  4. 关于UDF node_to_host传递数据的问题
3 帖子 2 发布者 5.7k 浏览
    csfine
    #include "udf.h"
    define FLUID_ID 6
    define Total_node 5000
    struct Point
    double x ;
    double y ;
    double z ;
    DEFINE_ON_DEMAND(pressures_to_file)
    int all_nodes ;
    int node_num = 0;  //
    //double *array;
    int pe;
    double (*array)[3];
    //double ** array ;
    #if !RP_NODE
        FILE *fp1  =fopen("Grid coordinates.dat" , "w");
    #endif
    #if RP_NODE
    Domain *domain=Get_Domain(1);
    Thread *t;
    //cell_t c;
    face_t f ;
    Node *node ;
    int n ;
    t=Lookup_Thread(domain,FLUID_ID);
    double Pnode[Total_node][3]={0};
    struct Point point ;
    begin_f_loop(f,t)
        f_node_loop(f,t,n)
            node = F_NODE(f, t, n);
            point.x = NODE_X(node);
            point.y = NODE_Y(node);
            point.z = NODE_Z(node);
            int false = 0 ;
            for (int i = 0; i < node_num; i++)
                if(Pnode[i][0] == point.x && Pnode[i][1] == point.y && Pnode[i][2] == point.z )
                    false = 1 ;
                if (false == 0)
                        Pnode[node_num][0] = point.x ;
                        Pnode[node_num][1] = point.y ;
                        Pnode[node_num][2] = point.z ;
                        node_num = node_num +1 ;
    end_f_loop(f,t)
    array=(double (*)[3])malloc(3*node_num*sizeof(double));
    int kk  = 0;
    begin_f_loop(f,t)
        f_node_loop(f,t,n)
            int false = 0 ;
            for (int i = 0; i < kk; i++)
                if(array[i][0] == point.x && array[i][1] == point.y && array[i][2] == point.z )
                    false = 1 ;
                if (false == 0)
                        array[kk][0] = point.x ;
                        array[kk][1] = point.y ;
                        array[kk][2] = point.z ;
                        kk = kk +1 ;
    end_f_loop(f,t)
        //Message(" node is %d\n" , kk);
        all_nodes = PRF_GISUM1(kk) ;
        pe = (I_AM_NODE_ZERO_P) ? node_host : node_zero;
        PRF_CSEND_INT(pe, &node_num, 1, myid);
        PRF_CSEND_DOUBLE(pe, array[0], 3*node_num, myid);
        free(array);
    if (I_AM_NODE_ZERO_P)
    compute_node_loop_not_zero (pe)
        PRF_CRECV_INT(pe, &node_num, 1, pe);
        PRF_CRECV_DOUBLE(pe, array[0], 3*node_num, pe);
        PRF_CSEND_INT(node_host, &node_num, 1, myid);
        PRF_CSEND_DOUBLE(node_host, array[0], 3*node_num, myid);
        free(array);
    #endif
        //node_to_host_int_1(all_nodes) ;
    #if RP_HOST
    compute_node_loop (pe)
    PRF_CRECV_INT(node_zero, &node_num, 1, node_zero);
    PRF_CRECV_DOUBLE(node_zero, array[0], 3*node_num, node_zero);
        for (int j = 0; j < 3; j++)
            fprintf(fp1 , "%g   " , array[i][j]) ;
        fprintf(fp1 , "\n") ;
        free(array);
    #endif
    #if !RP_NODE
        fclose(fp1) ;
        Message("Finished writing !\n");
        Message("all nodes= %d\n"  , all_nodes);
    #endif
    代码如上所示,主要实现的功能是将各个计算节点中的网格坐标发送到Host 节点。这一部分经过我的测试,没有问题。
    在上述代码中,我统计了总的网格节点数量(90行),并将节点总数发送到host节点,问题就来了:如果我把node_to_host 命令放在115行(已注释),当编译完成之后在fluent挂载的时候直接就卡死了,一直没反应。但是当我把这个命令放在143行的时候,就能成功显示。
    我的猜测是和117~145这一段的代码有关系,这一段代码主要是实现在host节点接收其他计算节点的坐标数组。
    由于本人计算机知识浅薄,目前尚不能明白上述问题所在,如有大神不吝赐教,我不胜感激!
    csfine
    发帖不多,帖子显示出来格式不大好看,大家包容包容。
    我想要发送总的网格节点到host的目的是为了构造一个数组来接收网格坐标以供后续使用,在我的代码中,我只是将数据写入文件夹,但是实际上我想要的是存进一个数组里面,各位大佬如果有好的思路可以给我分享一下。
  • M 离线
    M 离线
    martinliu
    compute_node_loop 不能在HOST节点运行,你117行#if RP_HOST 规定了下面的代码在HOST节点里,但是还要进行compute node 循环,所以会卡住,可能?
