  4. 用rhoReactingFoam对燃烧瞬态过程进行求解
多组分燃烧流
6 帖子 3 发布者 9.5k 浏览
  • M 离线
    M 离线
    myheart
    最近在做多组分燃烧+流动的计算,发现有人提到在每个时间步里,先算流动再算化学反应,且化学反应的时间步长一般要小于流动的时间步长(我理解为controlDict中的deltaT),但是我在rhoReactingFoam的源码中并没有发现这样一个分开计算的过程,有两个问题望大佬解惑。
    1. rhoReactingFoam在计算瞬态问题时的实际计算过程是怎么样的?
    2. 如果化学反应的时间步长和流动的时间步长不一致,那么化学反应的时间步长该如何控制?(在chemFoam的源码中有提到过dtChem这个变量,但没看懂具体是如何来的)
    附OpenFOAM-6的rhoReactingFoam.C如下。
    #include "fvCFD.H"
    #include "rhoReactionThermo.H"
    #include "CombustionModel.H"
    #include "turbulentFluidThermoModel.H"
    #include "multivariateScheme.H"
    #include "pimpleControl.H"
    #include "pressureControl.H"
    #include "fvOptions.H"
    #include "localEulerDdtScheme.H"
    #include "fvcSmooth.H"
        #include "postProcess.H"
        #include "setRootCaseLists.H"
        #include "createTime.H"
        #include "createMesh.H"
        #include "createControl.H"
        #include "initContinuityErrs.H"
        #include "createFields.H"
        #include "createFieldRefs.H"
        #include "createRhoUfIfPresent.H"
        #include "createTimeControls.H"
        turbulence->validate();
        if (!LTS)
            #include "compressibleCourantNo.H"
            #include "setInitialDeltaT.H"
        Info<< "\nStarting time loop\n" << endl;
        while (runTime.run())
            #include "readTimeControls.H"
            if (LTS)
                #include "setRDeltaT.H"
            else
                #include "setDeltaT.H"
            runTime++;
            Info<< "Time = " << runTime.timeName() << nl << endl;
            #include "rhoEqn.H"
            // --- Pressure-velocity PIMPLE corrector loop
            while (pimple.loop())
                #include "UEqn.H"
                #include "YEqn.H"
                #include "EEqn.H"
                // --- Pressure corrector loop
                while (pimple.correct())
                    if (pimple.consistent())
                        #include "../../../compressible/rhoPimpleFoam/pcEqn.H"
                    else
                        #include "../../../compressible/rhoPimpleFoam/pEqn.H"
                if (pimple.turbCorr())
                    turbulence->correct();
            rho = thermo.rho();
            runTime.write();
            Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
                << "  ClockTime = " << runTime.elapsedClockTime() << " s"
                << nl << endl;
        Info<< "End\n" << endl;
        return 0;
    你看一下chemistrySolver那面的欧拉隐性以及ode求解器,那面的solve函数可以更新化学反应的时间步
    M 1 条回复 最后回复
  • M 离线
    M 离线
    myheart
    @李东岳 谢谢李老师,我研究研究。
    yuky
    请问您是做气气燃烧还是气液燃烧的呀
    M 1 条回复 最后回复
  • M 离线
    M 离线
    myheart
    在 中回复了 yuky 最后由 编辑
    @yuky您好气气燃烧。
    据我已有的知识来说,除了雾化液滴,其余的大体积液体应该得先蒸发变为气态才能参与燃烧。(不一定对)
    Y 1 条回复 最后回复
    yuky
    在 中回复了 myheart 最后由 编辑
    @myheart 好的好的,十分感谢,我再去研究一下
