  3. 在fsifoam中运行算例报错
在fsifoam中运行算例报错
8 帖子 2 发布者 5.6k 浏览
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    写于 最后由 洱聿 编辑
    目前基于两相流求解器fsifoam,BeamInCross的案例可以运行。
    在设置新的算例过程中出现问题,检查网格设置没有问题,但在运行到wavefsifoam中的时候总会出现浮点报错,以下是报错的log文件。有大佬知道是什么问题嘛?
    Create time
    Create dynamic mesh for time = 0
    Selecting dynamicFvMesh dynamicMotionSolverFvMesh
    Selecting motion solver: velocityLaplacian
    Selecting motion diffusion: quadratic
    Selecting motion diffusion: inverseDistance
     Reading stress mesh
    Selecting turbulence model type laminar
    PIMPLE: no residual control data found. Calculations will employ 2 corrector loops
    Creating traction displacement boundary conditions
    Creating fixed displacement boundary condition
    Selecting rheology model linearElastic
    Creating constitutive model
    Selecting coupling scheme IQN-ILS
    Starting time loop
    Time = 0.0005 (dt = 0.0005)
    Create extended GGI zone-to-zone interpolator
    Checking fluid-to-solid face interpolator
    Fluid-to-solid face interpolation error: 2.66686e-15
    Checking solid-to-fluid point interpolator (GGI)
    calcMasterPointAddressing() const
    Extended GGI, master point distance, max: 0, avg: 0, min: 0
    Solid-to-fluid point interpolation error (GGI): 1.78004e-15
    Number of uncovered master faces: 0
    Number of uncovered slave faces: 0
    calcSlavePointAddressing() const
    Extended GGI, slave point distance, max: 0, avg: 0, min: 0
    Extended GGI, slave point orientation (<0), max: -0.707107, min: -1, nIncorrectPoints: 0/416
    Setting traction on solid patch
    Total force (fluid) = (9.09051e-13 -10310.3 0)
    Total force (solid) = (-9.17932e-13 10310.3 0)
    Evolving solid solver: unsTotalLagrangianSolid
    DICPCG: Solving for D, Initial residula = 1, Final residual = 0.00139832, No outer iterations = 46
    Max relative residual = 1, Relative residual = 8.57078e-05, enforceLinear = 0
    Current fsi relative residual norm: 1
    Alternative fsi residual: 1
    Time = 0.0005, iteration: 1
    Modes before clean-up : 0, modes after clean-up : 0
    Current fsi under-relaxation factor: 0.4
    Creating accumulated fluid interface displacement
    Maximal accumulated displacement of interface points: 0.0176225
    GAMG:  Solving for cellMotionUx, Initial residual = 1, Final residual = 0.000274813, No Iterations 1
    GAMG:  Solving for cellMotionUy, Initial residual = 1, Final residual = 3.40719e-06, No Iterations 1
    GAMG:  Solving for cellMotionUz, Initial residual = 0, Final residual = 0, No Iterations 1
    Evolving fluid solver
    Courant Number mean: 0 max: 0 velocity magnitude: 0
    volume continuity errors : volume = 1.798, max error = 7.41202e-10, sum local = 3.34731e-14, global = 3.74747e-17
    time step continuity errors : sum local = 6.76086e-06, global = -4.79613e-09, cumulative = -4.79613e-09
    GAMGPCG:  Solving for pcorr:  solution singularity
    time step continuity errors : sum local = 0, global = 0, cumulative = -4.79613e-09
    PIMPLE: iteration 1
    MULES: Solving for alpha1
    Liquid phase volume fraction = 0.333151  Min(alpha1_) = 0  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.33315  Min(alpha1_) = -5.43647e-12  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.333149  Min(alpha1_) = -1.63119e-11  Max(alpha1_) = 1
    Relaxing time: 0.13 s
    DILUPBiCG:  Solving for Ux, Initial residual = 0.0139054, Final residual = 5.6888e-10, No Iterations 1
    DILUPBiCG:  Solving for Uy, Initial residual = 0.90048, Final residual = 7.68278e-08, No Iterations 1
    DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 3.12111e-08, No Iterations 1
    GAMG:  Solving for pd, Initial residual = 0.000490799, Final residual = 3.64458e-07, No Iterations 6
    GAMG:  Solving for pd, Initial residual = 5.23309e-07, Final residual = 1.71699e-07, No Iterations 2
    time step continuity errors : sum local = 6.15505e-08, global = 2.24553e-08, cumulative = 1.76592e-08
    PIMPLE: iteration 2
    Liquid phase volume fraction = 0.33315  Min(alpha1_) = -1.87448e-09  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.333149  Min(alpha1_) = -1.87447e-09  Max(alpha1_) = 1
    Liquid phase volume fraction = 0.333148  Min(alpha1_) = -1.87447e-09  Max(alpha1_) = 1.00001
    Relaxing time: 0.06 s
    DILUPBiCG:  Solving for Ux, Initial residual = 0.00171359, Final residual = 7.95819e-09, No Iterations 1
    DILUPBiCG:  Solving for Uy, Initial residual = 0.00229415, Final residual = 1.1053e-08, No Iterations 1
    DILUPBiCG:  Solving for Uz, Initial residual = 0.971192, Final residual = 3.40668e-10, No Iterations 2
    GAMG:  Solving for pd, Initial residual = 0.000164208, Final residual = 8.28008e-07, No Iterations 1
    GAMGPCG:  Solving for pd, Initial residual = 8.28209e-07, Final residual = 3.38658e-09, No Iterations 5
    time step continuity errors : sum local = 1.20621e-09, global = -9.02852e-12, cumulative = 1.76502e-08
    Total force (fluid) = (-0.05684 4.2698e+06 0.000283692)
    Total force (solid) = (0.0568298 -4.2698e+06 -0.000283692)
    DICPCG: Solving for D, Initial residula = 0.99665, Final residual = 0.00109644, No outer iterations = 44
    Max relative residual = 1.01269, Relative residual = 9.25099e-05, enforceLinear = 0
    Alternative fsi residual: 1.00254
    Time = 0.0005, iteration: 2
    Maximal accumulated displacement of interface points: 3.28076
    GAMG:  Solving for cellMotionUx, Initial residual = 0.993157, Final residual = 0.000144068, No Iterations 1
    GAMG:  Solving for cellMotionUy, Initial residual = 1, Final residual = 8.88797e-06, No Iterations 1
    GAMG:  Solving for cellMotionUz, Initial residual = 6.05144e-07, Final residual = 3.33872e-07, No Iterations 1
    Courant Number mean: 0.00051952 max: 0.0335853 velocity magnitude: 0.33609
    volume continuity errors : volume = 1.79801, max error = 8.29118e-10, sum local = 3.35534e-14, global = 3.66141e-17
    time step continuity errors : sum local = 0.00099525, global = 3.75254e-06, cumulative = 3.75254e-06
    GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 6.62621e-05, No Iterations 8
    GAMGPCG:  Solving for pcorr, Initial residual = 2.80297e-05, Final residual = 1.4592e-06, No Iterations 2
    time step continuity errors : sum local = 9.21979e-12, global = -8.2965e-14, cumulative = 3.75254e-06
    Courant Number mean: 0.000181841 max: 0.0268574 velocity magnitude: 0.26901
    PIMPLE: iteration 1
    Liquid phase volume fraction = 0.332773  Min(alpha1_) = -4.11526e-33  Max(alpha1_) = 1.00385
    Liquid phase volume fraction = 0.332869  Min(alpha1_) = 0  Max(alpha1_) = 1.00315
    Liquid phase volume fraction = 0.332965  Min(alpha1_) = 0  Max(alpha1_) = 1.00257
    Relaxing time: 0.07 s
    DILUPBiCG:  Solving for Ux, Initial residual = 0.00750013, Final residual = 1.9279e-09, No Iterations 2
    DILUPBiCG:  Solving for Uy, Initial residual = 0.476658, Final residual = 6.03497e-09, No Iterations 2
    DILUPBiCG:  Solving for Uz, Initial residual = 0.363964, Final residual = 1.19961e-09, No Iterations 2
    GAMG:  Solving for pd, Initial residual = 0.0552688, Final residual = 4.74688e-07, No Iterations 21
    GAMG:  Solving for pd, Initial residual = 1.30893e-09, Final residual = 1.80425e-09, No Iterations 1
    time step continuity errors : sum local = 6.42096e-08, global = -1.01415e-09, cumulative = 3.75153e-06
    PIMPLE: iteration 2
    Liquid phase volume fraction = 0.332835  Min(alpha1_) = 0  Max(alpha1_) = 1.00023
    Liquid phase volume fraction = 0.332993  Min(alpha1_) = 0  Max(alpha1_) = 1.22181
    Liquid phase volume fraction = 0.333151  Min(alpha1_) = 0  Max(alpha1_) = 1.40207
