  3. openfoam11中多组分求解器混合规则调用失败
3 帖子 2 发布者 2.0k 浏览
    CFD乱民
    各位老师好,
    我最近在做一个气固耦合模拟,在气相中,使用了多组分模拟,下面是我在多组分混合时选用的数据模型
    type heRhoThermo;
    mixture multicomponentMixture;
    transport polynomial;
    thermo hPolynomial;
    equationOfState perfectGas;
    specie specie;
    energy sensibleEnthalpy;
    最初测试,transport使用的是sutherland,而 thermo使用的是janaf模型,是没有问题的,但因为缺少数据,所以,我改为了 polynomial 和 hPolynomial,程序可以跑1步,然后开始报错
    报错信息如下
    #0 Foam::error::printStack(Foam::Ostream&) at ??:?
    #1 Foam::sigFpe::sigHandler(int) at ??:?
    #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
    #4 Foam::GAMGSolver::Vcycle(Foam::PtrListFoam::lduMatrix::smoother const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
    #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
    #8 Foam::fvMatrix<double>::solve() at ??:?
    #9 Foam::solvers::isothermalFluid::correctBuoyantPressure() at ??:?
    #10 Foam::solvers::isothermalFluid::pressureCorrector() at ??:?
    #11 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamMultiRun"
    #12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #13 ? in "/opt/openfoam11/platforms/linux64GccDPInt32Opt/bin/foamMultiRun"
    ./Allrun:行 22: 157260 浮点数例外 (核心已转储) foamMultiRun
    请问应该如何处理?谢谢
    这个看起来就是发散了,看不出来啥别的东西
    CFD乱民
    在 中回复了 李东岳 最后由 CFD乱民 编辑
    @李东岳 谢谢师兄,因为模型有辐射模型,流固耦合,还有多物种传输,所以一直觉得是自己设置有问题,或者部分模型需要重新编译,忘了最基本的,刚才把所有收敛系数都调小了.可以跑了,应该就是前期不稳定。但是,也只是多跑了3步,我回头再看看
