我在查阅function Object turbulenceFields 的源代码时一直在思考一个问题:实现对湍流场的访问如R,k等是如何实现的。因为在源码turbulenceFields.C中没有定义任何显式的公式,经过很长时间的查阅之后我终于大概明白了,这涉及到OpenFOAM中通过复杂的宏实现湍流模型的具体化,所以就在这里记录一下。(在查阅时为了方便,用英语写的注解就懒得改了)
Turbulence model is defined by looking up in obr_(Object registry) which stored all accessible filed and models (in turbulenceFields.C)
in
turbulenceFields.C/turbulenceFields::execute()const auto& model = obr_.lookupObject<incompressible::turbulenceModel>(modelName_); /***/ processField<symmTensor>(f, model.R()); -
in
turbulentTransportModel.Hthis file defines name space
incompressibleand its typeturbulenceModel. which givesincompressible::turbulenceModelis equal to typeIncompressibleTurbulenceModel<transportModel>.namespace Foam { namespace incompressible { typedef IncompressibleTurbulenceModel<transportModel> turbulenceModel; /***/ } } -
in
IncompressibleTurbulenceModel.Hinclude
src/TurbulenceModels/turbulenceModels/TurbulenceModel/TurbulenceModel.H#include "TurbulenceModel.H"then in
TurbulenceModel.H, includesrc/TurbulenceModels/turbulenceModels/turbulenceModel.H#include "turbulenceModel.H"where in
turbulenceModel.H, turbulence fields i. e.Randk, are defined as pure virtual functions: (has to be realized by subclass)virtual tmp<volScalarField> k() const = 0; virtual tmp<volSymmTensorField> R() const = 0; -
LES Model is then derived from template parameters
BasicTurbulenceModels(indicates the compressibility of the flow), inturbulentTransportModels.H, macro is defined to make LES models:#define makeLESModel(Type)\ makeTemplatedTurbulenceModel \ (transportModelIncompressibleTurbulenceModel, LES, Type)this macro is based in
makeTurbulenceModel.H:#define makeTemplatedTurbulenceModel(BaseModel, SType, Type) \ /***/which gives template parameters:
BaseModel: transportModelIncompressibleTurbulenceModel Stype: LESin
turbulentTransportModels.C,BaseModelis made by macro realization:makeBaseTurbulenceModel ( geometricOneField, geometricOneField, incompressibleTurbulenceModel, IncompressibleTurbulenceModel, transportModel );this macro is defined in
makeTurbulenceModel.Has well:#define defineTurbulenceModelTypes( \ Alpha, Rho, baseModel, BaseModel, Transport) \ namespace Foam \ { \ typedef TurbulenceModel \ < \ Alpha, \ Rho, \ baseModel, \ Transport \ > Transport##baseModel; typedef BaseModel<Transport> \ Transport##BaseModel; \ typedef laminarModel<Transport##BaseModel> \ laminar##Transport##BaseModel; \ typedef RASModel<Transport##BaseModel> \ RAS##Transport##BaseModel; \ typedef LESModel<Transport##BaseModel> \ LES##Transport##BaseModel; } #define makeBaseTurbulenceModel(Alpha, Rho, baseModel, BaseModel, Transport) \ /* Turbulence typedefs */\ defineTurbulenceModelTypes(Alpha, Rho, baseModel, BaseModel, Transport) \ namespace Foam \ { \ /* Turbulence selection table */\ defineTemplateRunTimeSelectionTable \ ( \ Transport##baseModel, \ dictionary \ ); /***/ /* LES models */ \ defineNamedTemplateTypeNameAndDebug(LES##Transport##BaseModel, 0); \ defineTemplateRunTimeSelectionTable \ (LES##Transport##BaseModel, dictionary); \ addToRunTimeSelectionTable \ ( \ Transport##baseModel, \ LES##Transport##BaseModel, \ dictionary \ ); \ }by macro,