    DILUPBiCG:  Solving for Ux, Initial residual = 0.164439, Final residual = 8.32138e-08, No Iterations 5
    DILUPBiCG:  Solving for Uy, Initial residual = 0.201356, Final residual = 6.76597e-07, No Iterations 4
    DILUPBiCG:  Solving for Uz, Initial residual = 0.834862, Final residual = 8.61714e-07, No Iterations 5
    GAMG:  Solving for pd, Initial residual = 3.4311e-05, Final residual = 9.63653e-07, No Iterations 8
    GAMGPCG:  Solving for pd, Initial residual = 1.72276e-06, Final residual = 3.34751e-09, No Iterations 4
    time step continuity errors : sum local = 6.58196e-08, global = 1.14823e-10, cumulative = 3.75164e-06
    Total force (fluid) = (44895.8 -5.16199e+08 -0.04222)
    Total force (solid) = (-44895 5.16233e+08 0.0422304)
    det: -6.35377, 1.44569
    DICPCG: Solving for D, Initial residula = 0.981674, Final residual = 0.000998539, No outer iterations = 46
    Max relative residual = 1.04638, Relative residual = 0.000100841, enforceLinear = 0
    Alternative fsi residual: 1.00299
    Time = 0.0005, iteration: 3
    Maximal accumulated displacement of interface points: 468.826
    GAMG:  Solving for cellMotionUx, Initial residual = 0.999092, Final residual = 0.000110299, No Iterations 1
    GAMG:  Solving for cellMotionUy, Initial residual = 1, Final residual = 9.9143e-06, No Iterations 1
    GAMG:  Solving for cellMotionUz, Initial residual = 0.00878954, Final residual = 5.34767e-06, No Iterations 7
    Courant Number mean: 0.177766 max: 809.001 velocity magnitude: 163.989
    volume continuity errors : volume = 1.79747, max error = 2.69711e-06, sum local = 3.54005e-14, global = 2.8054e-17
    time step continuity errors : sum local = 0.136847, global = -0.00030095, cumulative = -0.00030095
    GAMGPCG:  Solving for pcorr, Initial residual = 1, Final residual = 8.68671e-05, No Iterations 67
    GAMGPCG:  Solving for pcorr, Initial residual = 0.478654, Final residual = 0.00915489, No Iterations 100
    time step continuity errors : sum local = -1.61429e-05, global = -1.66005e-06, cumulative = -0.00030261
    Courant Number mean: 6.3896 max: 548138 velocity magnitude: 12675.3
    PIMPLE: iteration 1
    Liquid phase volume fraction = 0.376351  Min(alpha1_) = -13.5602  Max(alpha1_) = 7.08985
    Liquid phase volume fraction = 0.361769  Min(alpha1_) = -295.669  Max(alpha1_) = 154.958
    Liquid phase volume fraction = 0.345683  Min(alpha1_) = -6379.38  Max(alpha1_) = 5395.01
    DILUPBiCG:  Solving for Ux, Initial residual = 0.580998, Final residual = 2.92065e-07, No Iterations 17
    DILUPBiCG:  Solving for Uy, Initial residual = 0.977539, Final residual = 9.94289e-07, No Iterations 14
    DILUPBiCG:  Solving for Uz, Initial residual = 0.972502, Final residual = 9.01328e-08, No Iterations 6
    卑以自牧,温润如玉。
    这个流体给固体的力是不是太大了?
    洱聿洱 1 条回复 最后回复
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    @李东岳 东岳老师说的是这里嘛?
    这个GGI 错误不太对我也注意到了,调节了一些参数还是没有太大帮住。
    我这个物体的长细比很大,厚度很小,自由液面网格精度不够是不是会影响这个流体对固体的力 ?
    卑以自牧,温润如玉。
    @洱聿 在 在fsifoam中运行算例报错 中说:
    看起来位移太大了,导致网格变动太大不能算了
    洱聿洱 1 条回复 最后回复
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    在 中回复了 李东岳 最后由 洱聿 编辑
    @李东岳 这些天主要是查了一些资料,修改了文件中的参数(目前算例已经可以计算,迭代步数较多,大致计算到1s左右)最主要的两个参数如下:
    1.修改solid/system/fvsolution中,在松弛因子中添加一项
    relaxationFactors
    	    fields
    	        D 0.5;
    	    equations
    	         D 1;//添加的这一项
    还是不太能分清fields和equtions代表的含义?
    2.还有一个是最大库朗数的调整
    maxCo           0.2;//3
    卑以自牧,温润如玉。
    fields是场松弛,equations是方程松弛。在simpleFoam解析里面有提及 http://dyfluid.com/simpleFoam.html
    洱聿洱 1 条回复 最后回复
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    @李东岳 嗯嗯好的,谢谢东岳老师,我好好学习一下。
    卑以自牧,温润如玉。
  • 洱聿洱 离线
    洱聿洱 离线
    洱聿
    写于 最后由 洱聿 编辑
    目前算例移植到计算机集群上计算,模型是水面上漂浮的平板。大约计算到0.8s时出现这个报错,查找原因是内存分配问题;
    有查看了相关的log文件,文件中给出的报错是如下所示
    为什么算例运行中会出现nu不被定义的报错呢?是因为计算过程中,网格出现问题嘛?
    卑以自牧,温润如玉。
