  3. OpenFOAM循环壁面生成
OpenFOAM循环壁面生成
2 帖子 2 发布者 1.6k 浏览
    Zhoujq
    ICEM建模
      1. 本研究基于ICEM建模,首先在构建计算域两侧循环壁面时 (称源面;source) 要和后续OpenFOAM中循环壁面的名字不同;OpenFOAM中重命名的循环壁面被称新面(new):
      1. ICEM进行循环设置:先在Global Mesh Setup—》Global Mesh Parameters 里设置periodicity
        进行网格更新和生成:
    OpenFOAM
      1. 在OpenFOAM中进行网格转化: " fluentMeshToFoam 文件名.msh "。通过checkMesh,无报错:
    checking geometry...
        Overall domain bounding box (-1.925 -0.60993 -0.05) (2.98 0.16507 0.0500586)
        Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
        Mesh has 3 solution (non-empty) directions (1 1 1)
        Boundary openness(1.79143e-17 -2.73076e-15 7.27475e-15) 0K.
        Max cell openness = 4.16732e-16 0K.
        Max aspect ratio = 30.0788 0K.
        Minimum face area = 1.31023e-06.
        Maximum face area = 0.00216234.
        Face areamagnitudes OK.
        Min volume = 4.46199e-09,Max volume = 697531e-06. Total volume = 0.371859. Cell volumes OK.
        Mesh non-orthogonality Max: 38.5733 average: 2.71723
        Non-orthogonality check OK.Face pyramids OK.
        Max skewness = 0.530396 0K.
        Coupled point location match (average o) OK.
    Mesh OK
    End
      1. 检查"boudnary",这时的壁面类型是 wall,需要改进:
    RIGHT
        type      wall;
        inGroups  List<word> 1(wall);
        nFaces    17939;
        startFace 1669453;
    LEFT
        type      wall;
        nFaces    17939;
        startFace 1687392;
      1. 如果直接在"boundary"文件里修改:
    RIGHT
        type           cyclic;
        inGroups       1(cyclic);
        nFaces         17939;
        startFace      1669453;
        neighbourPatch LEFT;
    LEFT
        type           cyclic;
        inGroups       1(cyclic);
        nFaces         17939;
        startFace      1687392;
        neighbourPatch RIGHT;
      1. 进行 checkMesh,报错:
      **Error in coupled point location: 3 faces have their 0th or consecutive vertex not opposite their coupled equivalent. Average mismatch 4.63216e-07.
      <<Writing 3 faces with incorrectly matched 0th (or consecutive) vertex to set coupledFaces
    Failed 1 mesh checks.
    End
      1. 尽管在 ICEM 中进行了结构网格划分,严格对等。但是由于网格数量较大,导入到 OpenFOAM中很容易出现不兼容,报错现象。这时候,需要通过 "createPatchDict"文件对循环壁面进行设置,"createPatchDict"文件需要放到 system目录下:
    pointSync false;
    // Patches to create.
    patches
            // Name of new patch (最好与源面的名字不同,例如示例中的CYCLIC1 (new)和LEFT(source))
            name CYCLIC1:
            // Type of new patch
            patchInfo
                type            cyclic;
                neighbourPatch  CYCLIC2;
                matchTolerance  0.002;
            constructfrom patches;
            patches (LEFT);   //源面
            set f0;
            name CYCLIC2:
            patchInfo
                type            cyclic;
                neighbourPatch  CYCLIC1;
            patches (RIGHT);
            set f0;
      1. 设置完成后,要运行 createPatch。在本案例中生成了一个新的 "0.001" 文件。里面为重新生成的 "polyMesh" 文件,在"boundary"文件包含了正确的循环壁面类型(源面"LEFT" 和"RIGHT"变成了新面"CYCLIC1"和"CYCLIC2"):
    CYCLIC1
        type           cyclic;
        inGroups       List<word> 1(cyclic);
        nFaces         17939;
        startFace      1669453;
        transformType  translational;
        separation     (-1.707449737153865e-10 1.376923575158173e-11 -0.1000000014894364);
    CYCLIC2
        type           cyclic;
        nFaces         17939;
        startFace      1687392;
        separation     (1.707449737153865e-10 -1.376923575158173e-11 0.1000000014894364);
      1. 把正确的"polyMesh"替换到"constant"文件中,重新 checkMesh,没报错:
    Checking geometry ...
        Boundary openness (1.79143e-17 -2.73076e-15 1.01788e-14) 0K.
        Max aspect ratio'= 30.0788 0K.
        Minimum face area = 1.31023e-06. Maximum face area = 0.00216234. Face area magnitudes oK.
        Min volume = 4.46199e-09.  Max volume = 6.97531e-06.  Total volume = 0.371859.   Cell volumes OK.
        Mesh non-orthogonality Max: 38.5733 average: 2.70242
        Face pyramids OK.
        Coupled point location match (average 4.63138e-07) OK.
    Mesh OK.
    End
    参考文献:
    本次教程解决了我面临的问题,主要结合以下教程:
    ICEM 部分:
      1. CFD中文网:
        链接文本
    OpenFOAM部分:
      1. CFDonline:
        链接文本
        附件:createPatchDict.gz
      1. 知乎:
        链接文本
        附件:channel_v0.4.tar.gz
      1. CSDN:
        链接文本
    感谢分享!!:146: :146: :146:
