  3. 构造UEqn的时候出错
构造UEqn的时候出错
1 帖子 1 发布者 528 浏览
    wliIPECAS
    构造UEqu的时候报错,编译可以通过,openfoam7版本,
    代码:
    fvVectorMatrix UEqn
                             fvm::ddt(rhoEff,U)
                             + fvm::div(Rhophi, U)
                             + fvc::div(rhoPhiR_PTRS)  // pseudo-turbulent Reynolds-stress
                             - fvm::laplacian(voidfraction*fluidViscosity, U)
                             - fvc::div(voidfraction*fluidViscosity*dev2(Foam::T(fvc::grad(U))))
                             - fvm::Sp(Ksl,U)
    运行到这的时候,报错:
    [GPU01:121865] *** An error occurred in MPI_Recv
    [GPU01:121865] *** reported by process [1419640833,1]
    [01:121865] *** on communicator MPI COMMUNICATOR 3 SPLIT FROM 0
    [GPU01:121865] *** MPI_ERR_TRUNCATE: message truncated
    [GPU01:121865] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
    [GPU01:121865] ***    and potentially your MPI job)
    [GPU01:121859] 2 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal
    [GPU01:121859] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
    大家有没有遇到过这样的问题?
