  3. foam-extend-4.0 移植重叠网格 wmake编译报错
6 帖子 3 发布者 2.8k 浏览
  • G 离线
    G 离线
    Gunther
    由于特殊原因需要将fe41中的src/overset和求解器植入fe40。
    目前已经完成src/overset目录下两个文件夹:oversetDynamicFvMesh和oversetMesh的编译,至少wmake libso没有报错。
    然而,在编译pimpleDyMOversetFoam求解器时,报错:
    Making dependency list for source file pimpleDyMOversetFoam.C
    could not open file crMatrix.H for source file pimpleDyMOversetFoam.C
    SOURCE=pimpleDyMOversetFoam.C ;  g++-5 -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/gunther/foam/foam-extend-4.0/src/dynamicMesh/dynamicFvMesh/lnInclude     -I/home/gunther/foam/foam-extend-4.0/src/dynamicMesh/dynamicMesh/lnInclude     -I/home/gunther/foam/foam-extend-4.0/src/meshTools/lnInclude     -I/home/gunther/foam/foam-extend-4.0/src/turbulenceModels/incompressible/turbulenceModel     -I/home/gunther/foam/foam-extend-4.0/src/transportModels     -I/home/gunther/foam/foam-extend-4.0/src/transportModels/incompressible/singlePhaseTransportModel     -I/home/gunther/foam/foam-extend-4.0/src/finiteVolume/lnInclude     -I/home/gunther/foam/gunther-4.0/src/overset/oversetMesh/lnInclude     -I/home/gunther/foam/gunther-4.0/src/overset/oversetDynamicFvMesh/lnInclude -IlnInclude -I. -I/home/gunther/foam/foam-extend-4.0/src/foam/lnInclude -I/home/gunther/foam/foam-extend-4.0/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPOpt/pimpleDyMOversetFoam.o
    In file included from /home/gunther/foam/gunther-4.0/src/overset/oversetMesh/lnInclude/oversetFvPatch.H:39:0,
                     from /home/gunther/foam/gunther-4.0/src/overset/oversetMesh/lnInclude/oversetFvPatchField.H:40,
                     from /home/gunther/foam/gunther-4.0/src/overset/oversetMesh/lnInclude/oversetFvPatchFields.H:29,
                     from pimpleDyMOversetFoam.C:43:
    /home/gunther/foam/gunther-4.0/src/overset/oversetMesh/lnInclude/oversetLduInterface.H:44:22: fatal error: crMatrix.H: No such file or directory
    compilation terminated.
    pimpleDyMOversetFoam.dep:796: recipe for target 'Make/linux64GccDPOpt/pimpleDyMOversetFoam.o' failed
    make: *** [Make/linux64GccDPOpt/pimpleDyMOversetFoam.o] Error 1
    但是我在oversetLduInterface.H:中已经包含crMatrix.H,并且在Make/options中也包含了crMatrix.H的路径,并且在之前oversetDynamicFvMesh和oversetMesh的编译中没有报错。
    oversetMesh/Make/options内容如下:
    EXE_INC = \
        -I$(LIB_SRC)/surfMesh/lnInclude \
        -I$(LIB_SRC)/sampling/lnInclude \
        -I$(LIB_SRC)/lduSolvers/lnInclude
    EXE_LIBS = \
        -lfiniteVolume \
        -lmeshTools \
        -lsurfMesh \
        -lsampling \
        -llduSolvers
    src/overset/oversetMesh/lnInclude/oversetLduInterface.H部分代码如下:
    #ifndef oversetLduInterface_H
    #define oversetLduInterface_H
    #include "lduInterface.H"
    #include "primitiveFieldsFwd.H"
    #include "crMatrix.H"
    跪求大佬指点,救救孩子!
    直接把crMatrix.H的绝对路径写到EXE_INC里试试
    G 1 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    @bestucan 感谢大佬!想详细了解一下,为什么我在overset的库中已经include了,但在编译solver时还需要include呀?
    bestucanB 1 条回复 最后回复
    在 中回复了 Gunther 最后由 编辑
    @Gunther 已经include?你是说在源代码里写的包含头文件那句代码?
    你知道那个文件在哪,但是gcc不知道,所以得在options里写明,头文件的位置,和库文件的位置。
    头文件可以让gcc知道有哪些函数可用,头文件一般都是函数声明。库文件定义函数如何运行。所以位置都得指明。
    那些个IDE有的设定好了,把这些细节藏起来了。
    至于为什么你的options文件没有发挥作用,我看你也没把overset的头文件写进包含里呀,具体怎么写不知道,但大概应该像这个的最后一行,地址不一定对,那你觉得你之前的option文件里,第几行包含了overset的头文件呢?
    EXE_INC = \
        -I$(LIB_SRC)/lduSolvers/lnInclude \
        -I$(LIB_SRC)/overset/lnInclude
    G 李东岳李 2 条回复 最后回复
  • G 离线
    G 离线
    Gunther
    @bestucan 大佬你好!感谢你的耐心解答,options那里我拿用绝对路径写就通过编译了。
    @bestucan 在 foam-extend-4.0 移植重叠网格 wmake编译报错 中说:
    这句话十分受用,感谢感谢!
    @bestucan :146: :146: :146:
