@东岳 和@yfclark 感谢两位的建议
对这个问题,我实在无从下手,于是刚刚尝试了一下换个版本的求解器试试看。于是,我将同样的代码片段植入到of4.0和fe4.0的interFoam求解器中,并做了同样的算例。结果发现同样的条件下的Laplace方程,of4.0解不了,fe4.0可以解。这让我很迷惑。
这个是of4.0求解器的算例的log文件,可以看到它的 Initial residual并没有收敛的迹象。
|  \\    /   O peration     | Version:  4.x                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 4.x
Exec   : interFoamtest
Date   : Oct 28 2019
Time   : 16:51:11
Host   : "cfd"
PID    : 116917
Case   : /home/cfd/OpenFOAM/cfd-4.x/run/interFoamtest/damBreak
nProcs : 1
sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster
Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading field p_rgh
Reading field U
Reading transportProperties
Selecting incompressible transport model Newtonian
Selecting turbulence model type laminar
Reading g
Reading hRef
Calculating field g.h
No MRF models present
DICPCG:  Solving for pcorr, Initial residual = 0, Final residual = 0, No Iterations 0
time step continuity errors : sum local = 0, global = 0, cumulative = 0
Courant Number mean: 0 max: 0
Starting time loop
Interface Courant Number mean: 0 max: 0
Time = 0.001
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 0, Final residual = 0, No Iterations 0
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = 0  Max(alpha.water) = 1
MULES: Correcting alpha.water
smoothSolver:  Solving for phiE, Initial residual = 1, Final residual = 0.00666667, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.969654, Final residual = 0.955898, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999906, Final residual = 0.999906, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999943, Final residual = 0.999943, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999959, Final residual = 0.999959, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.99997, Final residual = 0.99997, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999977, Final residual = 0.999977, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999982, Final residual = 0.999982, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999986, Final residual = 0.999986, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999989, Final residual = 0.999989, No Iterations 1000
DICPCG:  Solving for p_rgh, Initial residual = 1, Final residual = 0.0288118, No Iterations 2
time step continuity errors : sum local = 3.79873e-07, global = -1.14217e-22, cumulative = -1.14217e-22
DICPCG:  Solving for p_rgh, Initial residual = 0.014257, Final residual = 0.000679011, No Iterations 51
time step continuity errors : sum local = 1.80931e-08, global = 1.97801e-23, cumulative = -9.44368e-23
DICPCG:  Solving for p_rgh, Initial residual = 0.000685827, Final residual = 9.85239e-08, No Iterations 330
time step continuity errors : sum local = 2.59978e-12, global = -2.24454e-24, cumulative = -9.66814e-23
ExecutionTime = 29.16 s  ClockTime = 29 s
Courant Number mean: 8.45892e-06 max: 0.00486238
Time = 0.002
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 1.03138e-05, Final residual = 1.278e-11, No Iterations 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -1.02138e-12  Max(alpha.water) = 1
smoothSolver:  Solving for phiE, Initial residual = 0.999991, Final residual = 0.999991, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999993, Final residual = 0.999993, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999994, Final residual = 0.999994, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999995, Final residual = 0.999995, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999996, Final residual = 0.999996, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999997, Final residual = 0.999997, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.999998, Final residual = 0.999998, No Iterations 1000
DICPCG:  Solving for p_rgh, Initial residual = 0.148216, Final residual = 0.00717185, No Iterations 8
time step continuity errors : sum local = 1.53736e-07, global = 1.00047e-22, cumulative = 3.36563e-24
