Z
zju_klh
@zju_klh
  • fluent自定义求解器(sprayFoam)
    Z zju_klh
    @coolhhh 前辈 我还想问一下 我按照网上搜到修改蒸发模型的算例去修改碰撞模型 编译过程里没有报错 为什么在算例里读不出来我自定义的碰撞模型:135:
    Z zju_klh
    @coolhhh 感谢前辈!才看到 已经解决了!
    Z zju_klh
    请教各位前辈,在自定义求解器的时候遇到这个报错,但是我的options文件没有56行,修改制表符也没有解决,是什么问题呢微信图片_20250310164424.png 微信图片_20250310164452.png
  • openfoam计算停止但无明显error报错
    Z zju_klh
    @Amadeus 谢谢您 我这边换了个喷油的方式 可以算了 等手头事情做完了我试试您说的方法!
    Z zju_klh
    @ShaneHEEE 微信图片_20250221173635.png 我这边尝试了一下并行计算,但是这个返回非0是什么意思啊
    Z zju_klh
    各位老师 我在使用spray foam时遇到计算停止,但是日志并没有报错,这是什么原因。
    |  \\    /   O peration     | Version:  2406                                  |
    Build  : _be01ca78-20240625 OPENFOAM=2406 version=2406
    Arch   : "LSB;label=32;scalar=64"
    Exec   : sprayFoam
    Date   : Feb 21 2025
    Time   : 16:33:03
    Host   : DESKTOP-1CFS1LE
    PID    : 2872
    I/O    : uncollated
    Case   : /mnt/c/openfoam_run/nocoll_5g_more
    nProcs : 1
    trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
    fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5, maxFileModificationPolls 20)
    Create time
    Create mesh for time = 0
    PIMPLE: Operating solver in PISO mode
    Reading g
    Reading thermophysical properties
    Selecting thermodynamics package
        type            hePsiThermo;
        mixture         reactingMixture;
        transport       sutherland;
        thermo          janaf;
        energy          sensibleEnthalpy;
        equationOfState perfectGas;
        specie          specie;
    Selecting chemistryReader chemkinReader
    Reading CHEMKIN thermo data in new file format
    Creating component thermo properties:
        multi-component carrier - 5 species
        liquids - 1 components
        solids - 0 components
    Reading field U
    Creating turbulence model
    Selecting RAS turbulence model kEpsilon
    RAS
        RASModel        kEpsilon;
        turbulence      on;
        printCoeffs     on;
        Cmu             0.09;
        C1              1.44;
        C2              1.92;
        C3              0;
        sigmak          1;
        sigmaEps        1.3;
    Creating combustion model
    Selecting combustion model PaSR
    Selecting chemistry solver
        solver          ode;
        method          standard;
    StandardChemistryModel: Number of species = 5 and reactions = 1
    Selecting ODE solver seulex
        using integrated reaction rate
    Creating field dpdt
    Creating field kinetic energy K
    No MRF models present
    Constructing reacting cloud
    Constructing particle forces
        Selecting particle force sphereDrag
    Constructing cloud functions
        Selecting cloud function WeberNumber1 of type WeberNumber
        Selecting cloud function ReynoldsNumber1 of type ReynoldsNumber
        Selecting cloud function NusseltNumber1 of type NusseltNumber
        Selecting cloud function HeatTransferCoeff1 of type HeatTransferCoeff
    Constructing particle injection models
    Creating injector: model1
    Selecting injection model coneNozzleInjection
        Constructing 3-D injection
    Selecting distribution model RosinRammler
    Selecting dispersion model none
    Selecting patch interaction model standardWallInteraction
    Selecting stochastic collision model none
    Selecting surface film model none
    Selecting packing model none
    Selecting damping model none
    Selecting isotropy model none
    Selecting U integration scheme Euler
    Selecting heat transfer model RanzMarshall
    Selecting T integration scheme analytical
    Selecting composition model singlePhaseMixture
    Selecting phase change model liquidEvaporation
    Participating liquid species:
        C7H16
    Selecting atomizationModel LISA
    Selecting breakupModel ReitzKHRT
    Average parcel mass: 1e-09
    Selecting radiationModel none
    Courant Number mean: 0 max: 0
    Starting time loop
    particleDistribution distribution1 output:
        Processing cloud : sprayCloud
    deltaT = 2.94118e-06
    Time = 2.94118e-06
    Solving3-D cloud sprayCloud
  • OpenFoam液滴碰撞模型
    Z zju_klh
    @李东岳 有的 我这边一个算例大概要4-6h,网格不算太多
  • OpenFoam液滴碰撞模型
    Z zju_klh
    @李东岳 应该不是的老师 我增加了粒子数量还是重叠
  • OpenFoam液滴碰撞模型
    Z zju_klh
    请教各位老师,我在OF中开启了液滴碰撞模型,并在相同工况下分别选取其中的nocoll(无碰撞)、orourke(概率法)和trajectory(轨迹法)三种碰撞模型进行计算,但是轨迹法与无碰撞的液滴贯穿距完全一致,这是什么原因呢?微信图片_20250219140332.png
  • 请问如何在paraview中输出某一界面上的液相分数
    Z zju_klh
    @李东岳 谢谢老师!!!
    Z zju_klh
    如图,在做有关雾化的课题,但是在paraview中不知道怎么复现前辈的论文输出某截面的液相分数微信图片_20241221153039.png 微信图片_20241221153346.png 图片1.png
  • ORourke碰撞模型调用
    Z zju_klh
    @wangfei9088 谢谢老师!
  • ORourke碰撞模型调用
    Z zju_klh
    @欧阳 老师您好,我翻看了一些算例,没有找到关于这个两个值该如何定义,请问是需要我自己给定嘛微信图片_20241129132812.png 微信图片_20241129132751.png
  • ORourke碰撞模型调用
    Z zju_klh
    我这里显示在轨迹模型中缺少参数,想问一下这里具体参数是什么啊,需要加哪些参数呢
  • ORourke碰撞模型调用
    Z zju_klh
    @欧阳 谢谢大佬!我里面的参数设置有些问题,已经纠正了,另外还想请问,在OF碰撞模型里面出了有ORourke还有个Tracject,也是直接在stochasticCollisionModel上调用吗
  • ORourke碰撞模型调用
    Z zju_klh
    各位老师,我想基于OF里面的openfoam/tutorials/lagrangian/sprayFoama/achenBomb算例引入ORourke碰撞模型,直接计算算例没有问题,但是我关闭原有算例的化学反应部分,修正喷油方式为持续喷油并打开相应的随机碰撞模型以后,发现程序无法计算,没有报错,但也没有计算结果,还请各位老师指教一下!
