求助冷凝udf
#include "udf.h"
 /Constants used in psat_h2o to calculate saturation pressure/
 #define PSAT_A 0.01
 #define PSAT_TP 338.15
 #define C_LOOP 8
 #define H2O_PC 22.089E6
 #define H2O_TC 647.286
 /user inputs/
 #define MAX_SPE_EQNS_PRIM 2 /total number of species in primary phase/
 #define index_evap_primary 0 /evaporating species index in primary phase/
 #define prim_index 0 /index of primary phase/
 #define P_OPER 101325 /operating pressure equal to GUI value/
 /end of user inputs/
 / UDF for specifying an interfacial area density /
 double psat_h2o(double tsat)
 / Computes saturation pressure of water vapor /
 / as function of temperature /
 / Equation is taken from THERMODYNAMIC PROPERTIES IN SI, /
 / by Reynolds, 1979 /
 / Returns pressure in PASCALS, given temperature in KELVIN /
 int i;
 double var1,sum1,ans1,psat;
 double constants[8]={-7.4192420, 2.97221E-1, -1.155286E-1,
 8.68563E-3, 1.094098E-3, -4.39993E-3, 2.520658E-3, -5.218684E-4};
 / var1 is an expression that is used in the summation loop /
 var1 = PSAT_A(tsat-PSAT_TP);
 /* Compute summation loop /
 i = 0;
 sum1 = 0.0;
 while (i < C_LOOP){
 sum1+=constants[i]pow(var1,i);
 ++i;
 ans1 == sum1(H2O_TC/tsat-1.0);
 / compute exponential to determine result /
 / psat has units of Pascals /
 psat = H2O_PCexp(ans1);
 return psat;
 DEFINE_HET_RXN_RATE(user_evap_condens_react, c, t, hr, mw, yi, rr, rr_t)
 Thread **pt = THREAD_SUB_THREADS(t);
 Thread *tp = pt[0];
 Thread *ts = pt[1];
 int i;
 real concentration_evap_primary, accum = 0., mole_frac_evap_prim,
 concentration_sat ;
 real T_prim = C_T(c,tp); /primary phase (gas) temperature/
 real T_sec = C_T(c,ts); /secondary phase (droplet) temperature/
 real diam = C_PHASE_DIAMETER(c,ts); /secondary phase diameter/
 real D_evap_prim = C_DIFF_EFF(c,tp,index_evap_primary)- 0.7C_MU_T(c,tp)/C_R(c,tp);
 /primary phase species turbulent diffusivity/
 real Re, Sc, Nu, urel, urelx,urely,urelz=0., mass_coeff, area_density,
 flux_evap ;
 if(Data_Valid_P())
 urelx = C_U(c,tp) - C_U(c,ts);
 urely = C_V(c,tp) - C_V(c,ts);
 #if RP_3D
 urelz = C_W(c,tp) - C_W(c,ts);
 #endif
 urel = sqrt(urelxurelx + urelyurely + urelzurelz);
 /relative velocity/
 Re = urel * diam * C_R(c,tp) / C_MU_L(c,tp);
 Sc = C_MU_L(c,tp) / C_R(c,tp) / D_evap_prim ;
 Nu = 2. + 0.6 * pow(Re, 0.5)* pow(Sc, 0.333);
 mass_coeff = Nu * D_evap_prim / diam ;
 for (i=0; i < MAX_SPE_EQNS_PRIM ; i++)
 accum = accum + C_YI(c,tp,i)/mw[i][prim_index];
 mole_frac_evap_prim = C_YI(c,tp,index_evap_primary)
 / mw[index_evap_primary][prim_index] / accum;
 concentration_evap_primary = mole_frac_evap_prim * P_OPER
 / UNIVERSAL_GAS_CONSTANT / T_prim ;
 concentration_sat = psat_h2o(T_sec)/UNIVERSAL_GAS_CONSTANT/T_sec ;
 area_density = 6. * C_VOF(c,ts) / diam ;
 flux_evap = mass_coeff *
 (concentration_sat - concentration_evap_primary) ;
 *rr = area_density * flux_evap ;
