用simpleFoam求解器时出现的错误,求教如何解决
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 4.1 Exec : simpleFoam Date : Apr 10 2017 Time : 15:01:18 Host : "11" PID : 9444 Case : /home/w11/OpenFOAM/w11-4.1/run/ASBM2-Da nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field U tolerance 1e-06 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type laminar No MRF models present No finite volume options present Starting time loop Time = 1 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 9.33846e-13, No Iterations 136 smoothSolver: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0 GAMG: Solving for p, Initial residual = 1, Final residual = 0.0975624, No Iterations 26 time step continuity errors : sum local = 0.00312299, global = -0.000382393, cumulative = -0.000382393 ExecutionTime = 11.95 s ClockTime = 12 s ......... Time = 80 smoothSolver: Solving for Ux, Initial residual = 0.564078, Final residual = 8.76275e-13, No Iterations 103 smoothSolver: Solving for Uy, Initial residual = 0.391492, Final residual = 9.39228e-13, No Iterations 97 GAMG: Solving for p, Initial residual = 0.990623, Final residual = 0.617109, No Iterations 1000 time step continuity errors : sum local = 1.38438e+20, global = 5.64087e+19, cumulative = 5.64087e+19 ExecutionTime = 1160.33 s ClockTime = 1164 s Time = 81 smoothSolver: Solving for Ux, Initial residual = 0.414375, Final residual = 3.94608e-10, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.468273, Final residual = 2.39705e-10, No Iterations 1000 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:? #4 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #5 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:? #8 Foam::fvMatrix<double>::solve() at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? at ??:? 浮点数例外 (核心已转储) 这是我的fvSolution文件 solvers { U { solver smoothSolver; smoother GaussSeidel; tolerance 1e-12; relTol 0; nSweeps 1; } p { solver GAMG; tolerance 1e-9; relTol 0.1; smoother GaussSeidel; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration on; agglomerator faceAreaPair; nCellsInCoarsestLevel 10; mergeLevels 1; } } SIMPLE { nNonOrthogonalCorrectors 0; residualControl { p 1e-6; U 1e-6; } pRefCell 0; pRefValue 0; } relaxationFactors { p 0.2; U 0.9; }这个问题困扰了我好几天,本人小白一枚,年初刚接触OpenFOAM,之前做过几次小的模拟没遇到过这种情况,请教各位大神如何解决,感激不尽。
Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 972441 faces: 2653016 internal faces: 2348082 cells: 841637 faces per cell: 5.94211 boundary patches: 6 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 792917 prisms: 44780 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 3940 Breakdown of polyhedra by number of faces: faces number of cells 4 4 5 3936 Checking topology... Boundary definition OK. ***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology frontAndBack 33720 37963 ok (non-closed singly connected) left 10000 10251 ok (non-closed singly connected) right 10000 10251 ok (non-closed singly connected) bottom 3026 3561 ok (non-closed singly connected) top 4712 5452 ok (non-closed singly connected) fixedWalls 243476 249736 multiply connected (shared edge) <<Writing 2 conflicting points to set nonManifoldPoints Checking geometry... Overall domain bounding box (-0.17 -0.0604041 -0.001) (0.17 0.0601678 0.001) Mesh has 2 geometric (non-empty/wedge) directions (1 1 0) Mesh has 2 solution (non-empty) directions (1 1 0) ***Number of edges not aligned with or perpendicular to non-empty directions: 928948 <<Writing 951037 points on non-aligned edges to set nonAlignedEdges Boundary openness (-2.86088e-16 1.1772e-16 -1.21395e-15) OK. Max cell openness = 7.07551e-16 OK. Max aspect ratio = 12.3976 OK. Minimum face area = 1.35674e-09. Maximum face area = 2.45047e-06. Face area magnitudes OK. Min volume = 6.42698e-13. Max volume = 9.79806e-11. Total volume = 3.44166e-05. Cell volumes OK. Mesh non-orthogonality Max: 77.2055 average: 16.6713 *Number of severely non-orthogonal (> 70 degrees) faces: 28. Non-orthogonality check OK. <<Writing 28 non-orthogonal faces to set nonOrthoFaces ***Error in face pyramids: 1 faces are incorrectly oriented. <<Writing 1 faces with incorrect orientation to set wrongOrientedFaces ***Max skewness = 7.85662, 2557 highly skew faces detected which may impair the quality of the results <<Writing 2557 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 3 mesh checks.
这个问题现在已经解决了,是数值单位的错误。因为我的初始边界条件中入口处的p=1e-3,出口处的p=0,将网格的数值缩小了一千倍以后,使他们在同一数量级上再运行simpleFoam就不会出现“浮点数例外,核心已转储”的错误了。
 我还发现在用snappyHexMesh画三维网格的时候,如果将blockMeshDict中frontAndBack设为empty,在进行snap步骤之后依然得不到很优美的平滑的网格连接。而我听从了@wwzhao 的建议之后,将frontAndBack设置成与除了出口和入口之外的其他四个面的边界条件一致,也就是patch之后,再进行snappyHexMesh,就能得到平滑的网格了。
 这三天我失败了上百次,终于在昨天晚上凌晨的时候解决了这个问题,谢谢各位大神的指导,谢谢你们。
