  4. openFOAM codedFixedValue边界条件中调用标量场的问题
3 帖子 2 发布者 1.9k 浏览
    L_LL
    我尝试将of2306的jouleHeating算例中的jouleHeating::V从恒定电压改为恒定电流设置,因此想要通过电流乘以电阻来计算电压,其中电阻的设置涉及到电导率,而这个电导率是随着温度的变化变化的,所以想要读取标量场中的电导率(sigma)数据。
    以下是sigma设置
    |  \\    /   O peration     | Version:  v2206                                 |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      fvOptions;
    heating
        type            jouleHeatingSource;
        active          true;
        jouleHeatingSourceCoeffs
            anisotropicElectricalConductivity no;
            // Optionally specify sigma as a function of temperature
            //sigma           127599.8469;
            sigma           table
                (273      59600000)
                (298      58000000)
                (500      32000000)
    下面是我写的codedFixedValue边界条件
    boundaryField
        inlet
            value           uniform 0;// 初始值,可以为0或其他合理的数值
            name            dynamicV;
            codeInclude
        	    #include "mathematicalConstants.H"
        	    #include "fvCFD.H"
        	codeOptions
       	codeLibs
       		-lmeshTools \
       		-lfiniteVolume
           code
                const fvMesh& mesh = this->patch().boundaryMesh().mesh();
    	    dictionary C = mesh.lookupObject<dictionary>("fvOptions");
                // 定义常数
                scalar I = 0.6;
                scalar L = 0.007875;
                scalar A = 1.125e-8;
       	    const volScalarField& sigma = mesh.lookupObject<volScalarField>("sigma");
    	    scalar sigma = gMax(sigma);
                // 计算电阻
                scalar R = L / (sigma * A);
                // 计算电压,确保恒定电流 I
                scalar V =  I * R;
    	    Info << "V: " << V << endl;
    	    Info << "R: " << R << endl;
    	    Info << "sigma: " << sigma << endl;
                // 将计算出的电压值作为边界条件
                operator==(V);
        outlet
            type            fixedValue;
            value           uniform 0;
    这样的写法会出现
    Failed wmake "dynamicCode/dynamicV/platforms/linux64GccDPInt32Opt/lib/libdynamicV_c6587780c1810df06b6735b285db38c4418d36ec.so"
    file: 0/solid/jouleHeatingSource:V.boundaryField.inlet at line 28 to 47.
        From void Foam::codedBase::createLibrary(Foam::dynamicCode&, const Foam::dynamicCodeContext&) const
        in file db/dynamicLibrary/codedBase/codedBase.C at line 245.
    FOAM exiting
    code_text
    但是如果我把上面的sigam换成T又是可以运行的,想问问大家知道我该如何去写这段代码吗
    这一行换成T就可以了么?
    L 1 条回复 最后回复
    L_LL
    @李东岳 是的,这里换成T后下面的scalar T = gMax(T)函数也可以正常使用
