  3. 一个关于函数fvMatrix<Type>::H()函数的疑惑
7 帖子 2 发布者 3.1k 浏览
    AppleKiller
    代码如下,主要的疑惑点是这个for循环中的几行代码,我做了一些注释;首先调用函数addBoundaryDiag(boundaryDiagCmpt, cmpt);将边界条件对矩阵的影响系数取相反数并赋值给boundaryDiagCmpt场,然后调用函数addCmptAvBoundaryDiag(boundaryDiagCmpt);,不是很理解这几行代码做了一件什么事?希望各位大佬解惑!
    template<class Type>
    Foam::tmp<Foam::GeometricField<Type, Foam::fvPatchField, Foam::volMesh>>
    Foam::fvMatrix<Type>::H() const
        tmp<GeometricField<Type, fvPatchField, volMesh>> tHphi
            new GeometricField<Type, fvPatchField, volMesh>
                IOobject
                    "H("+psi_.name()+')',
                    psi_.instance(),
                    psi_.mesh(),
                    IOobject::NO_READ,
                    IOobject::NO_WRITE
                psi_.mesh(),
                dimensions_/dimVol,
                extrapolatedCalculatedFvPatchScalarField::typeName
        GeometricField<Type, fvPatchField, volMesh>& Hphi = tHphi.ref();
        // Loop over field components
        for (direction cmpt=0; cmpt<Type::nComponents; cmpt++)
            scalarField psiCmpt(psi_.primitiveField().component(cmpt));
            scalarField boundaryDiagCmpt(psi_.size(), Zero); // 定义一个全 0 的scalarField
            addBoundaryDiag(boundaryDiagCmpt, cmpt);	 // 边界条件对矩阵系数的影响(系数此时并未加到矩阵上)
            boundaryDiagCmpt.negate();		         // 对boundaryDiagCmpt场赋值为其相反数
            Hphi.primitiveFieldRef().replace(cmpt, boundaryDiagCmpt*psiCmpt);
        return tHphi;
    对应的addCmptAvBoundaryDiag(boundaryDiagCmpt);函数和其调用的cmptAv(internalCoeffs_[patchi])函数的代码如下
    void Foam::fvMatrix<Type>::addCmptAvBoundaryDiag(scalarField& diag) const
        for (label fieldi = 0; fieldi < nMatrices(); fieldi++)
            const auto& bpsi = this->psi(fieldi).boundaryField();
            forAll(bpsi, ptfi)
                const label patchi = globalPatchID(fieldi, ptfi);
                if (patchi != -1)
                    addToInternalField
                        lduAddr().patchAddr(patchi),
                        cmptAv(internalCoeffs_[patchi]),
                        diag
    template<class Form, class Cmpt, direction Ncmpts>
    inline Cmpt cmptAv
        const VectorSpace<Form, Cmpt, Ncmpts>& vs
        return cmptSum(vs)/Ncmpts; // 好像是 (vs[0] + vs[1] + vs[2])/3
    考虑对流项$\nabla\cdot(\bfU\bfU)$,离散后为$\sum_f (F_f\bfU_f)$,如果是内部面,这个$f$包含了所有的面。如果是边界面,对流项$\nabla\cdot(\bfU\bfU)$离散后为$\sum_{f_{内部}} (F_{f_{内部}}\bfU_f)+F_{边界}\bfU_{边界}$。
    首先对于$\sum_{f_{内部}} (F_{f_{内部}}\bfU_f)$,不管对于哪个速度分量,$F_{f_{内部}}$是固定的,所以针对每个分量离散出来的是这样:
    \sum_{f_{内部}} (F_{f_{内部}}\bfU_f)=
    \begin{pmatrix}
    \sum_{f_{内部}} (F_{f_{内部}} u_f)\\
    \sum_{f_{内部}} (F_{f_{内部}} v_f)
    \end{pmatrix}
    主要是其矩阵系数是一样的。这部分系数进入的是OpenFOAM中的lower以及upper元素。
    对于$F_{边界}\bfU_{边界}$。这部分系数进入的是internalCoeff以及boundaryCoeff,有多少个patch,internalCoeff里面就有多少个场数据。比如网格有3个边界,那么internalCoeff可能就是这样:
    3
    (第1组数据 对应第1个边界的数据)
    (第2组数据 对应第2个边界的数据)
    (第3组数据 对应第3个边界的数据)
    boundaryCoeff同样如此。
    继续考虑这个$F_{边界}\bfU_{边界}$。一般在给求解器的时候,是类似这种:fvm::div(phi, U),很明显phi已经是显性的值。因此对于$F_{边界}\bfU_{边界}$:
    • 如果给定的是固定值速度边界,$F_{边界}$已知,同时$\bfU_{边界}$已知,因此$F_{边界}\bfU_{边界}$的影响全部进入到boundaryCoeff。internalCoeff没有变化。
    • 如果给的是零法向梯度,$F_{边界}$是从U的网格点赋值相等过来,也是已知。$\bfU_{边界}$与内部网格点的值相同。具体多少取决于内部网格点。因此可以将其写为$\bfU_{边界}=\bfU_{内网格点}$,这样离散后,就存在内网格点的$\bfU$,因此会改变矩阵的对角线系数internalCoeff。但对边界boundaryCoeff没有影响。
