拉格朗日粒子和动网格不兼容吗?
在interIsoFoam基础上加入了拉格朗日粒子,编译成功后在网格不变的情况下运行没有问题,但是加入动网格后,计算在进行一段时间后突然终止,没有报错,就是停在了Solving 3-D cloud kinematicCloud这里:
Courant Number mean: 4.05392e-05 max: 0.899987 Interface Courant Number mean: 3.47277e-06 max: 0.47951 deltaT = 4.6765e-06 Time = 0.102143 PIMPLE: iteration 1 Selected 4 cells for refinement out of 208887. Refined from 208887 to 208915 cells. Selected 0 split points out of a possible 6252. GAMGPCG: Solving for pcorr, Initial residual = 1, Final residual = 6.35461e-06, No Iterations 25 GAMGPCG: Solving for pcorr, Initial residual = 0.0776576, Final residual = 7.22028e-06, No Iterations 15 time step continuity errors : sum local = 4.77276e-15, global = 1.316e-17, cumulative = 8.05896e-11 Evolving kinematicCloud Solving 3-D cloud kinematicCloud重新跑了好多次,每次都是停在这里,有大神知道怎么解决吗?
谢谢岳哥,已经debug过了, 发现是KinematicCloud.C里运行到 cloud.motion(cloud, td);这一行就停了,定义在这里:
template<class CloudType> template<class TrackCloudType> void Foam::KinematicCloud<CloudType>::motion ( TrackCloudType& cloud, typename parcelType::trackingData& td ) { td.part() = parcelType::trackingData::tpLinearTrack; CloudType::move(cloud, td, solution_.trackTime()); updateCellOccupancy(); }有点debug不动了,现在还是毫无头绪。问了chatgpt也没解决。。。
