  4. toposet之后出现空集。。。
toposet之后出现空集。。。
6 帖子 3 发布者 3.6k 浏览
  • 1 离线
    1 离线
    16c
    toposet之后polymesh下set文件夹的文件内全部显示是空集,终端显示识别了你的范围是XXX但是这个范围内狗der没有,我是真不到哪里出问题了。
    toposetdric代码是这样的:
    |  \\    /   O peration     | Version:  5                                     |
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      topoSetDict;
    actions
            name    porous;
            type    cellSet;
            action  new;
            source  boxToCell;
            sourceInfo
                box     (0 0 10) (2000 500 15);
            name    porousZone;
            type    cellZoneSet;
            action  new;
            source  setToCellZone;
            sourceInfo
                set porous;
            name    inletA;
            type    cellSet;
            action  new;
            source  boxToCell;
            sourceInfo
                box (0 0 15) (0.1 500 25);
            name    inletB;
            type    faceSet;
            action  new;
            source  cellToFace;
            sourceInfo
                set     inletA;
                option  all;
            name    inletB;
            type    faceSet;
            action  subset;
            source  patchToFace;
            sourceInfo
                name walls;
            name    outletA;
            type    cellSet;
            action  new;
            source  boxToCell;
            sourceInfo
                box (1999.9 0 15) (2000 500 50);
            name    outletB;
            type    faceSet;
            action  new;
            source  cellToFace;
            sourceInfo
                set     outletA;
                option  all;
            name    outletB;
            type    faceSet;
            action  subset;
            source  patchToFace;
            sourceInfo
                name walls;
    终端是这样说的:
    openfoam@openfoam-virtual-machine:~/OpenFOAM/openfoam-5.x/run/1$ topoSet
    |  \\    /   O peration     | Version:  5.x                                   |
    Build  : 5.x-7f7d351b741b
    Exec   : topoSet
    Date   : Nov 25 2024
    Time   : 09:45:57
    Host   : "openfoam-virtual-machine"
    PID    : 181025
    I/O    : uncollated
    Case   : /home/openfoam/OpenFOAM/openfoam-5.x/run/1
    nProcs : 1
    Create time
    Create polyMesh for time = 0
    Reading topoSetDict
    Time = 0
        mesh not changed.
    Created cellZoneSet porous
        Applying source boxToCell
        Adding cells with center within boxes 1((0 0 10) (2000 500 15))
        cellZoneSet porous now size 0
    Created cellSet inletA
        Adding cells with center within boxes 1((0 0 15) (0.1 500 25))
        cellSet inletA now size 0
    Created faceSet inletB
        Applying source cellToFace
        Adding faces according to cellSet inletA ...
        faceSet inletB now size 0
    Read set faceSet inletB with size 0
        Applying source patchToFace
        Adding all faces of patch walls ...
        Found matching patch walls with 31250 faces.
    Created cellSet outletA
        Adding cells with center within boxes 1((1999.9 0 15) (2000 500 50))
        cellSet outletA now size 0
    Created faceSet outletB
        Adding faces according to cellSet outletA ...
        faceSet outletB now size 0
    Read set faceSet outletB with size 0
    End
    blockMesh是这样的:
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      blockMeshDict;
    convertToMeters 0.001;
    vertices
        (0 0 0)                 // 0
        (2000 0 0)               // 1
        (2000 500 0)            // 2
        (0 500 0)              // 3
        (0 0 15)                // 4
        (2000 0 15)              // 5
        (2000 500 15)           // 6
        (0 500 15)             // 7
        (0 0 50)                // 4
        (2000 0 50)              // 5
        (2000 500 50)            // 6
        (0 500 50)             // 7
        // (0 0 25)                // 12
        // (0 500 25)              // 13
    blocks
        hex (0 1 2 3 4 5 6 7) (500 125 25) simpleGrading (1 1 1)
        // hex (4 5 6 7 8 9 10 11) (500 125 35) simpleGrading (1 1 1)
    edges
    boundary
        walls
            type wall;
            faces
                (0 1 5 4)
                (2 3 7 6)
                (0 4 7 3)
                (1 2 6 5)
        atmosphere
            type patch;
            faces
                (4 5 6 7)
                (0 1 2 3)
    mergePatchPairs
    我搞这个破玩意好几天了,一点头绪没有,还得求着各位大佬帮帮忙瞅一眼。。。。
    1 1 条回复 最后回复
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    你blockMesh文件convertToMeters 0.001;
    实际就是把下面的坐标乘以0.001画网格,画出来的计算域是(0,0,0)到(2,0.5,0.05)。
    而你toposet直接从(0,0,10)开始画box,当然找不到了。
  • 1 离线
    1 离线
    16c
    在 中回复了 16c 最后由 编辑
    @学流体的小明 在 toposet之后出现空集。。。 中说:
    大哥 按你说的改了topoSetDric , box的坐标和网格尺寸我也确定了是能对应上的,但是createPatch并ParaFoam之后出现了inlet这个面变成了豁牙子。。。
    改之后的topoSet是这样的:
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        location    "system";
        object      topoSetDict;
    actions
            name    porous;
            type    cellSet;
            action  new;
            source  boxToCell;
            sourceInfo
                box     (0 0 10e-3) (2000e-3 500e-3 12e-3);
            name    porousZone;
            type    cellZoneSet;
            action  new;
            sourceInfo
                set porous;
            name    inletA;
            type    cellSet;
            action  new;
            source  boxToCell;
            sourceInfo
                box (0 0 12e-3) (4e-3 500e-3 22e-3);
            name    inletB;
            type    faceSet;
            action  new;
            source  cellToFace;
            sourceInfo
                set     inletA;
                option  all;
            name    inletB;
            type    faceSet;
            action  subset;
            source  patchToFace;
            sourceInfo
                name walls;
            name    outletA;
            type    cellSet;
            action  new;
            source  boxToCell;
            sourceInfo
                box (1.996 0 12e-3) (2 500e-3 50e-3);
            name    outletB;
            type    faceSet;
            action  new;
            source  cellToFace;
            sourceInfo
                set     outletA;
                option  all;
            name    outletB;
            type    faceSet;
            action  subset;
            source  patchToFace;
            sourceInfo
                name walls;
    createPatch是这样的:
    FoamFile
        version     2.0;
        format      ascii;
        class       dictionary;
        object      createPatchDict;
    // Do a synchronisation of coupled points after creation of any patches.
    // Note: this does not work with points that are on multiple coupled patches
    //       with transformations (i.e. cyclics).
    pointSync false;
    // writeCyclicMatch  false;
    // Patches to create.
    patches
            name inlet;
            patchInfo
                type            patch;
            constructFrom set;
            set inletB;
            name outlet;
            patchInfo
                type            patch;
            constructFrom set;
            set outletB;
    这个豁牙子问题我之前跟着阿B上田东的视频做案例的时候也出现了 不知道是什么玩意 而且case跑完之后他明显是个实际存在的数值上的豁牙子,不是paraview显示问题
  • 学流体的小明学 离线
    学流体的小明学 离线
    学流体的小明 神
    感觉是topoSet选择网格,提取各种面的时候有些问题了,我没用过这方面的功能,不太了解。
    你如果只是想把边界面提取出来的话,在blockMesh当中就可以设置吧。
    1 1 条回复 最后回复
    豁牙子注意一下toposet点位置的精度。
  • 1 离线
    1 离线
    16c
    在 中回复了 学流体的小明 最后由 16c 编辑
    @李东岳 在 toposet之后出现空集。。。 中说:
    感谢两位大佬提点,豁牙子问题解决了...
