  4. 贴个对volSymmTensorField进行操作的代码
4 帖子 2 发布者 4.0k 浏览
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    首先对volSymmTensorField进行声明:
    Info<< "Creating field alphaUPrimeij and rhoUPrimeij\n" << endl;
    volSymmTensorField alphaUPrimeij
        IOobject
            "alphaUPrimeij",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh
    volSymmTensorField rhoUPrimeij
        IOobject
            "rhoUPrimeij",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh
    volScalarField myepsilon
        IOobject
            "myepsilon",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh
    然后计算,UMean是通过controlDict-functionObject的fieldAverage算的,然后alphaUPrimeij和rhoUPrimeij也会使用fieldAverage进行时间平均。
    if (mesh.thisDb().foundObject<volVectorField>("UMean"))
        const volVectorField& UMean_ = mesh.thisDb().lookupObject<volVectorField>("UMean");
        const volVectorField UPrime = U - UMean_;
        const volTensorField gradUPrime(fvc::grad( UPrime ));
        myepsilon = gradUPrime && gradUPrime;
        rhoUPrimeij.component(symmTensor::XX)=rho*UPrime.component(vector::X)*UPrime.component(vector::X);
        rhoUPrimeij.component(symmTensor::XY)=rho*UPrime.component(vector::X)*UPrime.component(vector::Y);
        rhoUPrimeij.component(symmTensor::XZ)=rho*UPrime.component(vector::X)*UPrime.component(vector::Z);
        rhoUPrimeij.component(symmTensor::YY)=rho*UPrime.component(vector::Y)*UPrime.component(vector::Y);
        rhoUPrimeij.component(symmTensor::YZ)=rho*UPrime.component(vector::Y)*UPrime.component(vector::Z);
        rhoUPrimeij.component(symmTensor::ZZ)=rho*UPrime.component(vector::Z)*UPrime.component(vector::Z);
        alphaUPrimeij.component(symmTensor::XX)=alpha1*UPrime.component(vector::X)*UPrime.component(vector::X);
        alphaUPrimeij.component(symmTensor::XY)=alpha1*UPrime.component(vector::X)*UPrime.component(vector::Y);
        alphaUPrimeij.component(symmTensor::XZ)=alpha1*UPrime.component(vector::X)*UPrime.component(vector::Z);
        alphaUPrimeij.component(symmTensor::YY)=alpha1*UPrime.component(vector::Y)*UPrime.component(vector::Y);
        alphaUPrimeij.component(symmTensor::YZ)=alpha1*UPrime.component(vector::Y)*UPrime.component(vector::Z);
        alphaUPrimeij.component(symmTensor::ZZ)=alpha1*UPrime.component(vector::Z)*UPrime.component(vector::Z);
    目的是计算下面帖子提到的这个多相流的雷诺应力
    @学流体的小明 在 如何在controlDict中创建一个场,不需要修改求解器 中说:
    话说这个latex代码怎么转义不了
    使用LES计算气泡槽道流,因为是多相流,某一点可能会有气泡经过,解析的雷诺应力$u\prime_i u\prime_j$会受到很大影响,所以我想对 $u\prime_i u\prime_j$ 进行加权处理。
    具体方法是:生成张量场,计算每一个cell每一个瞬时的$\alpha u\prime_i u\prime_j$,$(1-\alpha) u\prime_i u\prime_j$,$\rho u\prime_i u\prime_j$,然后使用fieldAverage进行系综平均。
    我想在controlDict中生成场$\rho u\prime_i u\prime_j$,然后每个时刻计算一下这个场,怎样通过functions{ }操作呢?因为是要每一个时间步都计算以获得正确的值,所以不太想按一定时间间隔输出数据之后再进行后处理。
    当然也可以直接在solver的createFields.H中创建,我就是想找一个更通用的不用修改求解器的方法,直接很简便地在controlDict - functions{ }中实现。
    毕竟functions{ }可以用writeObjects输出
       \\    /   O peration     | Version:  v2012
        \\  /    A nd           | Website:  www.openfoam.com
         \\/     M anipulation  |
    Description
        Writes out specified objects, e.g. fields, stored on the case database.
    type            writeObjects;
    libs            (utilityFunctionObjects);
    objects         (<object names>);
    writeControl    writeTime;
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    上面的代码不能用,原因是对GeometricField(使用的时候具体化了)的对象rhoUPrimeij使用rhoUPrimeij.component(symmTensor::ZZ);会返回tmp<GeometricField>,是一个临时的变量,实际的rhoUPrimeij根本没有被修改。
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    新代码长这样子:
    创造场变量时需要设置初始值,否则程序调用的构造函数一定会去文件中找,会报错说找不到该变量文件。
        IOobject
            "alphaUPrimeij",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        dimensionedSymmTensor(dimensionSet(0, 2, -2, 0, 0, 0, 0), symmTensor(0., 0., 0., 0., 0., 0.))
        IOobject
            "rhoUPrimeij",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        dimensionedSymmTensor(dimensionSet(1, -1, -2, 0, 0, 0, 0), symmTensor(0., 0., 0., 0., 0., 0.))
        IOobject
            "myepsilon",
            runTime.timeName(),
            mesh,
            IOobject::NO_READ,
            IOobject::NO_WRITE
        mesh,
        dimensionedScalar(dimensionSet(0, 2, -3, 0, 0, 0, 0), 0.)
        // const volScalarField UPrimeX = UPrime.component(0);
        // const volScalarField UPrimeY = UPrime.component(1);
        // const volScalarField UPrimeZ = UPrime.component(2);
        myepsilon = mixture.nu()*gradUPrime && gradUPrime;
        scalar rhoCell,alphaCell,UPrimeX,UPrimeY,UPrimeZ;
        forAll(rhoUPrimeij,celli)
            rhoCell=rho[celli];
            alphaCell=alpha1[celli];
            UPrimeX=UPrime[celli][0];
            UPrimeY=UPrime[celli][1];
            UPrimeZ=UPrime[celli][2];
            rhoUPrimeij[celli]=symmTensor(
                rhoCell*UPrimeX*UPrimeX,
                rhoCell*UPrimeX*UPrimeY,
                rhoCell*UPrimeX*UPrimeZ,
                rhoCell*UPrimeY*UPrimeY,
                rhoCell*UPrimeY*UPrimeZ,
                rhoCell*UPrimeZ*UPrimeZ
            alphaUPrimeij[celli]=symmTensor(
                alphaCell*UPrimeX*UPrimeX,
                alphaCell*UPrimeX*UPrimeY,
                alphaCell*UPrimeX*UPrimeZ,
                alphaCell*UPrimeY*UPrimeY,
                alphaCell*UPrimeY*UPrimeZ,
                alphaCell*UPrimeZ*UPrimeZ
    感谢分享!!:146: :146: :146:
