  4. 多相流计算出现局部高压点
多相流计算出现局部高压点
10 帖子 3 发布者 9.6k 浏览
    HIT_lly
    本文在使用compressibleInterIsoFoam进行过膨胀喷管的水下射流计算。开始计算较为稳定无异常情况发生。但是在换个电脑(从另一个电脑copy算例到其他电脑上)进行计算的时候出现了不正常的现象。在射流出口出现了不正常的局部高压,导致计算不稳定,报错内容是计算出现负温度。
    这是报错内容
    这是出现局部高压过程的压力云图。
    时间分别是21.2ms,21.25ms,21.3ms
    该算例的fvScheme文件和fvSolution文件如下。
    |  \\    /   O peration     | Version:  v2212                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSchemes;
    ddtSchemes
        default         Euler;
    gradSchemes
        default         Gauss linear;
    limited         cellLimited Gauss linear 1;
        grad(U)         $limited;
        grad(k)         $limited;
        grad(omega)     $limited;
    divSchemes
        div(phi,alpha)  Gauss vanLeer;
        div(phirb,alpha) Gauss upwind;
      div(phi,thermo:rho.water) Gauss upwind;
        div(phi,thermo:rho.air) Gauss upwind;
    div(Phirb,alpha)  Gauss interfaceCompression;
        div(rhoPhi,U)  Gauss limitedLinearV 1;
        div(rhoPhi,T)  Gauss upwind;
        div(rhoPhi,K)  Gauss upwind;
        div(phi,p)      Gauss upwind;
        div(phi,k)      Gauss upwind;
    default         Gauss upwind;
        div(phi,U)      Gauss linearUpwind limited;
        energy          Gauss linearUpwind limited;
        div(phi,e)      $energy;
        div(phi,K)      $energy;
        div(phi,Ekp)    $energy;
        turbulence      Gauss linearUpwind limited;
        div(phi,k)      $turbulence;
        div(phi,omega)  $turbulence;
        div(rhoPhi,omega)  $turbulence;
    div(rhoPhi,k)  $turbulence;
        div(phiv,p)     Gauss upwind;
        div((phi|interpolate(rho)),p) Gauss upwind;
    laplacianSchemes
    interpolationSchemes
        default         linear;
    snGradSchemes
        default         corrected;
    wallDist
        method          meshWave;
    这是fvSolution文件
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvSolution;
    solvers
        "alpha.water.*"
             nAlphaCorr      1;
            nAlphaSubCycles 5;
            cAlpha          1;
            reconstructionScheme isoAlpha;
            vof2IsoTol 1e-8;
            surfCellTol 1e-8;
            nAlphaBounds    3;
            snapTol         1e-12;
            clip            true;
            minIter         1;
        "pcorr.*"
            solver          GAMG;
            preconditioner
                preconditioner  GAMG;
                tolerance       1e-12;
                relTol          0.00001;
            nSweeps         4;
                smoother        DICGaussSeidel;
            tolerance       1e-12;
            relTol          0.00001;
            nSweeps         2;
            maxIter         100;
            smoother        GaussSeidel;
            minIter         1;
        ".*(rho|rhoFinal)"
            solver          diagonal;
            minIter         1;
        p_rgh
            solver          GAMG;
            tolerance       1e-14;
            relTol          0.00000001;
            nSweeps         4;
            minIter         2;
        p_rghFinal
            solver          GAMG;
            preconditioner
                tolerance       1e-14;
                relTol          0.0000001;
                nSweeps         4;
                nVcycles        2;
                nPreSweeps      2;
            tolerance       1e-14;
            relTol          0.0000001;
            nSweeps         3;
            maxIter         100;
            minIter         2;
        U
            solver          smoothSolver;
            tolerance       1e-10;
            relTol          0.00001;
            nSweeps         2;
            minIter         1;
    UFinal
            tolerance       1e-10;
            relTol          0.00001;
            nSweeps         2;
            minIter         1;
        "(T|k|B|nuTilda).*"
            tolerance       1e-12;
            relTol          0.00001;
            nsweeps         2;
            limit           10.0;
            maxIter         100;
            minIter         1;
    p
            solver          GAMG;
            tolerance       1e-10;
            relTol          0.0000001;
            nsweeps         2;
            minIter         1;
    "(U|e).*"
            $p;
            tolerance       1e-9;
        "(k|epsilon).*"
            $p;
            tolerance       1e-10;
        pFinal
            $p;
            relTol          0.000001;
            nSweeps         2;
            minIter         1;
        "(rho|U|k|omega|e)"
            solver          PBiCGStab;
            preconditioner  DILU;
            tolerance       1e-10;
            relTol          0.001;
            nSweeps         2;
            minIter         1;
        "(rho|U|k|omega|e)Final"
            $U;
            relTol          0.00001;
            nSweeps         2;
            minIter         1;
    SIMPLE
        residualControl
            p               1e-8;
            U               1e-8;
            "(k|omega|e)"   1e-8;
        nNonOrthogonalCorrectors 1;
        pMinFactor      0.3;
        pMaxFactor      1;
    PIMPLE
          momentumPredictor yes;
        transonic       yes;
        nOuterCorrectors 10;
        nCorrectors     6;
        nNonOrthogonalCorrectors 5;
    nAlphaCorr 1;
        nAlphaSubCycles 3;
        CAlpha 1;
     pMin      10000;
        pMax      1000000;
    relaxationFactors
        equations
            ".*"     0.1;
    这个可压缩算例的负温负压不太好处理,没有一个方法说只要改一个东西就能解决的。openfoam有一些limitTemp,limitP的作用也有限。大概率只能你自己去调试。不过你瞬态为什么加松弛?然而反过来如果你不加松弛可能会更早就发散了。
    H 1 条回复 最后回复
    HIT_lly
    @李东岳 谢谢东岳老师的回复,我再重新调试调试
  • 1 离线
    1 离线
    15735420621
    您好,发散问题您解决了吗,我也遇到了这个问题,这个求解器一直发散
    H 1 条回复 最后回复
    HIT_lly
    在 中回复了 15735420621 最后由 编辑
    @15735420621 没有调试成功,我换了入口的边界调节入口由之前的零梯度换成了固定值,这样好像会好一点,但是也不知道会在什么时候发散,感觉很神奇。
    1 1 条回复 最后回复
    非涉密算例可以上传上来我可以调一下。但是网格要小。
    H 1 条回复 最后回复
    HIT_lly
    非常感谢东岳老师的回复,这个算例可能有点大,现在换成固定值入口条件了,到现在还没挂,还正在计算,还算稳定没有出现局部异常情况。
  • 1 离线
    1 离线
    15735420621
    在 中回复了 HIT_lly 最后由 编辑
    @HIT_lly 是将温度改为固定值了吗,还是入口的其他条件呢
    H 1 条回复 最后回复
    HIT_lly
    @15735420621 把入口温度条件改成固定温度了,如果用zerogradien的话会在入口边界上产生巨大的温度梯度,导致算例崩溃,但是改成固定值后会稍微好点,但是也会产生负温度,但是将库郎数调整到0.75以下就可以算过去。
    1 1 条回复 最后回复
  • 1 离线
    1 离线
    15735420621
    @HIT_lly 好的,谢谢!我试试
