  3. foam-extend-4.1安装出错
foam-extend-4.1安装出错
10 帖子 2 发布者 5.4k 浏览
  • 杜 离线
    杜 离线
    杜浚平
    在ubuntu20.04中按照教程安装时出现以下问题:
    SOURCE=db/dictionary/dictionaryEntry/dictionaryEntry.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include     -I/home/ad/foam/foam-extend-4.1/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/dictionaryEntry.o
    db/IOstreams/Pstreams/IPread.C:29:10: fatal error: mpi.h: No such file or directory
     #include "mpi.h"
    db/IOstreams/Pstreams/OPwrite.C:29:10: fatal error: mpi.h: No such file or directory
     #include "mpi.h"
    db/IOstreams/Pstreams/PstreamReduceOps.C:26:10: fatal error: mpi.h: No such file or directory
     #include "mpi.h"
    db/IOstreams/Pstreams/Pstream.C:26:10: fatal error: mpi.h: No such file or directory
     #include "mpi.h"
    compilation terminated.
    In file included from db/IOstreams/Pstreams/PstreamGlobals.C:26:0:
    db/IOstreams/Pstreams/PstreamGlobals.H:39:10: fatal error: mpi.h: No such file or directory
     #include "mpi.h"
    make: *** [db/IOstreams/Pstreams/Pstream.dep:170: Make/linux64GccDPInt32Opt/Pstream.o] Error 1
    make: *** Waiting for unfinished jobs....
    make: *** [db/IOstreams/Pstreams/PstreamReduceOps.dep:148: Make/linux64GccDPInt32Opt/PstreamReduceOps.o] Error 1
    make: *** [db/IOstreams/Pstreams/PstreamGlobals.dep:114: Make/linux64GccDPInt32Opt/PstreamGlobals.o] Error 1
    make: *** [db/IOstreams/Pstreams/IPread.dep:136: Make/linux64GccDPInt32Opt/IPread.o] Error 1
    make: *** [db/IOstreams/Pstreams/OPwrite.dep:136: Make/linux64GccDPInt32Opt/OPwrite.o] Error 1
    + decompositionMethods/AllwmakeLnInclude
    + wmakeLnInclude decomposeReconstruct
    + wmakeLnInclude decompositionMethods
    + wmakeLnInclude metisDecomp
    + wmakeLnInclude parMetisDecomp
    + wmakeLnInclude scotchDecomp
    + wmake libso decompositionMethods
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdecompositionMethods.so' is up to date.
    + wmake libso metisDecomp
    SOURCE=metisDecomp.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I../decompositionMethods/lnInclude     -I../scotchDecomp/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/metisDecomp.o
    In file included from metisDecomp.C:26:0:
    metisDecomp.H:38:10: fatal error: decompositionMethod.H: No such file or directory
     #include "decompositionMethod.H"
    make: *** [metisDecomp.dep:342: Make/linux64GccDPInt32Opt/metisDecomp.o] Error 1
    + wmake libso parMetisDecomp
    SOURCE=parMetisDecomp.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/include     -I     -I../decompositionMethods/lnInclude     -I../metisDecomp/lnInclude     -I../scotchDecomp/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/parMetisDecomp.o
    In file included from parMetisDecomp.C:26:0:
    parMetisDecomp.H:37:10: fatal error: decompositionMethod.H: No such file or directory
    make: *** [parMetisDecomp.dep:362: Make/linux64GccDPInt32Opt/parMetisDecomp.o] Error 1
    + wmake libso scotchDecomp
    SOURCE=scotchDecomp/scotchDecomp.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/scotchDecomp.o
    SOURCE=engineScotchDecomp/engineScotchDecomp.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/engineScotchDecomp.o
    In file included from scotchDecomp/scotchDecomp.C:107:0:
    scotchDecomp/scotchDecomp.H:38:10: fatal error: decompositionMethod.H: No such file or directory
    In file included from engineScotchDecomp/engineScotchDecomp.H:49:0,
                     from engineScotchDecomp/engineScotchDecomp.C:26:
    lnInclude/scotchDecomp.H:38:10: fatal error: decompositionMethod.H: No such file or directory
    make: *** [engineScotchDecomp/engineScotchDecomp.dep:343: Make/linux64GccDPInt32Opt/engineScotchDecomp.o] Error 1
    make: *** [scotchDecomp/scotchDecomp.dep:342: Make/linux64GccDPInt32Opt/scotchDecomp.o] Error 1
    + wmake libso lagrangian/basic
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/liblagrangian.so' is up to date.
