老师,各位大佬,想问一下,openfoam能实现从,假如从4500s到0s的,delta 取-1,仅对于标量的求解,比如说是浓度,这样的逆着时间的模拟么?
亦又
 openfoam的反演问题
 安装openfoam@李东岳 老师,openfoam4.1 是不是不用编译这个foamyMesh,是不是可以整个跳过
 安装openfoam@李东岳 加上之前的,老师您再看看这些
 compilation terminated.
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/backgroundMeshDecomposition/backgroundMeshDecomposition.o] 错误 1
 In file included from lnInclude/CGALTriangulation3Ddefs.H:41:0,
 from lnInclude/conformalVoronoiMesh.H:46,
 from lnInclude/cellSizeFunction.H:39,
 from cellShapeControl/cellSizeAndAlignmentControl/searchableSurfaceControl/searchableSurfaceControl.H:37,
 from cellShapeControl/cellSizeAndAlignmentControl/searchableSurfaceControl/searchableSurfaceControl.C:26:
 lnInclude/CGALTriangulation3DKernel.H:48:60: fatal error: CGAL/Robust_circumcenter_filtered_traits_3.h: 没有那个文件或目录
 #include "CGAL/Robust_circumcenter_filtered_traits_3.h"
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMeshConformToSurface.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellShapeControl/cellShapeControl.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMesh.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellShapeControlMesh/cellShapeControlMesh.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/DelaunayMeshTools/DelaunayMeshTools.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMeshFeaturePoints.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellSizeAndAlignmentControl/cellSizeAndAlignmentControls.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformalVoronoiMesh/conformalVoronoiMeshIO.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/conformationSurfaces/conformationSurfaces.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cvControls/cvControls.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/conformalVoronoiMesh/cellShapeControl/cellSizeAndAlignmentControl/searchableSurfaceControl/searchableSurfaceControl.o] 错误 1
 make[1]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39:generation] 错误 2
 make: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39:mesh] 错误 2
 这个foamyMesh里面好像又出现一些问题。
 安装openfoam@亦又 在 安装openfoam 中说: @亦又 在 安装openfoam 中说: @李东岳 -ldynamicMesh -lgenericPatchFields -lOpenFOAM -ldl
 -lm -o /home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/subsetMesh
 make: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/makefiles/apps:39:mesh] 错误 2这是啥问题? .PHONY: application
 application: $(FOAM_APPS).PHONY: $(FOAM_APPS)
 $(FOAM_APPS):
 +@wmake -all $(TARGET) $@ 这是34行到39行dyz@dyz-VMware-Virtual-Platform:~/OpenFOAM/OpenFOAM-4.1$ cd ~/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/manipulation/subsetMesh
 dyz@dyz-VMware-Virtual-Platform:~/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/manipulation/subsetMesh$ wmake
 /home/dyz/OpenFOAM/OpenFOAM-4.1/applications/utilities/mesh/manipulation/subsetMesh
 make: “/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/bin/subsetMesh”已是最新。
 咋回事
 安装openfoam@亦又 在 安装openfoam 中说: @李东岳 -ldynamicMesh -lgenericPatchFields -lOpenFOAM -ldl
 $(FOAM_APPS):
 安装openfoam@李东岳 -ldynamicMesh -lgenericPatchFields -lOpenFOAM -ldl
 安装openfoam@李东岳 老师,如何强制跳过啊?如果手动编译别的,怎么查看还需要编译那些?
