  4. 时变的非均匀速度边界条件timeVaryingMappedFixedValue运行发散
7 帖子 3 发布者 7.7k 浏览
    wsy11
    请教各位老师一个边界条件文件,如题,我对于速度条件使用了在网上搜到的timeVaryingMappedFixedValue条件,可以导入时变、非均匀的风速数据,但是运行后会报发散错误,我认为是因为没有修改其他物理量边界条件的问题,但是没有找到相关的解决方法。
    希望各位老师帮忙看下怎么修改对应的边界条件:
    blockMesh如下:
    backgroundMesh
        xMin   1250;
        xMax   8698;
        yMin   1343;
        yMax   9476;
        zMin     -60;
        zMax   600;
        xCells  248;
        yCells  271;
        zCells  33;
    convertToMeters 1;
    vertices
        ($!backgroundMesh/xMin $!backgroundMesh/yMin $!backgroundMesh/zMin)
        ($!backgroundMesh/xMax $!backgroundMesh/yMin $!backgroundMesh/zMin)
        ($!backgroundMesh/xMax $!backgroundMesh/yMax $!backgroundMesh/zMin)
        ($!backgroundMesh/xMin $!backgroundMesh/yMax $!backgroundMesh/zMin)
        ($!backgroundMesh/xMin $!backgroundMesh/yMin $!backgroundMesh/zMax)
        ($!backgroundMesh/xMax $!backgroundMesh/yMin $!backgroundMesh/zMax)
        ($!backgroundMesh/xMax $!backgroundMesh/yMax $!backgroundMesh/zMax)
        ($!backgroundMesh/xMin $!backgroundMesh/yMax $!backgroundMesh/zMax)
    blocks
        hex (0 1 2 3 4 5 6 7)
            $!backgroundMesh/xCells
            $!backgroundMesh/yCells
            $!backgroundMesh/zCells
        simpleGrading (1 1 1)
    boundary
        west
            type patch;
            faces
                (0 3 7 4)
        east
            type patch;
            faces
                (1 5 6 2)
        south
            type patch;
            faces
                (0 4 5 1)
        north
            type patch;
            faces
                (3 2 6 7)
        ground
            type wall;
            faces
                (0 1 2 3)
        top
            type patch;
            faces
                (4 7 6 5)
    各物理量边界条件如下:
    U
    boundaryField
        west
            type            timeVaryingMappedFixedValue;
            offset          (0 0 0);
            setAverage      off;
        east
        north
            offset          (0 0 0);
            setAverage      off;
        south
        ground
            type            noSlip;
        buildings
            type            noSlip;
         wall
            type            noSlip;
        top
            offset          (0 0 0);
            setAverage      off;
    P
    internalField   uniform 0;
    boundaryField
        west
            type            zeroGradient;
        east
            rho             rho;
            psi             none;
            gamma           1;
            p0              uniform 0;
            value           uniform 0;
        north
            type            zeroGradient;
        south
            rho             rho;
            psi             none;
            gamma           1;
            p0              uniform 0;
            value           uniform 0;
        ground
            type            zeroGradient;
        wall
            type            zeroGradient;
        buildings
            type            zeroGradient;
        top
            type            zeroGradient;
    nut
    boundaryField
        west
            type            calculated;
            value           uniform 0;
        east
            type            calculated;
            value           uniform 0;
        north
            type            calculated;
            value           uniform 0;
        south
            type            calculated;
            value           uniform 0;
        ground
            value           uniform 0;
        buildings
            value           uniform 0;
        wall
            value           uniform 0;
        top
            type            calculated;
            value           uniform 0;
    k
    internalField   uniform 1.5;
    boundaryField
        west
            type            fixedValue;
            value           uniform 1.5;
        east
            type            inletOutlet;
            inletValue      uniform 1.5;
            value           uniform 1.5;
        north
            type            fixedValue;
            value           uniform 1.5;
        south
            type            inletOutlet;
            value           uniform 1.5;
        ground
            value           uniform 1.5;
        buildings
            value           uniform 1.5;
        wall
            value           uniform 1.5;
        top
            type            inletOutlet;
            value           uniform 1.5;
    spsilon
    dimensions      [0 2 -3 0 0 0 0];
    internalField   uniform 0.03;
    boundaryField
        west
            type            fixedValue;
            value           uniform 0.03;
        east
            type            inletOutlet;
            inletValue      uniform 0.03;
            value           uniform 0.03;
        north
            type            fixedValue;
            value           uniform 0.03;
        south
            type            inletOutlet;
            value           uniform 0.03;
        ground
            type            epsilonWallFunction;
            value           uniform 0.03;
        buildings
            value           uniform 0.03;
        wall
            value           uniform 0.03;
        top
            type            inletOutlet;
            value           uniform 0.03;
    你用的openfoam单向流求解器么,这个如果网格质量不是特别差的话,发散都是设置的问题。可以调节一下你湍流的进口边界。
    coolhhh 神
    在 中回复了 wsy11 最后由 编辑
    @wsy11
    1. 这是算URANS吗?计算的建筑绕流?