DICPCG:  Solving for p_rgh, Initial residual = 0.00694699, Final residual = 0.00032885, No Iterations 69
time step continuity errors : sum local = 7.31529e-09, global = -5.63383e-24, cumulative = -2.2682e-24
DICPCG:  Solving for p_rgh, Initial residual = 0.000331229, Final residual = 9.04502e-08, No Iterations 320
time step continuity errors : sum local = 2.00174e-12, global = -1.03358e-23, cumulative = -1.2604e-23
ExecutionTime = 55.26 s  ClockTime = 55 s
Courant Number mean: 1.00744e-05 max: 0.00608536
Time = 0.003
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 1.17667e-05, Final residual = 1.48862e-11, No Iterations 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -7.81203e-23  Max(alpha.water) = 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -2.49888e-15  Max(alpha.water) = 1
smoothSolver:  Solving for phiE, Initial residual = 0.999999, Final residual = 0.999999, No Iterations 1000
DICPCG:  Solving for p_rgh, Initial residual = 0.0570031, Final residual = 0.00216312, No Iterations 3
time step continuity errors : sum local = 4.53781e-08, global = -1.07358e-25, cumulative = -1.27114e-23
DICPCG:  Solving for p_rgh, Initial residual = 0.00216994, Final residual = 0.000103227, No Iterations 32
time step continuity errors : sum local = 2.19448e-09, global = 2.56894e-23, cumulative = 1.29781e-23
DICPCG:  Solving for p_rgh, Initial residual = 0.000103679, Final residual = 9.68435e-08, No Iterations 180
time step continuity errors : sum local = 2.06555e-12, global = 2.39499e-23, cumulative = 3.6928e-23
ExecutionTime = 80.51 s  ClockTime = 80 s
Courant Number mean: 1.02305e-05 max: 0.0059902
Time = 0.004
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 1.14624e-05, Final residual = 1.20817e-11, No Iterations 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -2.32959e-16  Max(alpha.water) = 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -6.27415e-12  Max(alpha.water) = 1
DICPCG:  Solving for p_rgh, Initial residual = 0.025679, Final residual = 0.00121229, No Iterations 2
time step continuity errors : sum local = 2.4847e-08, global = 4.56559e-24, cumulative = 4.14936e-23
DICPCG:  Solving for p_rgh, Initial residual = 0.00123628, Final residual = 5.7827e-05, No Iterations 29
time step continuity errors : sum local = 1.18735e-09, global = -1.92179e-25, cumulative = 4.13014e-23
DICPCG:  Solving for p_rgh, Initial residual = 5.83662e-05, Final residual = 9.44483e-08, No Iterations 129
time step continuity errors : sum local = 1.94768e-12, global = -2.79384e-23, cumulative = 1.3363e-23
ExecutionTime = 105.48 s  ClockTime = 105 s
Courant Number mean: 1.02721e-05 max: 0.00571222
Time = 0.005
PIMPLE: iteration 1
smoothSolver:  Solving for alpha.water, Initial residual = 1.10272e-05, Final residual = 9.91906e-12, No Iterations 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -1.84397e-16  Max(alpha.water) = 1
Phase-1 volume fraction = 0.0247173  Min(alpha.water) = -5.64491e-12  Max(alpha.water) = 1
DICPCG:  Solving for p_rgh, Initial residual = 0.0170557, Final residual = 0.000707649, No Iterations 2
time step continuity errors : sum local = 1.40556e-08, global = 5.55595e-24, cumulative = 1.8919e-23
DICPCG:  Solving for p_rgh, Initial residual = 0.00072258, Final residual = 3.40642e-05, No Iterations 66
time step continuity errors : sum local = 6.7235e-10, global = -1.97122e-24, cumulative = 1.69477e-23
DICPCG:  Solving for p_rgh, Initial residual = 3.47482e-05, Final residual = 9.44334e-08, No Iterations 110
time step continuity errors : sum local = 1.97407e-12, global = 2.71579e-25, cumulative = 1.72193e-23
ExecutionTime = 132.15 s  ClockTime = 132 s
Courant Number mean: 1.03787e-05 max: 0.00551763
这里是fe4.0的求解器的算例的log文件,它的Initial residual则呈现了收敛的趋势
| \\      /  F ield         | foam-extend: Open Source CFD                    |
|  \\    /   O peration     | Version:     4.0                                |
|   \\  /    A nd           | Web:         http://www.foam-extend.org         |
|    \\/     M anipulation  | For copyright notice see file Copyright         |
