  4. buoyantPimpleFoam相关问题
91 帖子 5 发布者 84.7k 浏览
    Afr1yne
    在 中回复了 yjc95 最后由 编辑
    #81
    @yjc95 我也是新手 不是大佬
    案例中一般都取0.7 具体的你可以找找文献看
    Y 1 条回复 最后回复
    yjc95
    在 中回复了 Afr1yne 最后由 编辑
    #82
    @Afr1yne 谢谢您
    yjc95
    @李东岳 东子老师,新年好呀。我带着新问题来向您请教了。我用v2206版本下的heatTransfer-buoyantBoussinesqPimpleFoam-hotRoom作为模板来模拟储热池的放热过程,我把floor设置成低温水进口,把ceiling设置成高温水出口,采用层流,介质为水,算出来的结果温度场很奇怪,中间的斜温层很厚。
    我查阅文献,并且用fluent算出来的斜温层应该非常薄才对。
    此外,我把所有物性参数扩大和缩小1000倍,温度场没变化。
    具体设置如下:
    • alphat
    FoamFile
        version     2.0;
        format      ascii;
        class       volScalarField;
        object      alphat;
    internalField   uniform 0;
    boundaryField
        floor
            type            alphatJayatillekeWallFunction;
            Prt             0.1;
            value           uniform 0;
        ceiling
            Prt             0.1;
            value           uniform 0;
        fixedWalls
            Prt             0.1;
            value           uniform 0;
    • nut
    FoamFile
        version     2.0;
        format      ascii;
        object      nut;
    boundaryField
        floor
            value           uniform 0;
        ceiling
            value           uniform 0;
        fixedWalls
            value           uniform 0;
    • p
    FoamFile
        version     2.0;
        format      ascii;
        object      p;
    internalField   uniform 1e5;
    boundaryField
        floor
            type            zeroGradient;
        ceiling
            type            zeroGradient;
        fixedWalls
            type            zeroGradient;
    • p_rgh
    FoamFile
        version     2.0;
        format      ascii;
        object      p_rgh;
    boundaryField
        floor
            type            zeroGradient;
            rho             rhok;
        ceiling
            type            zeroGradient;
            rho             rhok;
        fixedWalls
            type            zeroGradient;
            rho             rhok;
    • T
    FoamFile
        version     2.0;
        format      ascii;
        object      T;
    internalField   uniform 363;
    boundaryField
        floor
            type            fixedValue;
            value           uniform 283;
        ceiling
            type            zeroGradient;
        fixedWalls
            type            zeroGradient;
    • U
    FoamFile
        version     2.0;
        format      ascii;
        class       volVectorField;
        object      U;
    boundaryField
        floor
            type            fixedValue;
            value           uniform (0 0.1 0);
        ceiling
            type            fixedValue;
        fixedWalls
            type            noSlip;
    • transportProperties
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      transportProperties;
    transportModel Newtonian;
    // Laminar viscosity
    nu              1e-06;
    // Thermal expansion coefficient
    beta            3e-04;
    // Reference temperature
    TRef            273;
    // Laminar Prandtl number
    Pr              7;
    // Turbulent Prandtl number
    Prt             0.1;
    • turbulenceProperties
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      turbulenceProperties;
    simulationType      laminar;
    RAS
        RASModel        kEpsilon;
        turbulence      on;
        printCoeffs     on;
    麻烦您抽空看看,谢谢您!
    把你的openfoam跟fluent的对比图放上来我看看
    Y 1 条回复 最后回复
    yjc95
    @李东岳 东子老师,我又检查了一遍fluent的设置,发现是我把速度入口数值设置错了,重新算了一遍,看上去好像也差不多。耽误您时间了,抱歉。
    yjc95
    @李东岳 东子老师,您在可压+瞬态里面写到"方程(20)构成一个稀疏线性系统。求解方程(20)即可获得速度a9b8d0f0-6c94-4824-9262-1a7bbb3dea13-CodeCogsEqn (1).svg "其中的d6f64072-4486-45f4-b8f3-9930ece5b338-CodeCogsEqn (2).svg 指的是相邻网格的速度,在这里是用当前时刻已知的速度代入么?同样的,方程(41)中的60da7cda-4eab-4525-9cbf-8e0de54d04dd-CodeCogsEqn (3).svg 应该是要求的控制体体心处的压力吧,293ac512-c651-49f9-b898-ed50d16dbdcc-CodeCogsEqn (4).svg 是否是用当前时刻各个面的压力代入,这个压力好像之前并不知道吧,是咋求出60da7cda-4eab-4525-9cbf-8e0de54d04dd-CodeCogsEqn (3).svg的呢?
    Y 1 条回复 最后回复
    yjc95
    在 中回复了 yjc95 最后由 编辑
    #87
    @李东岳 东子老师,我悟了,这俩问题我想明白了。我有新的疑问:方程(41)中的c62c291b-9ee1-45ee-a181-1b31bca08525-CodeCogsEqn (3).svg 和985c483d-f149-4d68-bcb8-6f2301cb89fe-CodeCogsEqn (4).svg 有啥联系呢?
    带f是定义在面上的
    Y 1 条回复 最后回复
    yjc95
    @李东岳 您的意思是,体心处的p是面心处p的某种函数,比如体心处的p=面心处的p的加权平均?
    面心的值是体心的值的插值
    Y 1 条回复 最后回复
    yjc95
    @李东岳 谢谢您
