  3. 求助:interDyMFoam自适应网格问题
1 帖子 1 发布者 1.0k 浏览
  • 小 离线
    小 离线
    小刘lyw
    各位大佬好,我是CFDEM新手,最近尝试参照twoSpheresGlowinskiMPI构建自己的算例,采用dynamicRefine,在计算过程中断构建的算例基本与参照算例一致,但试跑算例出现中断,不知道是否是哪里没有注意到,求大佬指导
    报错描述
    当不使用自适应网格时,算例正常计算;当采用自适应网格功能interDyMFoam,网格未加密前(未达到设置加密条件),正常计算;网格开始加密计算中断。
    报错代码如下:
    Time = 0.0001
    Selected 0 cells for refinement out of 1613716.
    Selected 0 split points out of a possible 0.
    Courant Number mean: 0.000199582 max: 0.0804916
    - evolve()
     timeStepFraction() = 2
    Starting up LIGGGHTS
    Executing command: 'run 10    '
    Setting up run at Fri Jul 26 12:59:28 2024
    Memory usage per processor = 6.75634 Mbytes
    Step    Atoms         KinEng            rke         Volume       dragtota       dragtota       dragtota
       1        1  2.5261073e-08              0      0.0260508              0              0              0
    CFD Coupling established at step 10
      11        1  3.5918126e-08              0      0.0260508              0              0              0
    Loop time of 0.000962037 on 16 procs for 10 steps with 1 atoms, finish
    time Fri Jul 26 12:59:28 2024
    Pair  time (%) = 4.70437e-06 (0.489001)
    Neigh time (%) = 0 (0)
    Comm  time (%) = 4.65044e-06 (0.483395)
    Outpt time (%) = 6.52643e-05 (6.78397)
    Other time (%) = 0.000887418 (92.2436)
    Nlocal:    0.0625 ave 1 max 0 min
    Histogram: 15 0 0 0 0 0 0 0 0 1
    Nghost:    0 ave 0 max 0 min
    Histogram: 16 0 0 0 0 0 0 0 0 0
    Neighs:    0 ave 0 max 0 min
    Total # of neighbors = 0
    Ave neighs/atom = 0
    Neighbor list builds = 0
    Dangerous builds = 0
    LIGGGHTS finished
    Foam::cfdemCloudIB::reAllocArrays()
    nr particles = 1
    evolve done.
    DILUPBiCG:  Solving for Ux, Initial residual = 1, Final residual = 1.06984e-07, No Iterations 1
    DILUPBiCG:  Solving for Uy, Initial residual = 1, Final residual = 4.99282e-07, No Iterations 1
    DILUPBiCG:  Solving for Uz, Initial residual = 1, Final residual = 6.95219e-10, No Iterations 2
    DICPCG:  Solving for p, Initial residual = 1, Final residual = 9.26695e-07, No Iterations 573
    time step continuity errors : sum local = 3.69904e-10, global = -1.28591e-13, cumulative = -1.28591e-13
    DICPCG:  Solving for p, Initial residual = 0.0476412, Final residual = 9.26405e-07, No Iterations 513
    time step continuity errors : sum local = 3.16922e-08, global = -3.49546e-12, cumulative = -3.62406e-12
    DICPCG:  Solving for p, Initial residual = 0.0055667, Final residual = 9.51869e-07, No Iterations 500
    time step continuity errors : sum local = 3.3706e-08, global = -6.10801e-12, cumulative = -9.73206e-12
    DICPCG:  Solving for p, Initial residual = 0.00178549, Final residual = 9.94251e-07, No Iterations 473
    time step continuity errors : sum local = 3.53268e-08, global = -5.71629e-12, cumulative = -1.54484e-11
    particleCloud.calcVelocityCorrection()
    DICPCG:  Solving for phiIB, Initial residual = 1, Final residual = 9.63924e-07, No Iterations 501
    ExecutionTime = 30.7 s  ClockTime = 32 s
    Time = 0.0002
    Selected 784 cells for refinement out of 1613716.
    Refined from 1613716 to 1619204 cells.
    Selected 0 split points out of a possible 784.
    Courant Number mean: 0.126921 max: 9.46381
    - evolve()
    Setting up run at Fri Jul 26 12:59:56 2024
    11        1  3.5918126e-08              0      0.0260508              0              0    0.017347056
    CFD Coupling established at step 20
      21        1  3.6972707e-08              0      0.0260508              0              0    0.017347056
    Loop time of 0.00149142 on 16 procs for 10 steps with 1 atoms, finish time Fri Jul 26 12:59:56 2024
    Pair  time (%) = 3.75399e-06 (0.251706)
    Comm  time (%) = 3.65471e-06 (0.24505)
    Outpt time (%) = 8.7527e-05 (5.86871)
    Other time (%) = 0.00139648 (93.6345)
    Ave neighs/atom = 0
    LIGGGHTS finished
    nr particles = 1
    MPI_ABORT was invoked on rank 15 in communicator MPI_COMM_WORLD
    with errorcode 1.
    NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
    You may or may not see output from other processes, depending on
    exactly when Open MPI kills them.