Build    : 4.0
Date     : Oct 28 2019
Time     : 16:44:23
Host     : cfd
PID      : 116498
CtrlDict : "/home/cfd/foam/cfd-4.0/run/damBreak/system/controlDict"
Case     : /home/cfd/foam/cfd-4.0/run/damBreak
nProcs   : 1
SigFpe   : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Reading g
Reading field pd
Reading field alpha1
Reading field U
Courant Number mean: 0 max: 0 velocity magnitude: 0
Starting time loop
Time = 0.001
PIMPLE: iteration 1
MULES: Solving for alpha1
Liquid phase volume fraction = 0.0247173  Min(alpha1) = 0  Max(alpha1) = 1
BiCGStab:  Solving for Ux, Initial residual = 1, Final residual = 8.84344e-16, No Iterations 1
BiCGStab:  Solving for Uy, Initial residual = 1, Final residual = 2.39687e-15, No Iterations 1
BiCGStab:  Solving for Uz, Initial residual = 0.999809, Final residual = 1.01154e-15, No Iterations 1
smoothSolver:  Solving for phiE, Initial residual = 1, Final residual = 0.00885022, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.00440562, Final residual = 0.00275942, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.00276397, Final residual = 0.00177986, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.00178161, Final residual = 0.00114823, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.00114896, Final residual = 0.000740514, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.000740817, Final residual = 0.000477462, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.000477588, Final residual = 0.000307809, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.000307862, Final residual = 0.000198419, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.000198441, Final residual = 0.000127897, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 0.000127906, Final residual = 8.24364e-05, No Iterations 1000
DICPCG:  Solving for pd, Initial residual = 1, Final residual = 0.0228419, No Iterations 2
DICPCG:  Solving for pd, Initial residual = 0.0113008, Final residual = 0.000494115, No Iterations 19
DICPCG:  Solving for pd, Initial residual = 0.00049866, Final residual = 2.39276e-05, No Iterations 115
DICPCG:  Solving for pd, Initial residual = 2.39472e-05, Final residual = 9.68596e-08, No Iterations 302
time step continuity errors : sum local = 9.29479e-09, global = 1.57022e-22, cumulative = 1.57022e-22
ExecutionTime = 30.3 s  ClockTime = 30 s
Courant Number mean: 0.000308178 max: 0.120588 velocity magnitude: 1.20588
Time = 0.002
PIMPLE: iteration 1
BiCGStab:  Solving for Ux, Initial residual = 0.776521, Final residual = 8.28489e-11, No Iterations 2
BiCGStab:  Solving for Uy, Initial residual = 0.488694, Final residual = 2.35091e-11, No Iterations 2
BiCGStab:  Solving for Uz, Initial residual = 0.492107, Final residual = 6.27383e-10, No Iterations 2
smoothSolver:  Solving for phiE, Initial residual = 8.24401e-05, Final residual = 5.31333e-05, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 5.31349e-05, Final residual = 3.42459e-05, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 3.42465e-05, Final residual = 2.20722e-05, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 2.20724e-05, Final residual = 1.42259e-05, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 1.4226e-05, Final residual = 9.16875e-06, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 9.1688e-06, Final residual = 5.90937e-06, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 5.90939e-06, Final residual = 3.80865e-06, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 3.80866e-06, Final residual = 2.45471e-06, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 2.45471e-06, Final residual = 1.58208e-06, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 1.58208e-06, Final residual = 1.01967e-06, No Iterations 1000
DICPCG:  Solving for pd, Initial residual = 0.146545, Final residual = 0.00361308, No Iterations 2
DICPCG:  Solving for pd, Initial residual = 0.00335961, Final residual = 0.000167276, No Iterations 105