    因为固定值边界对internalCoeff不影响,现在考虑零法向梯度$F_{边界}\bfU_{边界}$对矩阵的影响。假定对于某个边界面的内网格速度$u=1,v=0$。在这种情况下,$F_{边界}\bfU_{边界}$将使得u方程的矩阵以及v方程的矩阵发生区别。如果u变量与v变量的矩阵不一样,如果有代码fvVectorMatrix UEqn,那么理论上应该区分为u矩阵以及v矩阵。
    但是OpenFOAM里面只有一个矩阵对角线。首先,对于一套网格系统的内部面,$\sum_f (F_f\bfU_f)$是固定的,因此u与v的矩阵系数一样。因为内部面是大多数。因此可以认为u矩阵以及v矩阵大部分元素相同。也就是这个矩阵的lower以及upper是相同的。
    但是边界的印象会导致不同。那么是否需要组建3个矩阵?目前来看OpenFOAM没有这么做。为了将u分量v分量的矩阵相同化,他把边界导致的系数的影响做了个平均。加到了矩阵的对角线元素上。也就是D()函数。
    深入看一下D()函数,代码这样:
    void fvMatrix<Type>::addCmptAvBoundaryDiag(scalarField& diag) const
        forAll(internalCoeffs_, patchI) //对每一个边界,都处理这个边界的internalCoeffs_
            addToInternalField//假如针对某个零法向梯度速度边界
                lduAddr().patchAddr(patchI),  // 这个边界的网格单元的面对应的内部网格单元编号
                cmptAv(internalCoeffs_[patchI]),  // 对这个patch上的internalCoeffs_,进行三个方向的平均,形成一个。
                //比如原来internalCoeffs_可能是(1,2,0), (1,2,0), (1,2,0),做完了之后成为了(1.5), (1.5), (1.5)
                diag//原本的对角线元素的贡献。加上考虑内部网格单元编号,与cmptAv的操作,形成一个新的internalCoeffs_的贡献
                //也就是原本对角线元素 + 平均后internalCoeffs_的贡献
    所以主要是这个D()函数,里面有一个平均后的操作,这样不同分量的D()都是一套。进一步的,A()函数就是简单的D()/V,因此对于UEqn.A(),其实只有一套矩阵系数,而不是3套矩阵系数。
    同理,针对H()函数,首先要进行类似D()函数的操作,比如下面的代码,就是简单的把平均后internalCoeffs_的贡献,乘以psi的值,就表示边界internalCoeffs_对H的贡献。在这个阶段,不同分量的H都是一样的。
            scalarField psiCmpt = psi_.internalField().component(cmpt);
            scalarField boundaryDiagCmpt(psi_.size(), 0.0);
            tHphi().internalField().replace(cmpt, boundaryDiagCmpt*psiCmpt);
    下面这个代码,就是好理解的内网格+源项,就是 http://dyfluid.com/piso.html 里面的$\mathbf{HbyA}$还没除A的时候。
    tHphi().internalField() += lduMatrix::H(psi_.internalField()) + source_;
    另外,边界不是也会影响boundaryCoeffs_么(只不过咱们这个讨论没变化)。但对于其他的情况,也要把boundaryCoeffs_对H()的影响考虑进来。就有下面的代码:
    addBoundarySource(tHphi().internalField());
    好。那这样写,是不是就不准了?也不是。你看看这个东西影响的是$\mathbf{HbyA}$。作为一个迭代算法,中间变量多多少少问题都不大。重要的是最后的phi是不是通量守恒了。以及最终的速度分量,是不是满足动量方程。如果phi守恒,并且我们的动量方程也根本没有调用$\mathbf{HbyA}$(UEqn是怎么写的?)。所以没问题。
    不知不觉竟然写了这么多。
    A 2 条回复 最后回复
    AppleKiller
    谢谢李老师,打了这么多字!我好好消化下
    AppleKiller
    @李东岳 老师,看了你的回复,我重新理了一下,我利用一个小栗子并结合代码来看哈
        return tHphi;
    假设Patch1的internalCoeffs_是(1 2 3);那么通过for循环中的这两行代码计算出来
    计算出来的boundaryDiagCmpt(对应for循环中cmpt分别为0,1,2)中Patch1索引对应的值为-1,-2,-3.
    再通过代码
    此时boundaryDiagCmpt(对应for循环中cmpt分别为0,1,2)中Patch1索引对应的值为1,0,-1
    然后再执行代码
    是这样对吗?
    针对某个具体的patch,比如patch1,如果是速度的话,internalCoeffs_应该是
    (1 2 3)
    (2 3 4)
    (3 4 5)
    每个都有3个分量,这才能跟速度3个分量对上。
    我仔细处理这个问题,就是因为如果对速度离散乘fvVectorMatrix的话,应该是3套系数(边界的影响)。但是OpenFOAM明显用的是一套矩阵系数,因为UEqn.A()、UEqn.D()都是一个。原因就在你主贴的疑问里面。之前这方面我还没细看。后来发现就是internalCoeffs_给平均了。你主贴里面问了个平均的操作cmptAv。比如上面这个internalCoeffs_明显3个分量不一样,这就需要三套系数。但是OpenFOAM给平均了:
    (1+2+3)/3
    (2+3+4)/3
    (3+4+5)/3
    就变成了一套系数。
    目前这个平均操作,我并不觉得有理论依据。就是简单平均话了。我认为的原因在上个帖子里面也讨论了。我认为就是这样(不影响收敛)。
    其他你写的我也没太看懂..
    AppleKiller
    @李东岳 老师,您说的这些我大概都清楚了(关于cmptAv函数部分),其实我的目前更想知道的是为什么在addCmptAvBoundaryDiag(boundaryDiagCmpt);这行代码之前需要先执行
    这两行代码呢?
    请参考:
    H操作符是把矩阵系数移到右边。下面的上下对角线移到右边都取负。边界导致的对角线移到右边,也要取负。
    for (register label face=0; face<l.size(); face++)
                Hphi[u[face]] -= Lower[face]*sf[l[face]];//取负
                Hphi[l[face]] -= Upper[face]*sf[u[face]];//取负