 安装openfoam@李东岳 老师,可是它自动停止了,到这里
 安装openfoam@李东岳
 insertSurfaceNearestPointPairs.C: In member function ‘void Foam::CV2D::insertSurfaceNearestPointPairs()’:
 insertSurfaceNearestPointPairs.C:178:31: error: ‘toPoint3D’ was not declared in this scope
 toPoint3D(vert),
 insertSurfaceNearestPointPairs.C:225:67: error: no matching function for call to ‘Foam::CV2D::toPoint2D(const Foam::Vector<double>&)’
 surfacePoints.append(toPoint2D(pHit.hitPoint()));
 insertSurfaceNearestPointPairs.C:225:67: note: candidates are:
 In file included from CV2D.H:469:0,
 from insertSurfaceNearestPointPairs.C:26:
 CV2DI.H 29: note: const point2D& Foam::CV2D::toPoint2D(const int&) const 29: note: const point2D& Foam::CV2D::toPoint2D(const int&) const
 inline const Foam::point2D& Foam::CV2D::toPoint2D(const point& p) const
 CV2DI.H 29: note:   no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const int&’ 29: note:   no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const int&’
 CV2DI.H 33: note: const point2DField Foam::CV2D::toPoint2D(const pointField&) const 33: note: const point2DField Foam::CV2D::toPoint2D(const pointField&) const
 inline const Foam::point2DField Foam::CV2D::toPoint2D(const pointField& p) const
 CV2DI.H 33: note:   no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const pointField& {aka const Foam::Field<Foam::Vector<double> >&}’ 33: note:   no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const pointField& {aka const Foam::Field<Foam::Vector<double> >&}’
 CV2DI.H:149:37: note: const point2D& Foam::CV2D::toPoint2D(const Point&) const
 inline Foam::CV2D::point2DFromPoint Foam::CV2D::toPoint2D(const Point& P) const
 CV2DI.H:149:37: note: no known conversion for argument 1 from ‘const Foam::Vector<double>’ to ‘const Point& {aka const CGAL::Point_2CGAL::Epick&}’
 from insertBoundaryConformPointPairs.C:26:
 CV2DI.H: In member function ‘bool Foam::CV2D::insertMirrorPoint(const point2D&, const point2D&)’:
 CV2DI.H:94:1: warning: control reaches end of non-void function [-Wreturn-type]
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertBoundaryConformPointPairs.o] 错误 1
 make[2]: *** 正在等待未完成的任务....
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2D.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/foamyQuadMesh.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertSurfaceNearPointPairs.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/CV2DIO.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertFeaturePoints.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/insertSurfaceNearestPointPairs.o] 错误 1
 make[2]: *** [/home/dyz/OpenFOAM/OpenFOAM-4.1/wmake/rules/General/transform:8:/home/dyz/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt32Opt/applications/utilities/mesh/generation/foamyMesh/foamyQuadMesh/shortEdgeFilter2D.o] 错误 1
 老师,这是什么问题?
 安装openfoam@李东岳 我用到了gcc5了,别的那些包有什么需要改动或者那个些源网站要怎么调整,./Allwmake -j 总是出问题?
 安装openfoam@李东岳 老师,之前一直用的4.1 感觉别的版本区别还不小,用起来不是很习惯
 安装openfoam@李东岳 老师,  。我在网上找到了压缩包,但是在Ubuntu24.04.1安装,总是出现各种问题。 。我在网上找到了压缩包,但是在Ubuntu24.04.1安装,总是出现各种问题。
 安装openfoam@亦又 在 安装openfoam 中说: @李东岳 老师,https://cfd-china.com/topic/7069/openfoam-org系列国内满速下载地址, 这里面的4.X是4.1版本么?那这个4.1版本的如何在ubuntu24.04上下载?需要换系统么? 好像很多东西版本不太兼容,那我需要怎么操作?
 安装openfoam@李东岳 老师,https://cfd-china.com/topic/7069/openfoam-org系列国内满速下载地址, 这里面的4.X是4.1版本么?那这个4.1版本的如何在ubuntu24.04上下载?需要换系统么?
 安装openfoam@李东岳 老师如果想安装自己以前的用过的openfoam-4.1,应该怎么操作?
 openFoam-11@李东岳 老师,ubuntu上安装了openfoam11了,还想安装一个openfoam10,我该如何操作?
 open foam11想问一下,openfoam11有哪些和之前不一样的地方,或者也没有什么需要注意的地方
 openFoam-11@李东岳 老师,我调了,虚拟器的处理器数量,然后保持电脑内存足够。就能安装了
 openFoam-11@李东岳
 g++: fatal error: 已杀死 signal terminated program cc1plus
 make[2]: *** [VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/CMakeFiles/vtkm_filter_gradient.dir/build.make:118:VTK/ThirdParty/vtkm/vtkvtkm/vtk-m/vtkm/filter/CMakeFiles/vtkm_filter_gradient.dir/GradientVector.cxx.o] 错误 1
 make[2]: *** 正在等待未完成的任务....也显示这个错误
 openFoam-11@李东岳 是的,前面也有些小问题。但通过更新部分内容,都能正常完成