    + wmake libso edgeMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libedgeMesh.so' is up to date.
    + wmake libso surfMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsurfMesh.so' is up to date.
    + wmake libso meshTools
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libmeshTools.so' is up to date.
    + wmake libso finiteVolume
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libfiniteVolume.so' is up to date.
    + wmake libso finiteArea
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libfiniteArea.so' is up to date.
    + conversion/Allwmake
    + wmake libso
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libconversion.so' is up to date.
    + wmake libso lduSolvers
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/liblduSolvers.so' is up to date.
    + wmake libso tetFiniteElement
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libtetFiniteElement.so' is up to date.
    + wmake libso decompositionMethods/decomposeReconstruct
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdecomposeReconstruct.so' is up to date.
    + dynamicMesh/AllwmakeLnInclude
    + wmakeLnInclude dynamicMesh
    + wmakeLnInclude dynamicFvMesh
    + wmakeLnInclude topoChangerFvMesh
    + meshMotion/AllwmakeLnInclude
    + wmakeLnInclude solidBodyMotion
    + wmakeLnInclude fvMotionSolver
    + wmakeLnInclude RBFMotionSolver
    + wmakeLnInclude mesquiteMotionSolver
    + wmake libso dynamicMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdynamicMesh.so' is up to date.
    + wmake libso solidBodyMotion
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsolidBodyMotion.so' is up to date.
    + wmake libso fvMotionSolver
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libfvMotionSolver.so' is up to date.
    + wmake libso RBFMotionSolver
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libRBFMotionSolver.so' is up to date.
    + wmake libso mesquiteMotionSolver
    SOURCE=mesquiteMotionSolver.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I/home/ad/foam/foam-extend-4.1/src/meshTools/lnInclude     -I/home/ad/foam/foam-extend-4.1/src/dynamicMesh/dynamicMesh/lnInclude  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/mesquiteMotionSolver.o
    In file included from mesquiteMotionSolver.H:39:0,
                     from mesquiteMotionSolver.C:26:
    /home/ad/foam/foam-extend-4.1/src/dynamicMesh/dynamicMesh/lnInclude/motionSolver.H:42:10: fatal error: twoDPointCorrector.H: No such file or directory
     #include "twoDPointCorrector.H"
    貌似是无法找到mpi.h文件、decompositionMethod.H文件以及twoDPointCorrector.H文件,我是应该自己添加这些文件然后重新编译吗?
