  4. 如何将dat数据转化为OpenFOAM场文件
12 帖子 2 发布者 6.9k 浏览
  • B 离线
    B 离线
    biaowai
    各位老师好,请教下将dat数据转OpenFOAM场文件的方法。
    我从NASA Turbulence Resource网站上下载了周期山LES时均流场的.dat文件,包含坐标,时均速度、压力、雷诺应力场,现在想将该数据用OpenFOAM对应算例的场文件表示,该如何实现呢?
  • B 离线
    B 离线
    biaowai
    例如,是否可以将data数据写为points U P Rxx ...等文件,然后通过给internalField指定某种边界条件,把数据映射到OpenFOAM internalField上?
    坐标,时均速度、压力、雷诺应力场
    简单来几行raw数据看看
  • B 离线
    B 离线
    biaowai
    老师,数据是tecplot格式,下载链接如下:
    https://turbmodels.larc.nasa.gov/Other_LES_Data/2dhill_periodic.html
    “Average pressures, velocities & turbulence quantities, gzipped file hill_LES_avgresults.dat.gz (1.7 MB)”
    完整的5mb,太大上传不了,部分如下,坐标和对应流场数据还是很好区分的:
    # LES data for 2D hill, long-time-average results, Tecplot data file format
    # Data from Temmerman, Leschziner, et al.
    # Subset of this data also available from ERCOFTAC Classic Database, Case 81
    # http://cfd.mace.manchester.ac.uk/
    variables="x"
    "y"
    "p"
    "u/Ub"
    "v/Ub"
    "w/Ub"
    "nu_t/nu"
    "uu/Ub^2"
    "vv/Ub^2"
    "ww/Ub^2"
    "uv/Ub^2"
    "uw/Ub^2"
    "vw/Ub^2"
    "k/Ub^2"
    ZONE T="onlyzone"
     STRANDID=0, SOLUTIONTIME=0
     I=196, J=128, K=1, ZONETYPE=Ordered
     DATAPACKING=BLOCK
     DT=(SINGLE SINGLE SINGLE SINGLE SINGLE )
      1.6071578E-02  4.8215870E-02  8.0367021E-02  0.1125362      0.1447275
      0.1769350      0.2091558      0.2413900      0.2736352      0.3058870
      0.3381367      0.3703752      0.4025976      0.4348043      0.4669973
      0.4991801      0.5315053      0.5641251      0.5970455      0.6302705
      0.6638022      0.6976425      0.7317982      0.7662754      0.8010758
      0.8362055      0.8716663      0.9074619      0.9435977      0.9800737
       1.016894       1.054060       1.091577       1.129447       1.167671
       1.206250       1.245187       1.284486       1.324150       1.364184
       1.404588       1.445366       1.486524       1.528066       1.569996
       1.612317       1.655035       1.698151       1.741669       1.785596
       1.829934       1.874691       1.919887       1.965541       2.011649
       2.058197       2.105185       2.152615       2.200492       2.248821
       2.297605       2.346848       2.396553       2.446728       2.497376
       2.548501       2.600106       2.652197       2.704781       2.757859
       2.811436       2.865520       2.920113       2.975218       3.030843
       3.086993       3.143672       3.200882       3.258632       3.316927
       3.375771       3.435169       3.495126       3.555650       3.616743
       3.678410       3.740658       3.803494       3.866921       3.930944
       3.995572       4.060810       4.126659       4.193129       4.260225
       4.327954       4.396322       4.465334       4.534668       4.603679
       4.672047       4.739775       4.806872       4.873343       4.939193
       5.004428       5.069057       5.133080       5.196507       5.259342
       5.321590       5.383258       5.444351       5.504874       5.564831
       5.624229       5.683074       5.741368       5.799119       5.856329
       5.913008       5.969158       6.024783       6.079890       6.134482
       6.188564       6.242141       6.295220       6.347804       6.399894
       6.451500       6.502625       6.553273       6.603448       6.653155
       6.702398       6.751180       6.799509       6.847385       6.894816
       6.941806       6.988353       7.034460       7.080114       7.125309
       7.170066       7.214405       7.258332       7.301851       7.344967
       7.387684       7.430006       7.471937       7.513479       7.554636
       7.595414       7.635818       7.675851       7.715517       7.754817
       7.793755       7.832335       7.870557       7.908425       7.945942
       7.983109       8.019931       8.056406       8.092541       8.128337
       8.163797       8.198927       8.233727       8.268205       8.302362
       8.336205       8.369735       8.402958       8.435880       8.468500
       8.500823       8.533006       8.565199       8.597406       8.629628
       8.661867       8.694117       8.726368       8.758614       8.790848
       8.823069       8.855276       8.887467       8.919637       8.951787
