  3. reactingFoam修改化学反应机理后遇到了问题
5 帖子 2 发布者 6.7k 浏览
    yuky
    目前研一刚入门阶段,针对reactingfoam进行一些改动,用的是自己的构型,边界条件也相应做了一些调整,原本的参考案例是用CH4,我自己改成了C7H16,也把化学机理加了进来,现在遇到了这个问题不知道怎么办(报错如下所附),请求各位大神指点一下
    --> FOAM FATAL ERROR:
    Sum of mass fractions is zero for species
    544
    各种组分
        From function void Foam::basicSpecieMixture::correctMassFractions()
        in file mixtures/basicSpecieMixture/basicSpecieMixture.C at line 205.
    FOAM exiting
    yuky
    这个问题解决了,但是出现了新的问题:136:
    No MRF models present
    No fvModels present
    No fvConstraints present
    #3  Foam::nutkWallFunctionFvPatchScalarField::nut() const at ??:?
    #4  Foam::nutWallFunctionFvPatchScalarField::updateCoeffs() at ??:?
    #5  Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>::Boundary::evaluate() in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
    #6  Foam::RASModels::kEpsilon<Foam::CompressibleMomentumTransportModel<Foam::dynamicTransportModel> >::correctNut() at ??:?
    #7  ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
    #8  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #9  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #10  ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
    epsilon不能给0的初始场。你检查一下
    Y 1 条回复 最后回复
    yuky
    @李东岳 好的,谢谢东岳老师,我去看看
    yuky
    又又又遇到了新问题,一步都没算下去,请问这种问题一般出在哪里:xinlei:
    Create time
    Create mesh for time = 0
    PIMPLE: No convergence criteria found
    PIMPLE: Operating solver in transient mode with 1 outer corrector
    Using LTS
    type heRhoThermo;
    mixture multiComponentMixture;
    transport sutherland;
    thermo janaf;
    energy sensibleEnthalpy;
    equationOfState perfectGas;
    specie specie;
    Reading field U
    Creating turbulence model.
    kEpsilonCoeffs
    Prt 0.85;
    Cmu 0.09;
    C1 1.44;
    C2 1.92;
    C3 0;
    sigmak 1;
    sigmaEps 1.3;
    Creating thermophysical transport model
    Selecting thermophysical transport type RAS
    Selecting default RAS thermophysical transport model unityLewisEddyDiffusivity
    Creating reaction model
    Selecting combustion model EDC
    Selecting chemistry solver
    solver ode;
    method standard;
    standardChemistryModel: Number of species = 544 and reactions = 2446
    Selecting ODE solver seulex
    Creating field dpdt
    Creating field kinetic energy K
    No fvModels present
    Starting time loop
    Time scales min/max:
    Flow = 9.728569846e-08, 0.0001
    Temperature = 4.494232837e+307, 4.494232837e+307
    Composition = 4.494232837e+307, 4.494232837e+307
    Overall = 9.728569846e-08, 0.0001
    Time = 1e-07
    diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
    DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.0001092756986, No Iterations 1
    DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.006862564884, No Iterations 1
    DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.0001167898495, No Iterations 1
    #0 Foam::error::printStack(Foam::Ostream&) at ??:?
    #1 Foam::sigFpe::sigHandler(int) at ??:?
    #3 double Foam::standardChemistryModel<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGasFoam::specie >, Foam::sensibleEnthalpy> > >::solve<Foam::Field<double> >(Foam::Field<double> const&) at ??:?
    #4 Foam::combustionModels::EDC::correct() at ??:?
    #5 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
    #6 ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #8 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
