  4. refineMesh + overset 计算带来很大误差。
rotation
3 帖子 2 发布者 3.5k 浏览
  • P 离线
    P 离线
    Perseus
    大家好,我想仿真2D均匀流场中放置一个强迫旋转的椭圆,openfoam版本是v2306。
    如果我使用AMI,那么可以得到和其他论文十分接近的结果,涡量图如下所示。
    但是当我使用overset的时候,会出现比较大的偏差,在我对结果进行可视化之后,我发现在我使用局部加密的位置会出现很明显的间断,如下图所示,我觉得这可能是主要的误差来源。
    以下是我的网格:
    在我绘制涡量图时,会更加奇怪:
    局部加密用的是openfoam自己的toposet和refineMesh,以下是对应的配置文件
    |  \\    /   O peration     | Version:  v2306                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      refineMeshDict;
    // Cells to refine; name of cell set
    set refine3;
    // Type of coordinate system:
    // - global : coordinate system same for every cell. Usually aligned with
    //   x,y,z axis. Specify in globalCoeffs section below.
    // - patchLocal : coordinate system different for every cell. Specify in
    //   patchLocalCoeffs section below.
    // - fieldBased : uses the list of field names from the directions list for
    //   selecting the directions to cut. Meant to be used with geometricCut, but
    //   can also be used with useHexTopology.
    coordinateSystem global;
    //coordinateSystem patchLocal;
    //coordinateSystem fieldBased;
    // .. and its coefficients. x,y in this case. (normal direction is calculated
    // as tan1^tan2)
    globalCoeffs
        tan1 (1 0 0);
        tan2 (0 1 0);
    // List of directions to refine, if global or patchLocal
    directions
        tan1
        tan2
        normal
    // List of directions to refine, if "fieldBased". Keep in mind that these
    // fields must be of type "vectorField", not "volVectorField".
    //directions
    //    radialDirectionFieldName
    //    angularDirectionFieldName
    //    heightDirectionFieldName
    // Whether to use hex topology. This will
    // - if patchLocal: all cells on selected patch should be hex
    // - split all hexes in 2x2x2 through the middle of edges.
    useHexTopology  true;
    // Cut purely geometric (will cut hexes through vertices) or take topology
    // into account. Incompatible with useHexTopology
    geometricCut    false;
    // Write meshes from intermediate steps
    writeMesh       false;
    |  \\    /   O peration     | Version:  v2006                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      topoSetDict;
    actions
            name    refine3;
            type    cellSet;
            action  new;
            source  boxToCell;
            min     (-2 -2 -0.5);
            max     (2 2 0.5);
    我想请问一下如果我使用局部加密网格,那么我有哪些需要注意的地方吗?
    以上,希望各位大佬可以拨冗指点迷津。
    你用overset,然后不适用refineMesh,会这样么?
    P 1 条回复 最后回复
  • P 离线
    P 离线
    Perseus
    @李东岳 老师,如果不使用refineMesh的话,结果会好很多,而且和论文中的Cd, Cl指数可以基本对上,但是在overset的边缘处还是会有一点问题。
    我的oversetInterpolation的method使用的是inverseDistance.