       8.983931      1.6072614E-02  4.8221398E-02  8.0390953E-02  0.1126138
      0.1449025      0.1772396      0.2096169      0.2420342      0.2744843
      0.3069537      0.3394175      0.3718477      0.4042305      0.4365664
      0.4688613      0.5011253      0.5335129      0.5661775      0.5991291
      0.6323731      0.6659118      0.6997479      0.7338908      0.7683513
      0.8031352      0.8382494      0.8736964      0.9094799      0.9456052
      0.9820726       1.018886       1.056047       1.093558       1.131418
       1.169626       1.208181       1.247085       1.286341       1.325952
       1.365921       1.406246       1.446933       1.487990       1.529422
       1.571233       1.613429       1.656014       1.698989       1.742358
       1.786130       1.830307       1.874906       1.919975       1.965564
       2.011655       2.058200       2.105188       2.152619       2.200496
       2.248825       2.297608       2.346851       2.396556       2.446731
       2.497379       2.548504       2.600109       2.652199       2.704783
       2.757861       2.811438       2.865522       2.920114       2.975219
       3.030844       3.086994       3.143672       3.200883       3.258633
       3.316927       3.375771       3.435169       3.495126       3.555649
       3.616742       3.678409       3.740657       3.803493       3.866919
       3.930942       3.995570       4.060807       4.126657       4.193126
       4.260222       4.327951       4.396320       4.465332       4.534665
       4.603675       4.672043       4.739772       4.806869       4.873339
       4.939189       5.004425       5.069052       5.133076       5.196502
       5.259337       5.321585       5.383253       5.444345       5.504869
       5.564826       5.624223       5.683068       5.741362       5.799112
       5.856322       5.913001       5.969151       6.024776       6.079882
       6.134475       6.188557       6.242134       6.295212       6.347795
       6.399886       6.451491       6.502616       6.553264       6.603438
       6.653145       6.702388       6.751170       6.799499       6.847376
       6.894807       6.941796       6.988341       7.034430       7.080020
       7.125089       7.169687       7.213865       7.257637       7.301008
       7.343983       7.386566       7.428763       7.470576       7.512008
       7.553064       7.593751       7.634077       7.674045       7.713657
       7.752915       7.791821       7.830376       7.868582       7.906441
       7.943952       7.981114       8.017929       8.054397       8.090521
       8.126305       8.161752       8.196866       8.231650       8.266111
       8.300256       8.334094       8.367631       8.400873       8.433826
       8.466492       8.498878       8.531141       8.563437       8.595773
       8.628156       8.660585       8.693049       8.725519       8.757970
       8.790387       8.822764       8.855102       8.887390       8.919613
       8.951782       8.983929      1.6075116E-02  4.8231687E-02  8.0423258E-02
      0.1127023      0.1450891      0.1775567      0.2100914      0.2426924
      0.2753479      0.3080350      0.3407131      0.3733364      0.4058819
      0.4383501      0.4707500      0.5030981      0.5355510      0.5682628
      0.6012480      0.6345130      0.6680605      0.7018941      0.7360257
      0.7704708      0.8052388      0.8403382      0.8757718      0.9115435
      0.9476586      0.9841177       1.020925       1.058081       1.095586
       1.133437       1.171628       1.210158       1.249030       1.288243
       1.327801       1.367703       1.407949       1.448544       1.489497
       1.530817       1.572508       1.614576       1.657024       1.699854
       1.743071       1.786684       1.830698       1.875136       1.920077
       1.965600       2.011670       2.058211       2.105197       2.152627
       2.200504       2.248832       2.297615       2.346857       2.396562
       2.446736       2.497384       2.548508       2.600113       2.652203
       2.704787       2.757864       2.811441       2.865524       2.920117
       2.975222       3.030846       3.086996       3.143674       3.200884
       3.258634       3.316928       3.375772       3.435170       3.495126
    数据这5列都是什么?
    NASA做的2D LES模拟?
