  4. openfoam动网格加密后 计算很慢
openfoam动网格加密后 计算很慢
5 帖子 2 发布者 3.6k 浏览
  • E 离线
    E 离线
    Emrys
    写于 最后由 Emrys 编辑
    各位老师好,我在计算三维多相流流动时采用界面局部加密的动网格,发现时间步长特别小,界面局部加密后的网格67w时间步长1e-7 1e-8左右;
    而在全场加密1000w网格情况下计算是正常的时间步长1e-5;
    请问是局部加密非结构化网格的原因导致步长很小? 四面是周期性边界条件,因此采用了cyclicAMI的边界。
        \\  /    A nd           | Version:  8
         \\/     M anipulation  |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "constant";
        object      dynamicMeshDict;
    dynamicFvMesh   dynamicRefineFvMesh;
    // How often to refine
    refineInterval  1;
    // Field to be refinement on
    field           alpha.water;
    // Refine field in between lower..upper
    lowerRefineLevel 0.001;
    upperRefineLevel 0.999;
    // If value < unrefineLevel unrefine
    unrefineLevel   10;
    // Have slower than 2:1 refinement
    nBufferLayers   1;
    // Refine cells only up to maxRefinement levels
    maxRefinement   2;
    // Stop refinement if maxCells reached
    maxCells        20000000;
    // Flux field and corresponding velocity field. Fluxes on changed
    // faces get recalculated by interpolating the velocity. Use 'none'
    // on surfaceScalarFields that do not need to be reinterpolated.
    correctFluxes
        (phi none)
        (nHatf none)
        (rhoPhi none)
        (alphaPhi0.water none)
        (ghf none)
    // Write the refinement level as a volScalarField
    dumpLevel       true;
    |  \\    /   O peration     | Version:  2212                                     |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      blockMeshDict;
    convertToMeters 1;
    hN  1.01e-4;
    L   #calc "100*$hN";
    D   #calc "1.0*$hN";
    H   #calc "3.0*$hN";
    z   #calc "M_PI*$L";
    nX  100;
    nY  50;
    nZ  100;
    vertices
        (0  0  0) //0
        ($L 0  0) //1
        ($L $H 0) //2
        (0  $H 0) //3
        (0  0  $z) //4
        ($L 0  $z) //5
        ($L $H $z) //6
        (0  $H $z) //7
    blocks
        hex (0 1 2 3 4 5 6 7) ($nX $nY $nZ) simpleGrading (1 1 1)
    edges
    boundary
        movingWall
            type wall;
            faces
                (0 1 5 4)
        inlet
            type                  cyclicAMI;
            neighbourPatch        outlet;
            transform       translational;
            separationVector ($L 0 0);
            faces
                (0 4 7 3)
        outlet
            type                  cyclicAMI;
            neighbourPatch        inlet;
            separationVector (-$L 0 0);
            faces
                (1 5 6 2)
          atmosphere
            type patch;
            faces
                (3 2 6 7)
        front
            type cyclicAMI;
            neighbourPatch        back;
            separationVector (0 0 $z);
            faces
                (0 1 2 3)
        back
            type cyclicAMI;
            neighbourPatch        front;
            separationVector (0 0 -$z);
            faces
                (4 5 6 7)
    mergePatchPairs
  • E 离线
    E 离线
    Emrys
    网格是需要接近1:1:1加密吗?整个区域尺寸的比例约为1:300:100
    加密之后时间步长变小是必然的。网格变小,为了保证库朗数小,只能减小时间步长
    E 1 条回复 最后回复
  • E 离线
    E 离线
    Emrys
    @李东岳 谢谢李老师回复,可是全场加密下1000w网格跑的比局部加密67w网格快是不是不太合理:135:
    那是不太合理,可能你67万的要发散了
