ANSYS ICEM热键
Geometry: a: Merge Curves b: Build Topology d: Delete Entity g: Group Curves h: Home Position j: Solid/Wire Frame Shading p: Project Point to Curve s: Segment Curve x: Cancel any Selection z: Zoom In Shift-c: Create Surface Shift-i: Isometric View Shift-p: Project Point to Surface Shift-r: View Reverse Shift-x: YZ Plane View Shift-y: XZ Plane View Shift-z: XY Plane View Ctrl + c: Create Curve from Points Ctrl + d: Delete Entity Permanently Ctrl + g: Segment Curve by Points Ctrl + m: Copy/Move Entities Ctrl + p: Project Curve on Surface Ctrl+ s: Segment Surface by Curve Ctrl+y: Redo (For any operation) Ctrl+z: Undo (For any operation) F11: Emergency Reset F4: Emergency Reset F5: Set Wireframe Offset Display F6: Set Wireframe Offset Display to 0 F7: Increase Wireframe Offset Display F8: Reduce Wireframe Offset Display Edit Mesh: a: Merge Nodes b: Repair Mesh d: Delete Elements e: Create Mesh from Edge m: Move Nodes p: Project Node to Curve q: Quality Matrices r: Remesh Elements s: Split Edge t: Convert Mesh Type v: Snap Project Nodes w: Swap Edge z: Zoom In shift-c: Create Element shift-d: Diagnostics shift-p: Project Nodes to Point Ctrl+a: Merge Node (interactive) Ctrl+m: Move Multiple Nodes Ctrl+p: Project Nodes to Surface Ctrl+q: Quality Histogram Ctrl+r: Remesh Bad Elements Ctrl+t: Convert Quad to Tri F11: Emergency Reset F4: Emergency Reset F5: Set Wireframe Offset F6: Set Wireframe Offset to 0 F7: Increase Wieframe Offset F8: Reduce Wireframe Offset Enter: Apply Blocking: a: Merge Vertices e: Edit Edge f: Associate Face to Surface g: Group and Ungroup curves i: Index Control l: Align Vertices m: Move Vertices n: Pre-mesh Parameters o: Split O-grid p: Associate Edge to Curve q: Premesh Quality s: Split Block u: Update Size (Mesh Parameter) v: Snap Project Vertices shift-c: Create Block shift-i: Isometric View shift-l: Set Edge Length shift-n: Scale Size shift-p: Associate Vertex to Point Ctrl+a: Merge Node (interactive) Ctrl+m: Move Multiple Nodes Ctrl+p: Project Nodes to Surface Ctrl+q: Quality Histogram Ctrl+r: Remesh Bad Elements Ctrl+s: Split Selected Edge F11: Emergency Reset F4: Emergency Reset F5: Set Wireframe Offset F6: Set Wireframe Offset to 0 F7: Increase Wieframe Offset F8: Reduce Wireframe Offset Enter: Apply Selection Mode: 0: Select All Node Elements 1: Select All Line Elements 2: Select All Shell Elements 3. Select All Volume Elements a: Select All b: Select All Blanked Shift + c: Select by Circular Region d: Select by Diagonal Corners g: Set Feature Angle h: Toggle Highlighted i: Segment in Between k: Flood Fill One (Select Attached Layer) l: Flood Fill m: Toggle Region n: Go to Next by Name o: Toggle Boundary p: Polygon Parts r: Flood Fill to Curve (Select Attached until Curve) t: Select Attached to Geometry v: Select All Visible x: Cancel Selection Mode [: Undo Selection ]: Accept Selection Enter: Apply -
z 和 x 用得最顺。
其他的还在熟悉中。