transportModel(Transport) is attached toIncompressibleTurbulenceModel(BaseModel) making aBaseModelof typeIncompressibleTurbulenceModel<transportModel>. As noted above, this is also aliased asincompressible::turbulenceModelthe
WALEmodel is made by macromakeLESModel():#include "WALE.H" makeLESModel(WALE);which gives template parameters:
BaseModel: transportModelIncompressibleTurbulenceModel Stype: LES Type: WALE -
Finally, this leads to the conclusion that the function object
turbulenceFieldsis linked to turbulence models original definition. It usesprocessField()to look up registered fields in turbulence model defined inconstant/turbulenceProperties. i. e. turbulence fields forWALEmodel is defined inWALE.C. As fork, it is realized directly inWALE.C:template<class BasicTurbulenceModel> tmp<volSymmTensorField> WALE<BasicTurbulenceModel>::Sd ( const volTensorField& gradU ) const { return dev(symm(gradU & gradU)); }$$
S^d_{ij}=\frac12(\frac{\partial u_i}{\partial x_j}\frac{\partial u_j}{\partial x_k}+\frac{\partial u_k}{\partial x_j}\frac{\partial u_j}{\partial x_i})
$$template<class BasicTurbulenceModel> tmp<volScalarField> WALE<BasicTurbulenceModel>::k ( const volTensorField& gradU ) const { volScalarField magSqrSd(magSqr(Sd(gradU))); return tmp<volScalarField> ( new volScalarField ( IOobject(IOobject::groupName("k", this-> alphaRhoPhi_.group()), this->runTime_.timeName(),this->mesh_), sqr(sqr(Cw_)*this->delta()/Ck_)*(pow3(magSqrSd) / ( sqr(pow(magSqr(symm(gradU)),5.0/2.0) +pow(magSqrSd,5.0/4.0)) +dimensionedScalar("SMALL",dimensionSet(0, 0, -10, 0, 0),SMALL)) ) ));}$$
\text{magSqr}S^d=(S^d_{ij}S^d_{ij})^{\frac12},
S_{ij}=\frac12(\frac{\partial u_i}{\partial x_j}+\frac{\partial u_j}{\partial x_i})
k=\left(\frac {C_w^2\Delta}{C_k}\right)^2\frac{(S^d_{ij}S^d_{ij})^{\frac32}}{(S_{ij}S_{ij})^{\frac52}+(S^d_{ij}S^d_{ij})^{\frac54}}
$$While
Ris inherited fromeddyViscosity::R(), because inWALE.H:#include "LESeddyViscosity.H"then in
LESeddyViscosity.H:#include "eddyViscosity.H"finally, in
eddyViscosity.H:template<class BasicTurbulenceModel> Foam::tmp<Foam::volSymmTensorField> Foam::eddyViscosity<BasicTurbulenceModel>::R() const { tmp<volScalarField> tk(k()); // Get list of patchField type names from k wordList patchFieldTypes(tk().boundaryField().types()); // For k patchField types which do not have an equivalent for symmTensor // set to calculated forAll(patchFieldTypes, i){ if(!fvPatchField<symmTensor>::patchConstructorTablePtr_->found(patchFieldTypes[i])){ patchFieldTypes[i] = calculatedFvPatchField<symmTensor>::typeName;} } return tmp<volSymmTensorField> ( new volSymmTensorField( IOobject(IOobject::groupName("R", this->alphaRhoPhi_.group()),this->runTime_.timeName(),this->mesh_,IOobject::NO_READ,IOobject::NO_WRITE,false), ((2.0/3.0)*I)*tk() - (nut_)*dev(twoSymm(fvc::grad(this->U_))), patchFieldTypes) );}$$
\tau_{ij}=\frac23k\delta_{ij}-2\nu_tS_{ij}
$$While
nut_is updated inWALE.C:template<class BasicTurbulenceModel> void WALE<BasicTurbulenceModel>::correctNut() { this->nut_ = Ck_*this->delta()*sqrt(this->k(fvc::grad(this->U_))); this->nut_.correctBoundaryConditions(); fv::options::New(this->mesh_).correct(this->nut_); BasicTurbulenceModel::correctNut(); }$$
\nu_t=C_k\delta\sqrt k
