = 80 (0% above average 80)
    Time = 0.0005s
    Processor 0: field transfer
    Detected additional non-decomposed files in "/home/dyfluid/OpenFOAM/dyfluid-10/run/2Dtry/0.0005/uniform"
    Processor 1: field transfer
    End
    这个0.0005时间文件,是之前并行计算后reconstructPar出来的
    我自己对比了一下,用0文件分网格出来,和0.0005分网格出来,确实后者会少一个“point”文件
    个人推测和动网格有关,因为我用dambreak的并行计算对比过,dambreak中途进行并行计算是可行的,但是具体哪里出问题了还不清楚
    你把0.0005改成0试一下
    郑 1 条回复 最后回复
  • 郑 离线
    郑 离线
    郑学习
    @李东岳 试了一下,文件名和“uniform-time”文件里面的时间信息也都更改了,分网格出来仍然没有“point”文件