DICPCG:  Solving for pd, Initial residual = 0.000188382, Final residual = 9.23987e-06, No Iterations 49
DICPCG:  Solving for pd, Initial residual = 9.8482e-06, Final residual = 9.46082e-08, No Iterations 286
time step continuity errors : sum local = 2.47934e-09, global = -3.54267e-22, cumulative = -1.97245e-22
ExecutionTime = 58.46 s  ClockTime = 58 s
Courant Number mean: 0.000218338 max: 0.0405799 velocity magnitude: 0.405799
Time = 0.003
PIMPLE: iteration 1
BiCGStab:  Solving for Ux, Initial residual = 0.431649, Final residual = 2.74542e-08, No Iterations 1
BiCGStab:  Solving for Uy, Initial residual = 0.223545, Final residual = 5.07216e-10, No Iterations 1
BiCGStab:  Solving for Uz, Initial residual = 0.212763, Final residual = 1.13065e-09, No Iterations 1
smoothSolver:  Solving for phiE, Initial residual = 1.01967e-06, Final residual = 6.57184e-07, No Iterations 1000
smoothSolver:  Solving for phiE, Initial residual = 6.57184e-07, Final residual = 4.23565e-07, No Iterations 1000
DICPCG:  Solving for pd, Initial residual = 0.027659, Final residual = 0.000699273, No Iterations 2
DICPCG:  Solving for pd, Initial residual = 0.00069462, Final residual = 3.42751e-05, No Iterations 109
DICPCG:  Solving for pd, Initial residual = 3.70155e-05, Final residual = 1.75277e-06, No Iterations 49
DICPCG:  Solving for pd, Initial residual = 1.78108e-06, Final residual = 9.77867e-08, No Iterations 266
time step continuity errors : sum local = 2.18185e-09, global = 1.21446e-22, cumulative = -7.57986e-23
ExecutionTime = 65.25 s  ClockTime = 65 s
Courant Number mean: 0.000237433 max: 0.0260814 velocity magnitude: 0.260814
Time = 0.004
PIMPLE: iteration 1
Liquid phase volume fraction = 0.0247173  Min(alpha1) = -5.52899e-28  Max(alpha1) = 1
BiCGStab:  Solving for Ux, Initial residual = 0.212063, Final residual = 1.20667e-11, No Iterations 1
BiCGStab:  Solving for Uy, Initial residual = 0.157791, Final residual = 5.26792e-13, No Iterations 1
BiCGStab:  Solving for Uz, Initial residual = 0.144847, Final residual = 8.02311e-13, No Iterations 1
smoothSolver:  Solving for phiE, Initial residual = 4.23565e-07, Final residual = 2.73004e-07, No Iterations 1000
DICPCG:  Solving for pd, Initial residual = 0.00638702, Final residual = 0.000228527, No Iterations 2
DICPCG:  Solving for pd, Initial residual = 0.000229721, Final residual = 1.09143e-05, No Iterations 115
DICPCG:  Solving for pd, Initial residual = 1.142e-05, Final residual = 4.41946e-07, No Iterations 58
DICPCG:  Solving for pd, Initial residual = 4.43246e-07, Final residual = 9.98953e-08, No Iterations 236
time step continuity errors : sum local = 1.92551e-09, global = -2.38779e-22, cumulative = -3.14578e-22
ExecutionTime = 69.77 s  ClockTime = 69 s
Courant Number mean: 0.000307195 max: 0.0317014 velocity magnitude: 0.317014
Time = 0.005
PIMPLE: iteration 1
BiCGStab:  Solving for Ux, Initial residual = 0.141162, Final residual = 1.73043e-11, No Iterations 1
BiCGStab:  Solving for Uy, Initial residual = 0.123101, Final residual = 6.00829e-13, No Iterations 1
BiCGStab:  Solving for Uz, Initial residual = 0.11123, Final residual = 9.9712e-13, No Iterations 1
smoothSolver:  Solving for phiE, Initial residual = 2.73004e-07, Final residual = 1.75965e-07, No Iterations 1000
DICPCG:  Solving for pd, Initial residual = 0.0068371, Final residual = 0.000235051, No Iterations 2
DICPCG:  Solving for pd, Initial residual = 0.000232659, Final residual = 1.10913e-05, No Iterations 27
DICPCG:  Solving for pd, Initial residual = 1.12968e-05, Final residual = 5.32458e-07, No Iterations 125
DICPCG:  Solving for pd, Initial residual = 5.36239e-07, Final residual = 9.64374e-08, No Iterations 42
time step continuity errors : sum local = 1.68223e-09, global = 4.27902e-22, cumulative = 1.13324e-22
ExecutionTime = 74.91 s  ClockTime = 75 s
Courant Number mean: 0.000376038 max: 0.0360665 velocity magnitude: 0.360665
姑且假设我写的求解器没有大问题的条件下,上述结果说明,两个版本的求解结果存在了不同。
所以,我在想是不是of40和fe40的Laplace求解器在什么地方存在差异,导致了这样的结果?