    2. top面为何也是速度入口,如果改为symmetry看看
    3. U的east和south,你设置了pressureInletOutletVelocity,我没用过这个,一般设置为zeroGradient或者inletOutlet。
      对应p的east和south,设置为fixedValue为0
    wsy11
    在 中回复了 coolhhh 最后由 编辑
    @coolhhh
    大佬您好,感谢您的指导,以下我对于没说清楚的点的一些解释:
    1、是的,我是计算的复杂地形上的建筑绕流,,但是不确定是否为URANS,我刚刚接触CFD,还没有具体学过湍流求解方法,现在选择RAS只是想先跑出结果;
    2、top面设置为速度入口,是因为我的研究区域,top、west、east、south、north面的速度都是已知的,因此把top面速度条件也给加进去了(理论上应该把除地面外的五个面都设置好初始速度),我要做的工作就是把大尺度的风速给细化,得到研究区域区域内小尺度的风速;
    3、zeroGradient这个条件也试过,但是还是发散,经过今天的学习,我认为是k文件epsilon文件的初始值也需要更改,准备以后测试一下。
    最后再次感谢大佬的耐心指导!(刚接触CFD,可能对于一些问题的解释并不是很清楚)
    wsy11
    李老师您好,我刚实操OpenFOAM,不太确定是否为您说的单向流求解器:
    1、我的研究区域top、west、east、south、north面的速度都是已知的,因此理论上应该把除地面外的五个面都设置好初始速度,我要做的工作就是把大尺度的风速给细化,得到研究区域区域内小尺度的风速(即复杂地形的建筑物扰流);
    2、我也认为是湍流的边界条件问题,今天学习后发现可能是因为将入口设置为时变的非均匀速度条件后,并没有改变k文件和epsilon文件对应点位的值(如上边对应文件所示,k和epsilon只是简单的设置成了fixedValue);
    3、李老师,想请问您一个问题:如果设置好入流面一个点的(u,v,w)后,这个点的脉动速度分别为(0.05u,0.05v,0.05w)吗?对于下面图中的k和速度场U的关系不是很理解
    coolhhh 神
    在 中回复了 wsy11 最后由 编辑
    @wsy11
    1. URANS(Unsteady Reynolds-Averaged Navier-Stokes)就是用RANS湍流模型+瞬态求解器(pisoFoam,pimpleFoam),如果用simpleFoam求解器就是稳态,就不应该用时变的边界
    2. 没有试过其他5个面都设置速度入口。因为算的不可压缩湍流,我的理解是要能计算至少得满足5个面在每个瞬时的通量总和等于0,即流入等于流出。没看过有人这么设置过,一般都会设置个出口,通过计算自动调整出口的通量,使得满足不可压缩条件
    3. 既然算瞬态,可以用LES模拟,采用WALE湍流模型,0文件夹只需要设置p,U,nut
    4. 建议先拿一个简单的长方体空风洞开始,先测试只有1个速度入口+1个出口(侧面和顶面用symmetry),再测试2个速度入口+2个出口(顶面用symmetry),依次增加速度入口个数测试,最后才是看5个面都是速度入口能否算
    wsy11
    @coolhhh
    大佬您好,我可能忘了介绍我的研究时段了,我研究的是较长时间的模拟,理想模拟时间应该是2-3天;模拟区域也比较大,大概为长宽高为6km6km600m。
    1、因为研究的时间较长,所以每个边界的风速肯定是变化的(风速输入用的是每个边界所设置的非均匀分布风塔的观测数据,每个面都有数个观测点,观测数据风速利用timeVaryingMappedFixedValue每隔十分钟输入)因为之前学习了windaroundbuildings这个算例(也是建筑扰流),所以设置求解器为simpleFoam,这个算例风速确实是时不变的,这一点没有考虑到,等换成瞬时求解器试试;
    2、目前还没有试过五个入流面,因为我也认为可能不太符合通量守恒,所以先设置了3个速度入口和2个出口,我先做一下大佬在4中提供的建议;
    3、LES模拟也考虑过,正在学习,等做完2中试验后尝试一下大佬提供的条件,就不用计算k和epsilon文件的设置了。