    B 1 条回复 最后回复
  • B 离线
    B 离线
    biaowai
    @李东岳 数据应该是按块分布的,这五列应该都是变量x,数据可以在tecplot里重新输出为按列分布的,
    数据是NASA提供的3D LES结果,因为沿展向平均,就少了z方向,
    我想是不是可以构建List,在OpenFOAM中读取这些数据,然后怎么把数据插值到OpenFOAM网格上,还不太清楚,不知道还有其他方法没
    没懂
    https://turbulence.pha.jhu.edu/docs/channel/profiles.txt
    这是Hopkins的数据,很直观:
     y+              U+              uv+             uu+             vv+             ww+           tau_uv/tau_w    tau_nu/tau_w     tau/tau_w        P+              pp+             up+
      0.0000000e+00   0.0000000e+00   0.0000000e+00   4.6029311e-36   0.0000000e+00   1.2527210e-35  -0.0000000e+00   1.0000000e+00   1.0000000e+00   0.0000000e+00   6.4599422e+00  -2.8535219e-20
    B 1 条回复 最后回复
  • B 离线
    B 离线
    biaowai
    在 中回复了 李东岳 最后由 李东岳 编辑
    @李东岳 李老师,就是用tecplot能输出为您指的数据形式,每一列对应一个变量,比如:
    TITLE     = ""
    VARIABLES = "x"
    "y"
    "p"
    "u/Ub"
    "v/Ub"
    "w/Ub"
    "nu_t/nu"
    "<u'u'>/U<sub>b</sub><sup>2</sup>"
    "<v'v'>/U<sub>b</sub><sup>2</sup>"
    "<w'w'>/U<sub>b</sub><sup>2</sup>"
    "uv/Ub^2"
    "uw/Ub^2"
    "vw/Ub^2"
    "k/Ub^2"
    ZONE T="onlyzone"
     DATAPACKING=POINT
     DT=(SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE SINGLE )
     1.607157849E-02 1.001670957E+00 -1.160032116E-02 -4.419332545E-04 1.108767829E-04 1.172445409E-04 4.169606604E-03 3.070679726E-03 5.363423497E-06 2.476341324E-03 -4.059855200E-05 1.324464120E-05 -2.093530611E-07 2.776192268E-03
     4.821586981E-02 1.001688957E+00 1.396110019E-04 4.357797094E-03 8.979442646E-05 9.442696319E-05 4.473063163E-03 3.449148964E-03 5.933116881E-06 2.876745071E-03 -4.381870167E-05 1.613048153E-05 -2.160398651E-07 3.165913746E-03
     8.036702126E-02 1.001670957E+00 1.550839003E-02 9.025274776E-03 1.329612860E-05 8.381024963E-05 4.288332537E-03 3.727899631E-03 5.552815765E-06 3.075941466E-03 -3.998054308E-05 2.274494545E-05 -2.837280135E-07 3.404696938E-03
     1.125361994E-01 1.001445055E+00 2.612541243E-02 1.919417270E-02 -2.363917738E-04 1.087907294E-04 3.781126114E-03 3.806996159E-03 6.014777227E-06 2.951187082E-03 -7.744952745E-05 2.379864600E-05 -5.770835969E-07 3.382098861E-03
     1.447274983E-01 1.000419021E+00 3.702546656E-02 1.935387589E-02 -9.386826423E-04 1.189410614E-04 3.441388486E-03 3.408961929E-03 1.454687845E-05 2.611031057E-03 -1.917025365E-04 2.557383959E-05 -1.437096330E-06 3.017270006E-03
     1.769350022E-01 9.981601834E-01 4.660356045E-02 1.412238460E-02 -1.236868207E-03 1.366295910E-04 3.388901474E-03 2.840716857E-03 2.945053711E-05 2.342321211E-03 -2.724293445E-04 2.348102316E-05 -2.140308652E-06 2.606244292E-03
     2.091557980E-01 9.944663048E-01 5.734289065E-02 4.700349644E-03 -6.553693092E-04 1.441779459E-04 3.570280271E-03 2.361760009E-03 5.394188702E-05 2.147532534E-03 -3.465094196E-04 2.182194294E-05 -3.161800123E-06 2.281617373E-03
     2.413900048E-01 9.890016913E-01 6.659116596E-02 -4.727009684E-03 9.238781640E-04 1.252938819E-04 3.973037004E-03 2.007554518E-03 9.121072071E-05 2.040160587E-03 -4.207944730E-04 2.163483987E-05 -4.550076937E-06 2.069463022E-03
     2.736352086E-01 9.814335108E-01 7.550033182E-02 -1.226636581E-02 3.284901148E-03 9.592642891E-05 4.854913801E-03 1.890096581E-03 1.540009980E-04 1.985419774E-03 -5.343046505E-04 1.919102579E-05 -5.457195584E-06 2.014758531E-03
     3.058870137E-01 9.714285731E-01 8.219367266E-02 -1.585314423E-02 5.553464405E-03 1.225007691E-05 7.452565245E-03 1.883902820E-03 2.544213203E-04 1.922742347E-03 -6.884611794E-04 8.922108464E-06 -3.239756779E-06 2.030533273E-03
     3.381367028E-01 9.587087035E-01 8.831046522E-02 -1.742931083E-02 7.657137234E-03 -5.126111864E-05 1.384659857E-02 1.852983725E-03 3.839910205E-04 1.818480319E-03 -8.407403948E-04 -1.677947012E-06 8.278285577E-07 2.027727431E-03
     3.703751862E-01 9.432629943E-01 9.336583316E-02 -1.686210930E-02 8.794154041E-03 3.129130710E-05 2.444427274E-02 1.714259852E-03 4.927591654E-04 1.661306480E-03 -9.171591373E-04 3.393027328E-06 -1.732327632E-06 1.934162690E-03
     4.025976062E-01 9.253342748E-01 9.835574031E-02 -1.553214993E-02 9.222077206E-03 7.906599058E-05 3.771342337E-02 1.464983448E-03 5.403565592E-04 1.458810992E-03 -8.884384879E-04 5.756015071E-06 -3.364400527E-06 1.732075587E-03
     4.348042905E-01 9.052193761E-01 1.024615988E-01 -1.335643232E-02 8.764483966E-03 4.293467646E-05 5.186402425E-02 1.188463531E-03 5.316339084E-04 1.246515894E-03 -7.940374198E-04 4.800015631E-06 -3.192184977E-06 1.483306638E-03
     4.669972956E-01 8.832147121E-01 1.061192974E-01 -1.114674564E-02 7.911175489E-03 1.114533234E-06 6.543247402E-02 9.446168551E-04 4.914068268E-04 1.062652562E-03 -6.807612954E-04 6.419184047E-06 -4.659785645E-06 1.249338151E-03
     4.991801083E-01 8.596161008E-01 1.087564006E-01 -9.040180594E-03 6.819012575E-03 1.906530815E-05 7.746666670E-02 7.578500663E-04 4.429326509E-04 9.066381608E-04 -5.789970746E-04 1.981409468E-06 -1.536214654E-06 1.053710468E-03
     5.315052867E-01 8.345888257E-01 1.110552996E-01 -7.447810378E-03 5.889367778E-03 4.942064697E-05 8.752124757E-02 6.230192957E-04 3.983406350E-04 7.891814457E-04 -4.978944780E-04 7.744821460E-07 -6.069661822E-07 9.052706882E-04
     5.641251206E-01 8.082603216E-01 1.126338989E-01 -5.844191182E-03 4.790665116E-03 1.439555945E-05 9.612683207E-02 5.203748588E-04 3.564094659E-04 7.008929970E-04 -4.304422473E-04 -1.420996341E-06 1.140804329E-06 7.888386608E-04
     5.970454812E-01 7.808707952E-01 1.139284000E-01 -4.751059692E-03 3.993643448E-03 -2.899725769E-05 1.011205018E-01 4.460995551E-04 3.202182415E-04 6.276970380E-04 -3.777765087E-04 -2.163184035E-06 1.783167363E-06 6.970074028E-04
     6.302704811E-01 7.526702881E-01 1.148426011E-01 -3.732610028E-03 3.186505986E-03 -1.079070425E-04 1.025080010E-01 3.779401304E-04 2.789359423E-04 5.530502531E-04 -3.245451371E-04 -3.089254506E-06 2.575873850E-06 6.049631629E-04
     6.638022065E-01 7.239235044E-01 1.155169010E-01 -3.113800427E-03 2.672569593E-03 -1.299815485E-04 1.001565978E-01 3.263925319E-04 2.428262669E-04 4.902411019E-04 -2.814127365E-04 -4.204823199E-06 3.541459819E-06 5.297299358E-04
     6.976425052E-01 6.949139237E-01 1.160271019E-01 -2.589607844E-03 2.211316256E-03 -1.442474604E-04 9.582434595E-02 2.900119871E-04 2.134600800E-04 4.396356235E-04 -2.487174352E-04 -3.560399819E-06 3.004487780E-06 4.715538234E-04
     7.317981720E-01 6.659088731E-01 1.163076013E-01 -2.212648746E-03 1.864501392E-03 -1.998465741E-04 8.804365993E-02 2.686502994E-04 1.920674695E-04 3.960952745E-04 -2.270761906E-04 -1.788054533E-06 1.529237807E-06 4.284065217E-04
    你可以首先反推出网格点的位置信息。然后把相关变量处理成场数据。比如数据是
     x              y             u
    2 3 4
    那你的网格单元体心的位置坐标就是(2 3),然后U的值是(4 0 0)
    B 1 条回复 最后回复
  • B 离线
    B 离线
    biaowai
    @李东岳 老师,如果原始数据坐标和我的网格体心坐标不重叠,就要用到插值方法,一般采什么插值方法合适呢
    不重叠就得插值。不过感觉插值好像也不太合适。如果都LES了,插值有失精度。如果要插值,简单的就线性插值呗。高端点的来个2次3次样条啥的。具体差不插值,我也是自己琢磨的,或许也可以吧。
    B 1 条回复 最后回复
  • B 离线
    B 离线
    biaowai
    @李东岳好的,谢谢老师!