    输入which mpirun 看一下
    杜 1 条回复 最后回复
  • 杜 离线
    杜 离线
    杜浚平
    @李东岳 东岳老师,输入后显示这个
    ad@ad:~$ which mpirun
    /usr/bin/mpirun
  • 杜 离线
    杜 离线
    杜浚平
    针对mpi.h文件,参考了这个帖子,再开始编译前输入了以下代码:
    echo "export WM_THIRD_PARTY_USE_BISON_27=1" > etc/prefs.sh
    echo "export WM_MPLIB=SYSTEMOPENMPI" >> etc/prefs.sh
    echo "export OPENMPI_DIR=/usr" >> etc/prefs.sh
    echo "export OPENMPI_BIN_DIR=\$OPENMPI_DIR/bin" >> etc/prefs.sh
    在之后的编译中mpi.h文件的问题不在出现,但decompositionMethod.H文件以及twoDPointCorrector.H文件的问题依然存在
  • 杜 离线
    杜 离线
    杜浚平
    在文件中存在decompositionMethod.H文件以及twoDPointCorrector.H文件,
    decompositionMethod.H位置为src/decompositionMethods/decompositionMethod/decompositionMethod.H;
    twoDPointCorrector.H位置为src/meshTools/twoDPointCorrector/twoDPointCorrector.H,
    编译还是显示无法找到
  • 杜 离线
    杜 离线
    杜浚平
    仅编译src/decompositionMethods文件夹:
    ad@ad:~/foam/foam-extend-4.1/src/decompositionMethods$ ./Allwmake
    Making dependency list for source file decompositionMethod/decompositionMethod.C
    Making dependency list for source file manualDecomp/manualDecomp.C
    Making dependency list for source file geomDecomp/geomDecomp.C
    Making dependency list for source file patchConstrainedDecomp/patchConstrainedDecomp.C
    Making dependency list for source file hierarchGeomDecomp/hierarchGeomDecomp.C
    Making dependency list for source file simpleGeomDecomp/simpleGeomDecomp.C
    SOURCE=decompositionMethod/decompositionMethod.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/decompositionMethod.o
    SOURCE=manualDecomp/manualDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/manualDecomp.o
    SOURCE=geomDecomp/geomDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/geomDecomp.o
    SOURCE=simpleGeomDecomp/simpleGeomDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/simpleGeomDecomp.o
    SOURCE=hierarchGeomDecomp/hierarchGeomDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/hierarchGeomDecomp.o
    SOURCE=patchConstrainedDecomp/patchConstrainedDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200  -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/patchConstrainedDecomp.o
    Making dependency list for source file metisDecomp.C
    could not open file metis.h for source file metisDecomp.C
    SOURCE=metisDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I../decompositionMethods/lnInclude     -I../scotchDecomp/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/metisDecomp.o
    Making dependency list for source file parMetisDecomp.C
    could not open file parmetis.h for source file parMetisDecomp.C
    SOURCE=parMetisDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/usr/lib/x86_64-linux-gnu/openmpi/include -I/usr/lib/x86_64-linux-gnu/openmpi/include/openmpi     -I     -I../decompositionMethods/lnInclude     -I../metisDecomp/lnInclude     -I../scotchDecomp/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/parMetisDecomp.o
    Making dependency list for source file scotchDecomp/scotchDecomp.C
    Making dependency list for source file engineScotchDecomp/engineScotchDecomp.C
    could not open file scotch.h for source file scotchDecomp/scotchDecomp.C
    SOURCE=scotchDecomp/scotchDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/scotchDecomp.o
    SOURCE=engineScotchDecomp/engineScotchDecomp.C ;  g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I     -I../decompositionMethods/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/engineScotchDecomp.o
    那就不要编译metis部分了
    杜 1 条回复 最后回复
  • 杜 离线
    杜 离线
    杜浚平
    @李东岳 这里scotchDecomp的编译也会出问题,导致并行运算没法使用scotch,在分块的时候会出现以下问题:
    ad@ad:~/foam/ad-4.1/run/damBreak$ decomposePar
    |  \\    /   O peration     | Version:     4.1                                |
    |   \\  /    A nd           | Web:         http://www.foam-extend.org         |
    |    \\/     M anipulation  | For copyright notice see file Copyright         |
    Build  : 4.1-0de8e022a122
    Exec   : decomposePar
    Date   : Dec 30 2024
    Time   : 13:10:13
    Host   : "ad"
    PID    : 19289
    CtrlDict : "/home/ad/foam/ad-4.1/run/damBreak/system/controlDict"
    Case   : /home/ad/foam/ad-4.1/run/damBreak
    nProcs : 1
    allowSystemOperations : Disallowing user-supplied system call operations
    Create time
    Time = 0
    Create mesh for region region0
    Calculating distribution of cells
    --> FOAM Warning :
        From function void* Foam::dlOpen(const Foam::fileName&, bool)
        in file POSIX.C at line 1204
        dlopen error : libscotchDecomp.so: cannot open shared object file: No such file or directory
    --> FOAM Warning :
        From function bool Foam::dlLibraryTable::open(const Foam::fileName&, bool)
        in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 97
        could not load "libscotchDecomp.so"
    --> FOAM Warning :
        From function decompositionMethod::loadExternalLibraries()
        in file decompositionMethod/decompositionMethod.C at line 520
        Loading of decomposition library libscotchDecomp.so unsuccesful. Some decomposition methods may not be  available
    --> FOAM Warning :
        dlopen error : libmetisDecomp.so: cannot open shared object file: No such file or directory
    --> FOAM Warning :
        could not load "libmetisDecomp.so"
    --> FOAM Warning :
        Loading of decomposition library libmetisDecomp.so unsuccesful. Some decomposition methods may not be  available
    --> FOAM Warning :
        dlopen error : libparMetisDecomp.so: cannot open shared object file: No such file or directory
    --> FOAM Warning :
        could not load "libparMetisDecomp.so"
    --> FOAM Warning :
        Loading of decomposition library libparMetisDecomp.so unsuccesful. Some decomposition methods may not be  available
    Selecting decompositionMethod scotch
    --> FOAM FATAL ERROR:
    Unknown decompositionMethod scotch
    Valid decompositionMethods are :
    4
    hierarchical
    manual
    patchConstrained
    simple
        From function decompositionMethod::New(const dictionary& decompositionDict, const polyMesh& mesh)
        in file decompositionMethod/decompositionMethod.C at line 496.
    FOAM exiting
    那就是你没有编译scotch,openfoam都要单独编译scotch,
    1. 你可以去我那个虚拟机下面这个scotch的库
    2. 编译scotch
    杜 1 条回复 最后回复
  • 杜 离线
    杜 离线
    杜浚平
    @李东岳 我把ThirdParty里需要的包都手动添加在了
    foam/foam-extend-4.1/ThirdParty/rpmBuild/SOURCES/
    ad@ad:~/foam/foam-extend-4.1/ThirdParty/rpmBuild/SOURCES$ ls
    bison-2.7.tar.gz       openmpi-1.4.1.tar.gz  parmetis-4.0.3.tar.gz
    cmake-3.2.2.tar.gz     openmpi-1.4.3.tar.gz  ParMGridGen-1.0.tar.gz
    hwloc-1.10.1.tar.gz    openmpi-1.5.tar.gz    PyFoam-0.6.4.tar.gz
    hwloc-2.0.1.tar.gz     openmpi-1.6.5.tar.gz  PyFoam-0.6.9.tar.gz
    libccmio-2.6.1.tar.gz  openmpi-1.8.4.tar.gz  scotch-6.0.0.tar.gz
    mesquite-2.1.2.tar.gz  openmpi-1.8.8.tar.gz  scotch_6.0.4.tar.gz
    mesquite-2.3.0.tar.gz  openmpi-3.1.1.tar.gz
    metis-5.1.0.tar.gz     openmpi-4.0.0.tar.gz
    也编译了scotch6.0.4,但还是会出现找不到decompositionMethod.H文件以及twoDPointCorrector.H文件的问题,还多了一个mgridgen.h文件的问题:
    ad@ad:~/foam/foam-extend-4.1$ fe41
    ad@ad:~/foam/foam-extend-4.1$ echo $WM_THIRD_PARTY_USE_SCOTCH_604
    1
    ad@ad:~/foam/foam-extend-4.1$ ./Allwmake
    make: Nothing to be done for 'all'.
    + wmakePrintBuild -check
    no git description found
    + /bin/rm -f foam/Make/linux64GccDPInt32Opt/global.C foam/Make/linux64GccDPInt32Opt/global.o
    + wmakeLnInclude foam
    + wmakeLnInclude meshTools
    + wmakeLnInclude OSspecific/POSIX
    + wmake libo OSspecific/POSIX
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libOSspecific.o' is up to date.
    + set +x
    Note: ignore spurious warnings about missing mpicxx.h headers
    + wmake libso foam
    SOURCE=global/global.Cver ; sed -e 's/VERSION_STRING/4.1/' -e 's/BUILD_STRING/4.1/' $SOURCE > Make/linux64GccDPInt32Opt/global.C; g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/home/ad/foam/foam-extend-4.1/ThirdParty/packages/openmpi-1.8.8/platforms/linux64GccDPInt32Opt/include     -I/home/ad/foam/foam-extend-4.1/ThirdParty/zlib-1.2.3 -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c Make/linux64GccDPInt32Opt/global.C -o Make/linux64GccDPInt32Opt/global.o
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libfoam.so' is up to date.
    SOURCE=parMetisDecomp.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -DOMPI_SKIP_MPICXX -I/home/ad/foam/foam-extend-4.1/ThirdParty/packages/openmpi-1.8.8/platforms/linux64GccDPInt32Opt/include     -I     -I../decompositionMethods/lnInclude     -I../metisDecomp/lnInclude     -I../scotchDecomp/lnInclude -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/parMetisDecomp.o
    + wmake libso
    make: *** [mesquiteMotionSolver.dep:408: Make/linux64GccDPInt32Opt/mesquiteMotionSolver.o] Error 1
    + wmake libso tetMotionSolver
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libtetMotionSolver.so' is up to date.
    + wmake libso dynamicFvMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdynamicFvMesh.so' is up to date.
    + wmake libso dynamicTopoFvMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdynamicTopoFvMesh.so' is up to date.
    + wmake libso topoChangerFvMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libtopoChangerFvMesh.so' is up to date.
    + wmake libso loadBalanceFvMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libloadBalanceFvMesh.so' is up to date.
    + wmake libso coupledMatrix
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcoupledLduMatrix.so' is up to date.
    + wmake libso sampling
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsampling.so' is up to date.
    + wmake libso ODE
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libODE.so' is up to date.
    + wmake libso POD
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libPOD.so' is up to date.
    + wmake libso randomProcesses
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/librandomProcesses.so' is up to date.
    + mesh/Allwmake
    + wmake libso autoMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libautoMesh.so' is up to date.
    + wmake libso blockMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libblockMesh.so' is up to date.
    + wmake libso extrudeModel
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libextrudeModel.so' is up to date.
    + wmake libso cfMesh
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcfMesh.so' is up to date.
    + thermophysicalModels/Allwmake
    + wmake libso specie
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libspecie.so' is up to date.
    + wmake libso thermophysicalFunctions
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libthermophysicalFunctions.so' is up to date.
    + wmake libso liquids
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libliquids.so' is up to date.
    + wmake libso liquidMixture
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libliquidMixture.so' is up to date.
    + wmake libso solids
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsolids.so' is up to date.
    + wmake libso solidMixture
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsolidMixture.so' is up to date.
    + wmake libso basic
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libbasicThermophysicalModels.so' is up to date.
    + wmake libso reactionThermo
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libreactionThermophysicalModels.so' is up to date.
    + wmake libso laminarFlameSpeed
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/liblaminarFlameSpeedModels.so' is up to date.
    + wmake libso chemistryModel
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libchemistryModel.so' is up to date.
    + wmake libso pdfs
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libpdf.so' is up to date.
    + wmake libso radiation
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libradiation.so' is up to date.
    + wmake libso barotropicCompressibilityModel
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libbarotropicCompressibilityModel.so' is up to date.
    + transportModels/Allwmake
    + wmake libso incompressible
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libincompressibleTransportModels.so' is up to date.
    + wmake libso interfaceProperties
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libinterfaceProperties.so' is up to date.
    + wmake libso viscoelastic
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libviscoelasticTransportModels.so' is up to date.
    + turbulenceModels/Allwmake
    + LES/Allwmake
    + wmakeLnInclude ../incompressible/LES
    + wmake libso LESfilters
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libLESfilters.so' is up to date.
    + wmake libso LESdeltas
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libLESdeltas.so' is up to date.
    + incompressible/Allwmake
    + wmake libso turbulenceModel
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libincompressibleTurbulenceModel.so' is up to date.
    + wmake libso RAS
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libincompressibleRASModels.so' is up to date.
    + wmake libso LES
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libincompressibleLESModels.so' is up to date.
    + compressible/Allwmake
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcompressibleTurbulenceModel.so' is up to date.
    + wmake libso RAS
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcompressibleRASModels.so' is up to date.
    + wmake libso LES
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcompressibleLESModels.so' is up to date.
    + lagrangian/Allwmake
    + wmake libso basic
    + wmake libso solidParticle
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsolidParticle.so' is up to date.
    + wmake libso intermediate
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/liblagrangianIntermediate.so' is up to date.
    + wmake libso dieselSpray
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdieselSpray.so' is up to date.
    + wmake libso dsmc
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libdsmc.so' is up to date.
    + wmake libso coalCombustion
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcoalCombustion.so' is up to date.
    + molecularDynamics/Allwmake
    + wmake libso potential
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libpotential.so' is up to date.
    + wmake libso molecularMeasurements
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libmolecularMeasurements.so' is up to date.
    + wmake libso molecule
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libmolecule.so' is up to date.
    + wmake libso conjugateHeatTransfer
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libconjugateHeatTransfer.so' is up to date.
    + postProcessing/Allwmake
    + wmake libo postCalc
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/postCalc.o' is up to date.
    + wmake libso foamCalcFunctions
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libfoamCalcFunctions.so' is up to date.
    + functionObjects/Allwmake
    + wmake libso check
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libcheckFunctionObjects.so' is up to date.
    + wmake libso field
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libfieldFunctionObjects.so' is up to date.
    + wmake libso forces
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libforces.so' is up to date.
    + wmake libso fvTools
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libFVFunctionObjects.so' is up to date.
    + wmake libso IO
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libIOFunctionObjects.so' is up to date.
    + wmake libso jobControl
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libjobControl.so' is up to date.
    + wmake libso systemCall
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsystemCall.so' is up to date.
    + wmake libso utilities
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libutilityFunctionObjects.so' is up to date.
    + wmake libso errorEstimation
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/liberrorEstimation.so' is up to date.
    + fvAgglomerationMethods/Allwmake
    + wmake libso MGridGenGamgAgglomeration
    SOURCE=MGridGenGAMGAgglomerate.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/ad/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/Lib        -I/IMlib       -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/MGridGenGAMGAgglomerate.o
    MGridGenGAMGAgglomerate.C:35:13: fatal error: mgridgen.h: No such file or directory
     #   include "mgridgen.h"
    make: *** [MGridGenGAMGAgglomerate.dep:447: Make/linux64GccDPInt32Opt/MGridGenGAMGAgglomerate.o] Error 1
    + wmake libso pairPatchAgglomeration
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libpairPatchAgglomeration.so' is up to date.
    + wmake libso engine
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libengine.so' is up to date.
    + wmake libso equationReader
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libequationReader.so' is up to date.
    + wmake libso multiSolver
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libmultiSolver.so' is up to date.
    + wmake libso solidModels
    '/home/ad/foam/foam-extend-4.1/lib/linux64GccDPInt32Opt/libsolidModels.so' is up to date.
    + wmake libso dbns
    SOURCE=multigrid/mgMeshLevel/mgMeshLevel.C ;  g++-7 -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3  -DNoRepository -ftemplate-depth-200 -I/home/ad/foam/foam-extend-4.1/src/finiteVolume/lnInclude     -I/home/ad/foam/foam-extend-4.1/src/meshTools/lnInclude     -I/home/ad/foam/foam-extend-4.1/src/thermophysicalModels/basic/lnInclude     -I/home/ad/foam/foam-extend-4.1/src/turbulenceModels/compressible/turbulenceModel     -I/IMlib     -I/Lib -IlnInclude -I. -I/home/ad/foam/foam-extend-4.1/src/foam/lnInclude -I/home/ad/foam/foam-extend-4.1/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linux64GccDPInt32Opt/mgMeshLevel.o
    multigrid/mgMeshLevel/mgMeshLevel.C:31:13: fatal error: mgridgen.h: No such file or directory
    make: *** [multigrid/mgMeshLevel/mgMeshLevel.dep:428: Make/linux64GccDPInt32Opt/mgMeshLevel.o] Error 1
    :135:
