  4. of10下pitzDaily案例调用SIMPLE算法,代码该如何修改?
8 帖子 2 发布者 5.1k 浏览
    yjc95
    of10下pitzDaily案例默认采用SIMPLEC算法,consistent为yes
    SIMPLE
        nNonOrthogonalCorrectors 0;
        consistent      yes;
        residualControl
            p               1e-2;
            U               1e-3;
            "(k|epsilon|omega|f|v2)" 1e-3;
    我想试试用SIMPLE算法,把consistent改为no,simpleFoam求解器里面的pEqn.H文件里有p.relax()(即已经对压力场进行松弛),运行之后报错
    Time = 6s
    smoothSolver:  Solving for Ux, Initial residual = 1, Final residual = 0.0894736, No Iterations 7
    smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 0.0905951, No Iterations 7
    #3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
    #4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
    #5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
    #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    #8  Foam::fvMatrix<double>::solve() in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    #9  ? in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    #10  ? in "/lib/x86_64-linux-gnu/libc.so.6"
    #11  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
    #12  ? in "/home/dyfluid/OpenFOAM/OpenFOAM-10/platforms/linux64GccDPInt32Opt/bin/simpleFoam"
    浮点异常 (核心已转储)
    你要改松弛因子
    Y 1 条回复 最后回复
    yjc95
    @李东岳 老师,我改了松弛因子,还是报错
    SIMPLE
        consistent      no;
        residualControl
            p               1e-2;
            U               1e-3;
    relaxationFactors
        equations
            U               0.9; // 0.9 is more stable but 0.95 more convergent
            ".*"            0.9; // 0.9 is more stable but 0.95 more convergent
            p               0.9; //
    Time = 6s
    浮点异常 (核心已转储)
    这是一个非常入门的问题。你最好系统学一下openfoam:
    http://dyfluid.com/openfoam11-2-1.html
    要不就参加课学一下 http://dyfluid.com/class.html
        equations
            ".*"            0.7; // 0.9 is more stable but 0.95 more convergent
    fields
            p               0.3; //
    Y 1 条回复 最后回复
    yjc95
    @李东岳 谢谢岳子老师,我很想去,但实际情况不允许。
    yjc95
    @李东岳 老师,pitzDaily这个案例用的是simpleFoam,代码里面也有设置参考点
            pEqn.setReference
                pressureReference.refCell(),
                pressureReference.refValue()
    为啥包括fvSolution文件在内的所有文件都没有设置压力参考点呢?是默认为0吗?
    有固定值边界条件不需要设置参考点
    Y 1 条回复 最后回复
    yjc95
    @李东岳 对哦,谢谢您
